LT1045 w/20HP Kohler Hard Starting - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 37 Old 06-30-2018, 11:44 PM
guyina4x4
guyina4x4's Avatar
Re: LT1045 w/20HP Kohler Hard Starting
I replaced the pump on my 2084 last fall, started great the few times I used it till it got cold and the first time I went to blow snow.
second time it wouldn't start at all and was hard to start all winter and spring and into the summer.
well it finally quit starting all together again about a month ago
I took a used pump off a spare motor I have and swapped them out, has started great ever since.
lesson? new doesn't mean better
Yanmar YM155D
Cub Cadet 2084
Cub Cadet 2185
guyina4x4 is offline
post #17 of 37 Old 07-01-2018, 03:11 AM
Yeah, the fuel pump on my Kohler CV22 also failed last winter, but the fuel tank is above the carb, so it still worked after I bypassed the pump and plugged the line to the crankcase. I think it failed because some fluid (either oil or perhaps even water condensing from the air) got into it either from the crankcase line or the little vent on the outside of it.
I'm hoping the new fuel pump I bought, which seems to have a slightly different design, works this winter.
dave_r is online now
post #18 of 37 Old 07-01-2018, 09:05 AM
Originally Posted by Pepperpikker View Post
Any other suggestions would be welcome. I am hoping I don't have to deal with the carburetor at all.
Always helpful to have the Kohler service manuals on hand. You can find yours on this thread here:
https://www.mytractorforum.com/19-cu...e-manuals.html
Also, check to make sure the fuel shut off solenoid on the top rear of the carb is working correctly. Over time, this tends to get gummed up where it doesn't work just right. Many a people tear their hair out overlooking this little item. I know, I was one!
Flaken is offline
post #19 of 37 Old 07-13-2018, 12:26 AM
paoldschool's Avatar
It really sounds like the carb could use a good cleaning. Small carbs hate dirt, and no matter how careful you are some always get in...
2005 Massey Ferguson GC 2310 TLB
1990 Craftsman II GT6000
paoldschool is offline
post #20 of 37 Old 03-23-2019, 07:05 PM Thread Starter
When you say "carb cleaning" do you mean simply spraying some carb cleaner in it or pulling it off the motor and cleaning it?
2008 Cub Cadet LT 1045
Manufacture date: 2/20/2008
Kohler 20 HP single cyl. Twin cam OVH
Model SV600S
Spec No: SV600-0009
Pepperpikker is offline
post #21 of 37 Old 03-25-2019, 03:23 PM Thread Starter
To close this thread out, I found the solution to the hard starting. The fuel cutoff solenoid was bad. I replaced it with an aftermarket solenoid for $10.50 and it starts great again.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks to everyone that lent me their knowledge and experience. I am just glad to have my rider back in good working order.
Bruce
Model SV600S
Spec No: SV600-0009
post #22 of 37 Old 03-26-2019, 02:39 AM
thanks for posting your fix.
post #23 of 37 Old 03-26-2019, 09:23 AM Thread Starter
Yah, I am on a couple of similar forums and I always hate it when people drop in, ask for all kinds of help and then never post back the outcome. So, I try to do so whenever I ask for suggestions. I hope the next guy can get his problem fixed without replacing all the parts I did and having to deal with the problem for two years.
Model SV600S
Spec No: SV600-0009
post #24 of 37 Old 03-26-2019, 10:15 AM
Sorry I'm late to the party......just found this thread.
I had the same tractor with the same problem and a new solinoid fixed it.
Sorry I didn't find the thread sooner, but glad you got it fixed.
Gregg
2015 XT2 LX46 (Fab)
Rangerhgm is offline
post #25 of 37 Old 03-26-2019, 10:21 AM Thread Starter
Ranger, yah, I wish you had as well. AFter two years of messing with everything else and replacing good parts, I wish I would have found the solution a long time ago. But all is well now and I am happpppyyyyy.
Glad you got your tractor fixed too. BTW: How do you winterize your mower at the end of the season?
Model SV600S
Spec No: SV600-0009
post #26 of 37 Old 06-18-2019, 01:19 PM
I wanted to start new post, but can't figure out how. We had these issues, but also had more. How do I go about that?
Julia A. Harding is offline
post #27 of 37 Old 06-18-2019, 02:24 PM
Retired & lovin it!
Newsman's Avatar
To post a question, go to the forum, in this case the Cub Cadet forum where you are and click on the button on upper left hand side of the page just below the header that says Post New Thread. Click on the button, fill out your question / or statement then scroll down and click Submit New Thread.
MikeC
Newsman is offline
post #28 of 37 Old 06-19-2019, 09:12 AM
I've been hacksawing off the plunger on any bad fuel shutoff solinoids.....never sticks again!
Cranman is offline
post #29 of 37 Old 07-15-2019, 06:28 PM
I have one, and it's been worked on by a pretty good small engine guy... it starts right up. BUT if I have the filter on and in place and engage the blade, it immediately bogs down and stalls. If I remove the filter, no problem. Any chance the solenoid could do THAT?
Michael Smith is offline
post #30 of 37 Old 07-15-2019, 07:14 PM Thread Starter
My guess is no, but I would try a new (different) filter. The solenoid would only restrict fuel flow.
Model SV600S
Spec No: SV600-0009
