Xt1.2 - Page 6 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #76 of 90 Old 04-27-2019, 08:48 PM
Tech Exchange Moderator
Sergeant's Avatar
Re: Xt1.2
Originally Posted by Steve Urquell View Post
Cool. Make sure you have plenty of expansion space for the oil tank. The K61 in my wheelhorse had about a pint sized reservoir with a cold fill line about 1/2" up from the bottom. It'd get hot and expand enough to overfill it and it would barf oil down the sides.
I think the sleeve hitch I mounted on my 3240 was for an MTD or Craftsman and it was a pretty close fit.
The sleeve Hitch for Both MTD Brands & MTD Made Craftsman or HOP Made Craftsman are Made By Agri-Fab The very similar in design if Not the same if it's a MTD Made Craftsman Garden tractor https://www.sears.com/craftsman-pro-...01614630402517 Because all of the Current Craftsman Made Garden Tractors are XT1 or XT2 Garden tractors Painted black
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
MSGT 11 & 18 Series Retired
Sergeant is offline
post #77 of 90 Old 04-27-2019, 09:15 PM
Steve Urquell's Avatar
Originally Posted by Sergeant View Post
The sleeve Hitch for Both MTD Brands & MTD Made Craftsman or HOP Made Craftsman are Made By Agri-Fab The very similar in design if Not the same if it's a MTD Made Craftsman Garden tractor https://www.sears.com/craftsman-pro-...01614630402517 Because all of the Current Craftsman Made Garden Tractors are XT1 or XT2 Garden tractors Painted black <img src="https://www.mytractorforum.com/images/smilies/thThumbsUp.gif" border="0" alt="" title="ThThumbsUp" class="inlineimg" />
Mine is quite a bit older than the current line of sleeve hitches. It has a row of 8 or so 1/2" threaded holes along the hitch. I found it in some partstree parts lists awhile ago.
2001 Cub 3240 with fabbed hydraulic sleeve hitch and Swisher Hydraulic Front Bucket
Steve Urquell is online now
post #78 of 90 Old 04-28-2019, 10:29 AM
Sergeant's Avatar
Re: Xt1.2
The MTD sleeve Hitch You Have Looks Like the Old fast attach mixed with the even Older standard MTD sleeve Hitch That just connected to a Rod that ran through the Back of the tractor Then Up to the Lift arm on MTD tractor That had a Mid Lift arm on the right side My MTD Made Wards Had that style without the Back Plate
White Model: GT2055
Sergeant is offline
post #79 of 90 Old 04-28-2019, 10:45 AM
Re: Xt1.2
I have no idea how (or if) this was usable in the condition I got it in as nothing hooked the hitch to the lift plate arm. It was free with my Agri-FAIL Agri-fab box blade purchase so I have ~$0 in it. It's now been repurposed as a hydraulic hitch on my 3240.
ID:	2374167   Click image for larger version
post #80 of 90 Old 04-28-2019, 11:48 AM
Sergeant's Avatar
Re: Xt1.2
Yeah that is actually two different sleeve Hitches the Old and the Fast attach Mixed The Old Hitch section is actual a True MTD Made Part The Fast attach section with lift lever is a Agri-Fab Made Part
White Model: GT2055
Sergeant is offline
post #81 of 90 Old 05-25-2019, 07:17 AM Thread Starter
Abryant2004's Avatar
He is an update on the xt1.2 I swapped out the K61 for a k65 from a simplicity I also am using the clutch and a break assembly from the simplicity. I added a under the seat gas tank from a deere. Now for the dash the upper I made a custom fiberglass she'll that shaved the gas tank hole I used a battery tray and shelf from a Husqvarna, and a tilt steering assembly from a Toro wheel horse. The neck around the steering shaft is a modified xt3 one and I'm using a aluminum steering box from an xt3. Front axel is spindles and drag links are from a newer Craftsman. I just needed to extent the drag links a little. Lastly added a electric PTO from a craftsman
ID:	2378055   Click image for larger version
Abryant2004 is offline
post #82 of 90 Old 05-25-2019, 09:06 PM
That Guy
oefveteran's Avatar
Re: Xt1.2
Man, you built your own garden tractor, that's **** cool.
Cub Cadet XT3 GSX
John Deere 10P Yard Cart
oefveteran is offline
post #83 of 90 Old 05-26-2019, 10:43 PM Thread Starter
Thanks bro
post #84 of 90 Old 06-06-2019, 01:54 AM Thread Starter
Here are some new pics
ID:	2380351   Click image for larger version
ID:	2380353   Click image for larger version
post #85 of 90 Old 06-06-2019, 01:56 AM Thread Starter
Few more
ID:	2380357   Click image for larger version
ID:	2380359   Click image for larger version
post #86 of 90 Old 06-07-2019, 10:45 PM Thread Starter
Well I didn't like how loose the steering was so now working on a cub gt and jd combo set up
post #87 of 90 Old 06-08-2019, 02:54 AM
That Guy
oefveteran's Avatar
Good to see you're still at it!
Cub Cadet XT3 GSX
post #88 of 90 Old 06-10-2019, 12:13 AM Thread Starter
The John Deere tilt works a lot better now I'm trying to decide if I want to try and cut up the JD dash and fiberglass it to my dash or just order an xt3 dash which I think I could make work
post #89 of 90 Old 06-12-2019, 05:57 PM Thread Starter
Think she is about done
ID:	2381505   Click image for larger version
post #90 of 90 Old 06-12-2019, 06:16 PM
That Guy
oefveteran's Avatar
Re: Xt1.2
That thing is cool.
Cub Cadet XT3 GSX
