Boy Mekkanix vs The Electrix Lyft Sleeve Hitch. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 40 Old 03-12-2019, 08:39 AM Thread Starter
(The names have been changed to ... , never mind).
Round 3
If you've never seen one of these - tada:
ChuckT is online now
post #2 of 40 Old 03-12-2019, 08:41 AM Thread Starter
Re: Boy Mekkanix vs The Electrix Lyft Sleeve Hitch.
Laid out in pieces.
post #3 of 40 Old 03-12-2019, 02:12 PM Thread Starter
I have read better instruction but I think this is how the horizontal straps are supposed to fit:
ID:	2366187   Click image for larger version
post #4 of 40 Old 03-12-2019, 02:15 PM Thread Starter
However I did a bit of backyard engineering and came up with this:
ID:	2366191   Click image for larger version
ID:	2366193   Click image for larger version
post #5 of 40 Old 03-12-2019, 02:27 PM Thread Starter
From the left & counter clockwise - the vertical piece of 3/4 ply is a spacer I used for alignment, The black strap is the supplied piece (didn't like it), the MDF was made to fill the frame rails, then I made 2 blanks from 1/4 plywood and drilled one for the bolt spacing. My XT3's frame rails has both of the 3/4" holes bur because the Sleeve Hitch frame is just a touch bigger, left to right width, then the back-step I will probably only use only the first bolt.
post #6 of 40 Old 03-12-2019, 02:36 PM Thread Starter
Laid out in the background and then the foreground is the 3x36x3/16 strap to replace the supplied pieces. I'll need to shorten the bolts (they are 3/4 x 3") and the flat washers are to fit inside the frame rails as spacers.
Next - the tractor rails to show my configuration versus the supplied components
ID:	2366199   Click image for larger version
ID:	2366201   Click image for larger version
post #7 of 40 Old 03-12-2019, 09:50 PM
No Quarter's Avatar
Look forward to seeing it installed.
1946 Gibson Model A w/WI 5.9hp
1984 John Deere 318 w/Onan 18hp
1989 John Deere 420 w/Onan 20hp (2)
1990 Craftsman GT6000 w/Briggs 18hp (2)
No Quarter is offline
post #8 of 40 Old 03-13-2019, 01:11 PM Thread Starter
XT3 left side with wheel removed. Both rear frame rails have two 3/4" holes. Ill use them.
post #9 of 40 Old 03-13-2019, 01:18 PM Thread Starter
The supplied side strap won't align to my satisfaction.
post #10 of 40 Old 03-13-2019, 05:36 PM Thread Starter
In that position, nor this.
post #11 of 40 Old 03-13-2019, 05:42 PM Thread Starter
I think my plywood mock-up strap is a better idea, with two 3/4" & two 5/16" hex bolts to hold everything together.
Next - I need to cut and drill this 2" x 3/16" strap to fit instead of the mock-up.
ID:	2366297   Click image for larger version
post #12 of 40 Old 03-13-2019, 06:52 PM
Steve Urquell's Avatar
Looks like you're getting things handled. Sorry it doesn't fit well. I can see now why Sergeant bought the factory hitch and added an actuator.
Steve Urquell is offline
post #13 of 40 Old 03-13-2019, 08:43 PM Thread Starter
Yes I've got to agree.
So long as I don't get in over my head, dealing with challenges is fun (andAnd I can be a bit of a masochist). It helps that this install is nearly identical to the same thing I bought and installed on a Craftsman GT 15 years ago.
But an end user shouldn't have to put out this much effort for a "made to fit" item.
post #14 of 40 Old 03-13-2019, 10:09 PM
When I saw your pics I said out loud "Da.. Thats a LOT of holes."
I fitted a manual sleeve hitch (dont know what it fit) I got in a trade to my 3240 and I had to deal with the hitch to frame channel arms like you are.
I marked where the 3/4" holes go thru, hole sawed the arms to 1 1/8" and welded small pieces of 3/4" ID pipe in place which fit inside the channel. 3/4" pins thru the frame. Made for a clean install.
post #15 of 40 Old 03-14-2019, 08:35 PM Thread Starter
That looks good.
Husqvarna TS348XD sleeve hitch and attachment options? Chopper Moon Husqvarna/Dixon 9 05-19-2019 10:47 AM
Built a Winch Lift Receiver Sleeve Hitch for my XT3 Steve Urquell Cub Cadet Forum 44 11-27-2018 05:42 PM
help decide: build a 3 point or sleeve hitch? Great white Backyard Round Table - L & G Tractor Related Topics 9 10-31-2018 08:39 PM
SLeeve hitch to CAT 0 attachments? yardsale Lawn and Garden Tractor Accessories 3 02-18-2013 05:22 PM
reverse sleeve hitch??? yardiron Lawn and Garden Tractor Accessories 2 02-08-2013 09:42 PM
