Legacy/K92 hydraulic psi increase - done! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 76 Old 12-08-2008, 09:56 PM Thread Starter
randyny's Avatar
We've discussed it in other threads; now I made good on my threat and increased the psi on the implement relief valve by adding shims. Not a difficult task at all - took about two hours. Here is what I did.
But first *** Disclaimer *** This is something I have done to my machine at my own will. It is above the design spec although informally, a tuff-torq engineer said it would be fine, and others have also done the upgrade. I accept the risk that something may fail on my machine. Do this at your own risk. ****
Pic #1 is the patient.
#2 are the shims I got from McMaster
#3 is the pre-shim psi at a front quick-connect
#4 take off the fender and be greeted by lots of dirt.
...To be continued
ID:	56611   Click image for larger version
ID:	56612   Click image for larger version
ID:	56613   Click image for larger version
2005 Legacy XL diesel subcompact w/Loader, Backhoe, 60" deck, DR 3-pt logsplitter, Leinbach 7200Jr Post Hole Digger w/ 12" auger
1984 Allis Chalmers 912H
1951 Farmall Cub w/54" snow/grader blade
randyny is offline
post #2 of 76 Old 12-08-2008, 10:06 PM Thread Starter
randyny's Avatar
Re: Legacy/K92 hydraulic psi increase - done!
#5 remove the tank and some more brackets to reveal a crud-covered tranny
#6 a quick cleanup and you can see the center valve block. The relief valve is the hex-head between the two check valves. Be very careful to clean the crud from around the valve when removing.
#7 This is the relief valve plunger assembly. It unscrews rather easily
#8 separate the components, and you get the hex nut, o-ring, washer, shim. The K92 spec sheet shows two shims by default; I only had one. The shim to insert is above the center washer.
...to be continued
ID:	56615   Click image for larger version
ID:	56616   Click image for larger version
ID:	56617   Click image for larger version
randyny is offline
post #3 of 76 Old 12-08-2008, 10:20 PM Thread Starter
randyny's Avatar
and the results:
#9 psi increased to 1150 with one .5mm shim
#10 psi increased to 1300 with two .5mm shims.
#11 is the exploded diagram of the valve block. K through R is where the action is.
I put it all back together and didn't have any bolts left over.
Initial test:
It was dark so I could not go crazy with testing. But I can lift the front of the tractor without issue (couldn't do that before), steering is noticeably easier even with weight in the bucket, and the few scoops I took in the mulch pile were obviously more powerful. Watch this space for more updates.
ID:	56626   Click image for larger version
ID:	56627   Click image for larger version
randyny is offline
post #4 of 76 Old 12-09-2008, 07:22 AM
Collector of many tractors
Kbeitz's Avatar
So is this the shim that you are talking about and the place you added more???
Kbeitz is offline
post #5 of 76 Old 12-09-2008, 09:36 AM Thread Starter
randyny's Avatar
The gold one is just a washer; the shim is to the right. Yes, that is where I added them. The valve is located just below seat. If not for the free-wheeling lever you could make this change just by lifting the seat.
randyny is offline
post #6 of 76 Old 12-09-2008, 09:48 AM
Retired and Busy!
Rodney in VA's Avatar
randyny:
Thanks for the project review and great photos. Very well done.
Rodney
John Deere 2305 TLB
John Deere X540 GT
"Retired and Busy"
Rodney in VA is offline
post #7 of 76 Old 12-09-2008, 06:22 PM
well done! good pics. having read your previous posts (I notice you work that thing hard), I predict you'll be very happy with the improvement.
steadite is offline
post #8 of 76 Old 12-09-2008, 06:34 PM
firefighter5143's Avatar
Nice!!!
SIMPLICITY
firefighter5143 is offline
post #9 of 76 Old 12-10-2008, 07:51 AM
That's one "Class A" description. This thread should go into the shop manual!
bx24d is offline
post #10 of 76 Old 12-10-2008, 04:43 PM
exNCite's Avatar
WOW!!!! Great story and presentation Randy. Would scare the crap out of me if I had mine in that many pieces.
And what do you do in your spare time?
exNCite is offline
post #11 of 76 Old 12-10-2008, 06:45 PM
9K+ Poster
JDFANATIC's Avatar
Randy,
Great post! Please let us know how much more responsive the hydraulics are.
Cheers
JDFANATIC
JDFANATIC is offline
post #12 of 76 Old 12-10-2008, 10:17 PM Thread Starter
randyny's Avatar
Thank you fellas. If I had known how easy it was I would have done some time ago.
Some more playing around yesterday. Basically it has become much more powerful. It either lifts what I ask it to, or it lifts the back end trying. One day I will get enough bags of weight so I can measure capacity. When I first got it, I measured 540 pounds to full height, although it took a looong time to get there. Which brings up another operational nicety. It operates more like I would expect hydraulics to operate; heavy loads lift at a normal speed now.
This has also got me wondering about the physics behind this charge pump design. To get to max pressure, whether the default 1000psi or the upgraded 1300psi I had to hold the joystick for a few seconds while it built the pressure. Contrast that to the PTO pump for the logsplitter - when that ram hits an immovable object the relief valve kicks in immediately. So this gives me a margin of error - if I attempt to lift a too-heavy load, it won't reach 1300psi for a few seconds, allowing me to rejudge to attempt while easing the ultimate load on the hydraulics. That's my theory anyway....
I don't imagine I will be maxing this out all that much but it is nice to be able to lift up mulch from the bottom of the pile.
randyny is offline
post #13 of 76 Old 12-15-2008, 11:54 AM
Did you have to tear it apart that much?
bersh is offline
post #14 of 76 Old 12-17-2008, 03:34 PM Thread Starter
randyny's Avatar
Yes, what you see in the pics is necessary. It is very simple though. Took two hours the first time I did it. I could do it now in half that. No special tools needed either.
randyny is offline
post #15 of 76 Old 03-28-2009, 09:12 AM
unchained's Avatar
Randy, did this mod increase the speed of the hyd as well? If not, is there anything that can be done to make the bucket respond a little quicker?
2007 Legacy XL diesel 54" deck w/mulcher, front loader, custom rear draw bar and more impliments to come.
unchained is offline
