Getting the 'ol 1254 going - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 144 Old 12-05-2014, 09:43 AM Thread Starter
Professional Amateur
gardentractornut's Avatar
Hi guys,
I guess I'm starting this thread to get some help here and there for my 1254. I bought a carb kit from tubeframes and soaked my carb on some berryman chem-dip. Just finished soaking yesterday. Sprayed everything out extensively with brake cleaner and carb cleaner. My problem is that I took the carb apart in like September, hoping that I could till the garden before snow. well, that never happened. So, being as I took the darn thing apart so long ago I can't remember where a couple of things went.
First of all, did I get this right? Are the plug and inlet in the right holes?
[IMG][/IMG]
Where do these go? The camera takes a bad dark picture, but one is a really small pin and the other is a tiny spring.
[IMG][/IMG]
Where does this go?
[IMG][/IMG]
More to come
Challenge Met
1971 Bolens 1254 w/ tiller, deck, blower, blade, sleeve hitch, 2 Brinly plows
https://www.mytractorforum.com/18-bol...254-going.html
1983 Snapper LT12
https://www.mytractorforum.com/15-sna...ml#post7673977
1987 Snapper LT16 w/ mower deck and snow blower
1997? Murray Ultra w/ mower deck and snow blower
gardentractornut is offline
post #2 of 144 Old 12-05-2014, 10:02 AM Thread Starter
Re: Getting the 'ol 1254 going
Is this plug in the right spot?
What do I set this screw at?
This one?
Challenge Met
1983 Snapper LT12
post #3 of 144 Old 12-05-2014, 10:04 AM Thread Starter
Also, if my regulator has rusted connections, will it work right? Or should I just buy a new one right away? What is the round thing with the plug wire coming out the top? Condenser? Coil? Should that be replaced also? I'm new to these older tractors as this is my first GT.
Thanks!
Challenge Met
1983 Snapper LT12
post #4 of 144 Old 12-05-2014, 01:40 PM Thread Starter
Oh yeah, does anybody know where I can get that fuel inlet to the carb? mine has a ton of crap in it and I figured that it would be best to get a new one.
Challenge Met
1983 Snapper LT12
post #5 of 144 Old 12-05-2014, 04:37 PM
Looks like the fuel inlet is in the wrong spot, supposed to go on the side not the end.
Have you tried any of these guys for parts?
http://gardentractortalk.com/forums/...site-sponsors/
tractorbob222 is offline
post #6 of 144 Old 12-05-2014, 07:22 PM Thread Starter
Thanks! that looks like a pretty good source for parts
Challenge Met
1983 Snapper LT12
post #7 of 144 Old 12-05-2014, 07:40 PM
29 Chev's Avatar
This may help with where things go and adjustments (see last page at top for adjustments).
29 Chev is offline
post #8 of 144 Old 12-08-2014, 11:34 AM Thread Starter
Thanks! That's just what I was looking for.
Yesterday I got a stack from TSC. I'll be making a bracket and pipe for that this week. Everything gets permanently mounted after the carb goes on. Does anybody know what those 2 small pieces are from???
Challenge Met
1983 Snapper LT12
post #9 of 144 Old 12-08-2014, 08:16 PM Thread Starter
Did a little bit out in the shop today.
Do the coil and regulator look like they are in working order? Will they get a connection with all that rust? Or will there still be some good under the rust? I should have taken a wire brush to them.
if not, would this coil work?
I found the manual for it. It looks like the original too! In near mint shape!
Next to an old weathered single page:
Also have what looks to be the original engine manual
Challenge Met
1983 Snapper LT12
post #10 of 144 Old 12-09-2014, 12:23 PM
Triumph66's Avatar
I got a Bolens 1254 myself. Would love to see some photos of your 1254. Thanks
1963 Bolens 800 with mower
1963 BOlens Ride a Matic with mower
1960s Bolens Lawn Keeper
1971 Bolens 1254
Howard Bolens rear reel mower attachment (PTO driven)
Haban Sickle Mow
Bolens Snow Plough
Bolens Tiller
Mowing Deck
Mold Board plough
Triumph66 is offline
post #11 of 144 Old 12-09-2014, 01:52 PM Thread Starter
I don't have many pictures of it, but here are a couple from yesterday:
Now, let's see some of yours!
Challenge Met
1983 Snapper LT12
post #12 of 144 Old 12-09-2014, 02:23 PM
Triumph66's Avatar
Great looking tractor the 1254. Yes I will post some photos of mine shortly. Cheers
1971 Bolens 1254
Haban Sickle Mow
Bolens Snow Plough
Bolens Tiller
Mowing Deck
Mold Board plough
post #13 of 144 Old 12-09-2014, 02:56 PM Thread Starter
Thanks! It'll look a lot better when I get it running and working...
Challenge Met
1983 Snapper LT12
post #14 of 144 Old 12-09-2014, 03:49 PM
Triumph66's Avatar
I, too, need to get mine up and running. It's missing a fuel tank and need a rewire too. This photo was taken when I took delivery of it; I have since washed it, pumped up the tyres, grease the suspension etc. for some reason it's up side down
1971 Bolens 1254
Haban Sickle Mow
Bolens Snow Plough
Bolens Tiller
Mowing Deck
Mold Board plough
post #15 of 144 Old 12-09-2014, 04:27 PM
I would sand the regulator terminals. For the coil, I would just go on EBay and buy a Beru coil, just search for "Volkswagen Type1 bus coil" and you will see a blue coil for around 30 dollars. Should be a direct replacement for yours, as I have one on my 1000.
Theo655 is offline
