3165 Briggs trouble - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 04-20-2019, 10:55 PM Thread Starter
cubcadet3240's Avatar
3165 Briggs trouble
I have 3165 with a Briggs 18hp that is blowing oil out of the carb and filling air filter with oil! Changed breather hoping that would fix it but it did not! I have been told could be a head gasket among other thing just looking for your input on my next move or parting it out.
Thanks in advance
Jamie
Cub Cadet 3225,3165,3240,xt1 in my stable
cubcadet3240 is offline
post #2 of 11 Old 04-21-2019, 03:47 AM
Re: 3165 Briggs trouble
First thing is check the oil for presence of gas. Smell it. Is is overfilled or thinned out?
Is this an 18 single cyl ohv?? If so the head gasket will eventually fail but it will become mosquito fogger for a few seconds and then clear up and repeat- mostly on hills or angle.
I test them by getting up to temp and going in 4 tight circles to the right the 4 to the left....this will usually trigger a house hiding cloud of smoke!
TobyU is offline
post #3 of 11 Old 04-21-2019, 09:44 PM Thread Starter
Thanks for your input I will give that a try and see what kind of outcome I get!
Thanks
Jamie
post #4 of 11 Old 04-21-2019, 09:46 PM
Steve Urquell's Avatar
Check to make sure your choke is opening all the way. My wife ran my 22hp Kohler with it closed one day I was at work and it dumped gas in the oil and blew oil and gas out the exhaust.
Steve Urquell is online now
post #5 of 11 Old 04-21-2019, 10:03 PM
Mudyapster's Avatar
Good idea on the choke being stuck closed. Rhonda had the choke on the XT3GSX and couldn't figure out what she was doing wrong. Woman driver!
JD 5083E Limited 4X4
2018 Cub Cudet XT3 GSX 60" Fab deck
Mudyapster is online now
post #6 of 11 Old 04-22-2019, 02:06 AM
How exactly does having the choke on "dump gas in the oil"?
dave_r is offline
post #7 of 11 Old 04-22-2019, 06:58 AM
Not enough air to mix with the fuel to burn it. Washed down the cylinder walls into the oil. I did not start it when I saw the mess and smelled the gas in the oil. Right plug was saturated and appeared to not be firing. My crankase was full of gas and muffler blew a mess of carbon/gas everywhere.
I changed the oil and filter and cleaned the plugs and it started right up. No apparent damage.
post #8 of 11 Old 04-22-2019, 10:12 AM
Having the choke on won't put any gas into the oil. If gas gets in the oil it is the carburetor needle and seat not shutting off properly or on some that have a fuel pump the fuel pump is defective and letting gas get into the crankcase. You will get a richer mixture and can wash off some of the oil off the piston rings and cylinder walls but on a lawnmower engine it's not going to do any long-term harm and you won't get a noticeable fuel anywhere else. It's not like the choke can actually pull liquid gas into the cylinder because it gets a rich mixture and dies quickly. Even if it's just running with the choke full-on but still managing to chug, it will blow out lots of black smoke and run rich but since the engine is still running it will all come out the exhaust on every exhaust stroke.
TobyU is offline
Old 04-22-2019, 12:56 PM
Steve Urquell
This message has been deleted by Steve Urquell.
post #9 of 11 Old 04-22-2019, 01:06 PM
He is saying running with the choke closed did not cause the problem. Read his post again
RoyM is offline
post #10 of 11 Old 04-22-2019, 01:27 PM
It did in my case as I've not had gas in the oil since. I deleted my post as I'm grouchy today. Peace and out.
post #11 of 11 Old 04-22-2019, 07:28 PM
Senior MTF Poster
Bad carb float needle, replace it and add an inline gas shut off valve and use it.
Walt Conner
Walt 2002 is online now
Briggs & Stratton Recalls Portable Generator Fuel Tank Replacement Caps JP Savage Generators 1 10-11-2018 09:14 PM
Briggs & Stratton Recalls Riding Mowers Due to Risk of Injury JP Savage Backyard Round Table - L & G Tractor Related Topics 6 03-23-2018 02:40 PM
Briggs 14.5 OHV I/C Stator Wiring Question Edmckna Small Engines and Repair 19 03-14-2018 10:04 PM
850 Briggs on a Toro Commercial 21 solidstate21 Walk Behind Mowers 2 11-15-2017 10:45 PM
Cub 3185 wiring with Briggs engine herbiegrizz Cub Cadet Forum 41 12-16-2012 12:03 PM
