New Simplicity Mower... a few random questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 09-16-2019, 11:45 AM Thread Starter
Hi all, I just picked up a 2003 (I think... PO wasn't 100% sure on the year) Broadmoor with 345 hours. It doesn't look like the PO did anything but put gas in it all these years. She has some squeaks and rattles but overall not in bad shape. Has the 16HP Vanguard engine and the K62 Hydro. I'm going to get to all the maintenance this winter, but had a couple questions as this is my FIRST Simplicity. That being said it is very elegant compared to my 07 Snapper, but I will admit the Snapper has a few legs up on it, which has me a bit surprised and I want to be sure this is normal. The Snapper is a flat out power house with the 23HP Extended Life Briggs engine.
First off, the hydro pedals are a bit stiff compared to the Snapper and almost tire my leg out holding them down. Are these supposed to be harder to push down and return slow? My Snapper will stop on a dime, but the Simplicity slows gradually over a few feet. I'm assuming this is normal, but it seems to take about 3 feet to stop in reverse vs maybe 1-2 in forward. Is this normal? If it is normal, is there a way to adjust this so it will stop faster? It's a bit dangerous because if I need to stop quick, the tractor won't and I'm worried I may run into something.
Second is that there has to be something wrong with the steering. My Snapper will return to center when I release the wheel, the Simplicity will not. Once I get past maybe 1/3 turn, the Simplicity will actually rip the wheel out of my hand and go to full lock without returning to center unless I counter steer back. The front tires are tight and look to be straight/proper. Does anyone have any idea what may cause this? The steering does squeak a little when turned, so I'm wondering if something is worn out.
Any other tips/things you feel I should know about my new machine are welcome.
TIA
1990Onan520-H is offline
post #2 of 5 Old 09-16-2019, 03:36 PM
Re: New Simplicity Mower... a few random questions
The steering is definitely messed up. Can't think of what because most of it should be non-adjustable, but there's something wrong it shouldn't do that. Check the front tie rod to make sure it's not bent someplace, that might cause one wheel to steer more than the other.
As far as the forward/reverse pedals go, sounds like the dampner has gone out. There should be a dampner to create some resistance, but also push the control lever on the transmission back to neutral in relatively quick fashion when you let off the pedals. If this is going that might cause a stiff pedal that takes a long time to return. Otherwise there might be some binding in the control levers from the pedals back. If the previous owner didn't do a lot of maintenance there could be a whole lot of grass built up somewhere along the path that could be causing some resistance.
Chuck Woolery is offline
post #3 of 5 Old 09-16-2019, 04:00 PM Thread Starter
Thanks. I'll take a look. There was a TON of grass on the mower deck, so I'm sure it's built up elsewhere.
post #4 of 5 Old 09-16-2019, 05:27 PM
Cracked Gear
adamthewebman's Avatar
Cogratulations on your first Simplicity and welcome to the wonderful world of Simplicity.
Sent from my SM-J727T1 using Tapatalk
-Adam
Belvidere, Illinois
Simplicity Landlord 7010, 7014, Hydro 18
Broadmoor 227, 228
adamthewebman is offline
post #5 of 5 Old 09-16-2019, 06:57 PM
Cat385B's Avatar
2nd vote for grass buildup in the hydro linkage.
Cat385B is offline
