-   Cub Cadet Forum (https://www.mytractorforum.com/19-cub-cadet-forum/)
-   -   XT3GSX Frame Flex (https://www.mytractorforum.com/19-cub-cadet-forum/1316995-xt3gsx-frame-flex.html)
Mudyapster 01-09-2019 04:00 AM
132 Attachment(s)
Have any of you with the XT3 noticed the frame flex? I can feel the frame flexing while sitting in my seat. Its almost like there are some frame bolts loose and when I go over uneven ground the frame is flexing in the rear. Is this normal flex or do I have something going on with the frame. I checked for loose bolts but haven't found any. Maybe I need to look harder for loose frame bolts. It seems to be excessive I'm wondering if MTD went cheap on the 2018 XT3 frame on mine. Heck it even makes a creaking sound when the frame flexes which it flexes all the time while I'm driving over the least uneven ground. Wondering if it has a flimsy thin frame that's not heavy duty enough for the weight of this machine.
Any thoughts anyone.
Steve Urquell 01-09-2019 06:53 AM
Re: XT3GSX Frame Flex
I haven't noticed mine doing it but I did find I had a missing seat slide track bolt yesterday. Cub uses a stout frame on these with a 5 year warranty. Maybe have Rhonda drive it around with the engine idle set low and listen to find where it's creaking. I'll get on mine today and see if it's doing the same.
Check your seat track bolts.
Mudyapster 01-09-2019 07:55 AM
I haven't looked at the seat track I'll look at that after work today. Thanks
Mudyapster 01-10-2019 07:22 AM
Well I checked the seat track all bolts are there and tight. Looked under the fenders on the frame nothing loose under there either. I could find a bolt loose anywhere. Oh well guess it's normal flex I feel. The 60" Fab mower deck is heavy so maybe that's the thing. 50.4 hrs on it and going to just roll with it. Won't be long till 1st mowing this year I already have weeds growing 3 plus inches tall. Nothing like South East Texas growing season.
On a side note I think I found a place to mount my 2/4x4 LED light bars on front without drilling a hole. Going to make a L shape bracket to mount them on and see if the clear the tires when turning.
Steve Urquell 01-10-2019 07:54 AM
I bet that 60" deck is >200lbs easy. My 54" fab is a bear to drag out. Crazy you have anything growing right now. We're in dormant season till April here. 26 degrees right now.
Show some pics of your light install. Very interested in how this works out.
Mudyapster 01-10-2019 08:09 AM
132 Attachment(s)
In February here it always hits 85 to 90 for a week. Been in the mid 70s here till yesterday it cooled off to 59. This morning its 38 and today's high forecast is 59 again. I need to put out some pre-emergant and then fertilize. We only get about a 2 month break from mowing here. About the time the leaves fall off my fruit trees they start budding again. I already see some buds on my Fig tree.
I'll be posting pics of my green grass before yours starts growing. LOL
oefveteran 01-10-2019 07:37 PM
I feel a mild bit of flex at times when snow blowing, but that's about it. I'm a big man, 6'5" and 400 pounds, if the frame was going to flex for anyone it would be me. Lol.
Mudyapster 01-11-2019 07:22 AM
LOL
I'm 180# and my dog that rides with me is 12#, my ice chest of brew is about 15#. I can't find anything loose to make it flex like it does all bolts are tight.
Steve Urquell 01-11-2019 07:40 AM
LOL
You have me wondering now. Mine feels really solid. I'd get on it but it's nasty right now. Rain/sleeting.
Ray2 01-12-2019 10:30 AM
some frame flex is acceptable...everything that moves from one point to another will flex.....too rigid and it would shake itself apart......might be called force dampening ?
Mudyapster 01-12-2019 10:40 AM
Sounds good to me. I'm just going to keep driving the snot out of it.
17xt3 01-12-2019 01:23 PM
Mine flexes a good bit as well on uneven terrain. It concerned me a bit at first but no issues in 2.5 years.
Mudyapster 01-12-2019 05:04 PM
That's good to hear, thanks for the feed back. I just drove mine to the front gate about 1/2 mile round trip. Let it flex!!!!
ejl6658 01-13-2019 08:57 AM
Mudy, feeling the frame flex on your xt3 would be a concern. Looking at the front axle I see two bolts (item#2) that would appear to limit the pivot of your front axle which older 3000 series models do not have. Are you seeing that all four wheels are not in contact with the ground when driving on uneven terrain, particularly a front wheel up off the ground due to limited pivot caused by those two bolts.
https://www.partstree.com/parts/cub-...y-1-inch-axle/
Mudyapster 01-13-2019 09:07 AM
134 Attachment(s)
No all tires are on the ground. I did adjust the front pivot joint bolts a little. These bolts to tight and I got more frame flex, then I loosened them back up and resulted in less frame flex. I probably have the front pivot bolts to loose right now, but have less frame flex with them pretty loose. I'll add If you have the pivot bolts to loose then you get front wheel wonder so I don't have them so loose to get wheel wonder. They are loose enough to let the pivot do it job but not to loose. I'm going to put a wrench on my seat bolts even though they don't appear loose.
