Cub Cadet 100 Rear axle issues - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 07-11-2019, 09:08 PM Thread Starter
fanboy0199's Avatar
Help Cub Cadet 100 Rear axle issues
Im trying to replace the seals in my cub 100 rear axle. however i cannot get the clips that hold the axles off. they are not like normal c clips where you could stick a screw driver in a pop them off. i have been at this for 3 days with no luck. i have tried everything i can think of. any way of cutting them off?
Thanks
1999 Craftsman GT 20/46
2003 John Deere G100
1998 Cub Cadet 2165
1994 Service Star MTD Garden Tractor
1995 MTD Lowes Garden Tractor
1998 Simplicity Coronet
1987 Simplicity 4212
1972 GE E14
1969 Case 220
1968 Allis Chalmers B10
1972 Wheelhorse Ranger 800
1963 Cub Cadet 100
1974 John Deere Push Mower
1975 John Deere 212
1974 Ford Push mower
1962 Toro Sportlawn 18
1967 Hahn Eclipse Rocket 21
2002 Toro Super Recycler
2005 Toro Recycler
1998 Lawnboy 10323
fanboy0199 is offline
post #2 of 10 Old 07-11-2019, 09:26 PM
Re: Cub Cadet 100 Rear axle issues
Not sure of this on your model.
But alot of older machines used a snap ring rather than e-clips of today.
Look to see if there are two small holes where the ring almost meets itself.
If so you need snap ring pliers to remove.
Be careful taking them off-they can shoot themselves across the room if you slip.
Wlmitty is offline
post #3 of 10 Old 07-12-2019, 04:53 AM
Maybe post a pic of the clip, if post #2 didn't help.
dave_r is offline
post #4 of 10 Old 07-14-2019, 08:59 AM
RBedell's Avatar
Here is a picture of the Retainer Ring.
CC models: 100, 105, 129, 1450, & 784
Only Cub Cadets
Buy: Made in the USA
RBedell is online now
post #5 of 10 Old 07-14-2019, 03:27 PM
Put the tip of a screwdriver in one of the two cutout openings of the clip and rotate the screwdriver. The clip should slide at least partially open, and then either repeat on the other cutout opening and/or with a larger screwdriver for it to slide all the way off.
dave_r is offline
post #6 of 10 Old 07-15-2019, 11:50 PM
What Dave said. But keep your non-screwdriver hand on/over it to keep it from flying.
NicoR is offline
post #7 of 10 Old 07-16-2019, 10:10 AM
On the Parts Tree page for the Cub Cadet 100 model for the rear axle shows that Item #6 is two snap rings. Snap rings are different than the E or C clips that many use today. You need a special tool called a snap ring pliers to remove the snap ring, which are available at most places you buy tools.
https://www.partstree.com/parts/cub-...tor/rear-axle/
Flaken is online now
post #8 of 10 Old 07-17-2019, 06:59 AM
RBedell's Avatar
The IH-378066-R1 is pictured above.
Only Cub Cadets
post #9 of 10 Old 07-17-2019, 07:19 AM
Yes, that is an E-clip not a snap ring.
post #10 of 10 Old 07-17-2019, 07:32 AM
Kubota Ronin's Avatar
A pair of proper sized screwdrivers should fit snug into those 'slots', allowing you to squeeze the ring inward toward the center and pop it out.
Grind up some old junkers if you have to to make 'em fit.
If they're hacked already use a Dremel or hacksaw to cut into the retaining slot far enough to sever the rings, just far enough/no further, no major harm done. Refit with snap rings for future ease of maintenance.
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
