washer anti freeze in my tires - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 07-10-2019, 01:27 AM Thread Starter
oldfart50's Avatar
Anyone have a easy method to remove it..My XT3 I bought used low hrs seems the guy put washer anti freeze in the rear tires .Dang thing beat me up mowing so bad I went to ck the tire pressure and anti freeze came out the end of my tire gauge . Was thinking with the stem at 6 '0 clock and guts removed will the air force most out .want to get out all i can before i take them to get broke down and wiped dry . ~~oldguy ~~ No wonder it rode like flintstone wheels
oldfart50 is offline
post #2 of 7 Old 07-10-2019, 02:52 AM
Re: washer anti freeze in my tires
remove air so the tire isn't pressurized, then break the bead loose from the rim and flip the tire over, might need to wedge a screwdriver in the bead to hold it open for the fluid to come out. I would think this will get most of it out.
dave_r is online now
post #3 of 7 Old 07-10-2019, 07:54 AM
An EASY WAY??? Sure, take the tyre to a tyre shop and have them do it. Don't tell them beforehand and video it.
Remove the valve from the stem. Set tyre where lowest point is the stem and allow to drain, may take several hours. Could try using a small transfer pump the same way it may have been filled. then break the bead to remove most of the rest.
Flaken is offline
post #4 of 7 Old 07-10-2019, 07:50 PM
Are you removing it just to make it ride smoother?
If so, why not just remove about 1/2 of it and leave the rest in. It should help provide traction and it should ride very similar to unfilled tires at 1/2 full.
To do that I would jack the rear of the tractor up and rotate the tire to where the valve stem is at the mid point on the tire. It will drain slow, may take a couple hours, but it will drain.
Joelk is offline
post #5 of 7 Old 07-10-2019, 08:16 PM Thread Starter
oldfart50's Avatar
yeah my back trashed and it rides like Flintstone wheels , I was figuring on rotating the stem to the 6 0' clock taking out the stem value and let the air pressure push it out / Don't need the extra weight for mowing have a 700 twin Polaris for my plowing. once I get most out i'll have them broke down and wiped dry so not to rust ~~oldguy
post #6 of 7 Old 07-11-2019, 07:49 AM
20,000 Posts & Climbing
Jack the back end up, position the valve as you stated, lower the jack, and sit in the seat until it quits draining. Jack it up and turn the tire for the valve to be above the fluid level to let air in, then do the above procedure again.
It will take about 3 or 4 cycles as above to get it to minimum. Then it can be broken down to finish.
Personally, I would leave the last bit in for the traction on wet grass and the stability for doing the ditches. The air chamber should be large enough for a comfortable ride.
TUDOR is online now
post #7 of 7 Old 07-11-2019, 11:25 AM Thread Starter
oldfart50's Avatar
yea i got one of those air chucks like they use to pop the bead out I can hit it with air with the guts out of the stem ~~oldguy ~
