Cub 1864 Restore for Garden Duty - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 05-24-2019, 07:55 PM Thread Starter
B440's Avatar
I picked up an 1864 recently from FB Marketplace. The description didn't mention the model, but I spied this from the pic. (This is my pic. Seller's pic was from far away and hard to see.)
Power steering! Which I do not have for any of my current machines. I picked it up in the middle of a rainstorm, with no front wheels, just as you see it. The 54" deck had to be removed first. and we winched it onto the trailer.
The seller said the engine would run.... but you know how that goes. It's a Kohler Command V-twin. When I got some free time, I put some oil in, hooked up the charger/starter, and fired some starter fluid down the carburetor. It ran! He wasn't kidding.
So the next day I went to the mower repair/boneyard and they just happen to have an 1862 or 3 with everything but the engine. I bought the front wheels and bolts.
I got it running well enough to go for a ride. I think the fuel in the tank was bad. I changed out the oil and filter. and drove around the yard. Love it!
Now on to the issues:
1.) Reverse wasn't very fast and it failed my test hill going up in reverse. There was hardly any oil in the transaxle. I added a quart and it brought it to the Low mark. Not sure if it is leaking?
2.) The lever for hydraulic deck up/down seemed to be frozen, but I gave it a little tappa-tappa from the back side and it works now.
3.) It is a filthy, oily mess! The engine leaks oil just sitting there. It peed on my garage floor and I had to lay down rags.
4.) The hood mounts are broken. Here are two pics of it just kind of sitting on there.
So I need to pull the engine and find the leak, or leaks. Then investigate changing the transaxle oil and fixing slow reverse. If I'm successful with everything I want to do, then this tractor will replace my John Deere 212 which has full-time garden duty.
B440 is online now
post #2 of 11 Old 05-24-2019, 08:20 PM Thread Starter
B440's Avatar
Re: Cub 1864 Restore for Garden Duty
The 1864 needs a plow to replace the 212, and I was having trouble finding something that would fit. Now a 1440 pops up for sale, with a plow, so that appeared to be a no-brainer. It also came with a 42" deck, but no pic of that.
This one has a 14hp Briggs Vanguard. Seller said it ran when using a gravity-fuel tank. He also said not to fill the original tank because the petcock seals were leaking. I noted these issues and proceeded to fire up the engine. It ran on starter fluid but not the gravity tank that I added. I did notice this strange wire not connected to anything.
It appeared to be going to the anti-backfire solenoid on the carb. I tried putting power to it but heard no click from the ABS. Just for fun I unscrewed the ABS just a little (fuel was leaking out), and then cranked the engine; it ran! I drove it around for a bit. Forward and reverse worked great. Steering was a little stiff compared to the 1864 but I guess that's to be expected
So I stopped there and pulled the engine and cleaned it. The valve covers had been leaking oil for quite some time. I resealed the valve covers with Threebond.
The hood is marginally better than the 1864. The mounts aren't broken, but there has been many repairs done to the inner structure. I guess it will become a donor for parts. I will say that if I had bought the 1440 first, it would also replace the JD 212. Here is what it looks like currently.
I'm thinking the Vanguard engine will go in the 1864 while I find the leaks on the Kohler.
B440 is online now
post #3 of 11 Old 05-24-2019, 08:43 PM Thread Starter
B440's Avatar
Here is the greasy, oily mess of an 1864.
Shot of the Kohler engine before cleaning.
Found a missing exhaust stud
After cleaning. I only used an electric low-power washer. Some of the oil is baked on and may require scrubbin' to remove.
It was much dirtier before. Hmm, I see a clue?
Closer inspection. Case bolt. I can turn it in either direction by hand.
So I'm wondering if the case gasket is the only leak? It would certainly be the reason oil leaks while the tractor sits. I'm definitely going to run the Vanguard while I fix all the issues on the Kohler.
I pulled the tractor out and power washed it. I thought I was done until I removed the panel covering the cooling fan.
There was oil on everything in there. The fan was black. The filter was black. So much oil! Mostly clean now.
Since I had gone this far, I removed the fender and fuel tank.
I did notice sloppy white RTV at the joints of the transaxle, so I suspect someone has opened it before. Well at least it is clean now and I will be able to see the potential leaks better.
Does anyone know if I could use this output shaft for a PTO? I would love to have a 3-point hitch and PTO.
A few questions; Is this the plug to use for draining the hydrostatic fluid? Can I use 5W-50 synthetic to refill? How many quarts? And what is the filter number?
B440 is online now
post #4 of 11 Old 05-25-2019, 05:10 AM
Cannon51's Avatar
I used a Wix 51410 n my 1863 transaxle and a Stens 120-265 on my 1641. There is a list of recommended filters here. Removing the filter will drain the pump and differential or remove the rear cover. https://www.onlycubcadets.net/forum/...ghlight=filter
I used this "Meets the Requirements of" fluid in my transmission https://www.tractorsupply.com/tsc/pr...d?cm_vc=IOPDP1
I've had to clean the fuel tank petcocks on both mine, there in the bottom of the tank and get clogged up sometimes.
The nose piece of the hood is broken on both of mine, I've patched them up with limited success.
