eaton 11 whining - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 08-26-2018, 04:33 PM Thread Starter
Scott.O's Avatar
eaton 11 whining
here is a video of my Eaton 11 it is whining very loudly lately any ideas?it is from the housing spinning,is this normal?
here is a short video.
QT-17 48"deck, 6' utility dump trailer
Scott.O is offline
post #2 of 14 Old 08-26-2018, 05:40 PM
Re: eaton 11 whining
I would guess some thing is broke. Sounds like it needs oil. Is the input shaft turning not just the drive shaft ? They will make that noise if the input spline is stripped.
rjmartinny is offline
post #3 of 14 Old 08-26-2018, 06:04 PM Thread Starter
Scott.O's Avatar
thank you i will open it up and check..Scott
Scott.O is offline
post #4 of 14 Old 08-27-2018, 10:39 PM
Paulgo's Avatar
That doesn't sound good at all.
What part of Ontario?
Paul
Bolens HT23s-04, HT23, 1886-01, 1477, 1476, 1250, some miscellaneous GT's, and lots of attachments.
Paulgo is offline
post #5 of 14 Old 08-28-2018, 09:39 AM Thread Starter
Scott.O's Avatar
north of Toronto Paul .I plan to open it up next week and have a look.It still runs just fine and the noise subsides after about 10 minutes but it can't keep going for long...Scott
Scott.O is offline
post #6 of 14 Old 08-28-2018, 11:20 AM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
This may help if tou don't have one already......
.EATON 11 REPAIR MANUAL.pdf
Larry ( in Southern Ontario )
Larry LGT 165 is offline
post #7 of 14 Old 08-28-2018, 02:19 PM Thread Starter
Scott.O's Avatar
thanks Larry I have that pdf. i'm going to drain the Eaton and see if there is anything there.by the way are you using dextron 2 in your Eaton?
Scott.O is offline
post #8 of 14 Old 08-28-2018, 02:42 PM
Eatons are fantastic pumps and run equally well on ATF (red), Hydraulic oil (clear) or 20W motor oil (golden).
First thing I would be doing (after checking the fluid level and color) is replacing the filter as the contaminated fluid passes thru there before returning to the sump. (at least in the case of my Jake built Fords with Peerless transaxles.)
If the filter is a spin on, cut it open and see what's inside. (probably filled with silver paste) The bottom drain plug may also offer up larger pieces, and if the fluid is black, it's had a cooling problem.
post #9 of 14 Old 08-28-2018, 03:13 PM Thread Starter
Scott.O's Avatar
Larry the atf is clean and fluid level is spot on.the machine is working perfectly.I hope it might clear with a fluid change and filter. I will check the hoses as a collapsed hydro line could starve the unit..Scott
Scott.O is offline
post #10 of 14 Old 08-28-2018, 03:30 PM Thread Starter
Scott.O's Avatar
well I started up the old girl and no noise? now i'm really confused. will do the filter and oil change and see what happens...Scott
Scott.O is offline
post #11 of 14 Old 09-02-2018, 08:49 AM
I have three of these eaton-11 on H16XL and one did not whine then put different filter and oil in [Why?? LOL] that one and a whine started?? So got a good filter [no by-pass] and put 10w-30 shell Hydro static Fluid in it like my others and no more whine? So thats all I can add they been running good now on Hot days I run my loader with two speed rear for 4 hours and Temp in Trans is around 140 F.
62, Diesel Mechanic, John deere rebuild,Welder, Wood worker, All in All HAndy
Durfman is offline
post #12 of 14 Old 09-02-2018, 09:57 PM
Hey Scott. What oil did you end up using.
So north of TO. I’m near Tottenham.
Hydronerd is online now
post #13 of 14 Old 09-07-2018, 02:02 PM Thread Starter
Scott.O's Avatar
i'm out of town right now,will change the oil in a week or two..Scott
Scott.O is offline
post #14 of 14 Old 09-18-2018, 11:54 PM Thread Starter
Scott.O's Avatar
did the oil and filter change today.It turns out the filter was incorrect it was a 1068 NAPA gold. all still seems fine again,the whine has subsided. I used a NAPA 1410 filter and dextron 3mercon part #pf-atf-dm-qt.cut the lawn and all was fine...Scott
Scott.O is offline