Cannon
Name:	cub 1863 032.JPG
Cannon51 is offline
post #5 of 11 Old 05-25-2019, 09:57 PM
Tech Exchange Moderator
Sergeant's Avatar
Well MTD didn't set Up this tractor to run a rear PTO only Cat 0 3point Hitch. You would Have to Look at How MTD ran the Supers Garden tractors rear 2000RPM PTO Kit Because I Know the Supers used the same Transmission That was Found In the standard Garden tractor which you have But MTD Never Intended the Standard Garden tractor to run a Rear PTO They Made a 8HP 3 point Mounted Tiller for the 1864
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
MSGT 11 & 18 Series Retired
Sergeant is online now
post #6 of 11 Old 05-26-2019, 06:44 PM Thread Starter
B440's Avatar
I was trying to figure out how to operate the plow using the hydraulic deck control when the 1440 hooks the plow up to the lever.
On the 1864 there's this thing which I thought was plastic and only there to show the deck height.
I flipped it around and realized it's steel and could be used for plow actuation. I'll have to figure the rest out later. Must do engine work first.
Something I noticed about the Kohler; The engine mount bolts are larger and in a different location from the Briggs. Kohler shown below.
Briggs bolts on the 1440.
So The whole mounting plate had to be removed to get the front bolts out. Ugh, more oily mess.
The Vanguard engine needs a diode on each coil kill wire so they can't interfere with each other. I had to remake my harness. The original harness was completely busted.
Much better. I'm trying to sort out any wiring issues before everything goes back together. It's much easier to access stuff when the engine is out of the tractor.
I also replaced the battery terminals. They were pretty beat up and not making good connections.
Here is something I've wanted to do for all my tractors. Critter-proofing.
Both engines have seen problems with mice nests. I'm hoping this prevents any future problems. It's much harder to remove the cooling shroud on a horizontal engine vs. a vertical.
The cooling shroud is back on and I just need to install the exhaust heat shields. Then the engine can go back in. That's as much as I felt like doing today.
B440 is online now
post #7 of 11 Old 05-27-2019, 12:50 AM
Cat385B's Avatar
Good idea on rodent proofing, I like that.
Cat385B is online now
post #8 of 11 Old 06-04-2019, 08:13 PM Thread Starter
B440's Avatar
Got the oil changed.
7 quarts and a filter.
I placed the engine on the frame and realized the driveshaft was too short. I needed to pull the 1440 driveshaft and swap.
This is where I left off last night.
Today I finally tackled the last electrical connections.
I connected the kill wire, fuel solenoid power, and the alternator. The other two are taped off for now. I'll hook them up some other time.
I tried to start the engine and no-go. Two problems; the pulse line for the fuel pump was cracked, and the fuel solenoid is junk. I fiddled with it and thought I had it fixed, but I finally ended up cutting the plunger.
It starts, runs, and is clean enough to see leaks, which I found. How much work is it to fix this? It appears to be coming from the seal at the top of the steering.
Also, how do I make reverse faster? I was in full reverse (so slow) and pushed on the spring and it went faster! Any tricks to this? Do I need a different plate as shown below?
B440 is online now
post #9 of 11 Old 06-18-2019, 04:21 PM
Hello, I also have an 1864 that was given to me. It has engine problems,( I think it was run without oil). I picked up another moter, but I haven't started working on it yet. I have only ever had Craftsman riders, so the Cub Cadet is new to me, and it seems like it is more heavy duty, but I know nothing about them. I have been trying tp locate a service manual, but have not found any yet. I seem to keep hitting road blocks when I try searching.
I just read over what you have been doing with yours, but the last that I found was from 6/4/2019. I'd be interested in following your progress. You also seem to be lucky, having a mower scrap yard at your disposal. I haven't found any ot them here in Pa.
on this tracter that I got, it seems like there is no power to the starter. I jumped the starter, and used starting fluid to see what I got. It started, but it popped a little and I shut it down. I did find two white wires coming out from the motor that are cut and I can't find any place for them to go. One of the things I was told was that when ever they went to use it, they had to jump the starter, and it never seemed to charge the battery, making me think that the white wires have something to do with that.I've taken up enough of your time, so I will wait and watch for your next posts!
racerdon08 is offline
post #10 of 11 Old 06-18-2019, 05:07 PM Thread Starter
B440's Avatar
Put your model and serial in here PDF Manual Web Archive
It should have a wiring diagram. The wires are color-coded. White may be the kill wire, but check and confirm.
B440 is online now
post #11 of 11 Old 06-19-2019, 05:44 AM
Cannon51's Avatar
The 2 white wires are probably the stator but there are other white wires on some of the engines. The wires on my index finger are from the stator and go to the outside pins of the voltage regulator. I believe this link http://www.kohlerengines.com/engines..._24_690_06.pdf will take you to a place to download the PDF engine manual.
Cannon
Cannon51 is offline
XT3 GSX My New Cub Sergeant Cub Cadet Forum 48 01-03-2019 03:42 AM
FS: Cub Cadet SLT1554 lawn tractor (MI) zuren For Sale & Wanted to Buy (Your Location) 0 10-28-2018 02:42 PM
Help with JD Rear Work Light Installation, 4 Series w/ Cab mwnitz John Deere 2 08-25-2018 10:02 AM
Cub 3pt...hydro demand? Talntedmrgreen Cub Cadet Forum 6 11-28-2012 11:36 AM
Cub 73 good for light work? Diesel332 Cub Cadet Forum 7 11-25-2012 02:02 PM
