Slow Sub-forum? Just moved to a Simplicity from a JD - Questions!! - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 20 Old 06-13-2019, 12:46 PM
Prestigious1's Avatar
Re: Slow Sub-forum? Just moved to a Simplicity from a JD - Questions!!
Did someone say stripes??? These are from the walk behind Pacer and the Presitige.
ID:	2381657   Click image for larger version
ID:	2381659   Click image for larger version
ID:	2381661   Click image for larger version
ID:	2381665   Click image for larger version
ID:	2381667   Click image for larger version
2003 Simplicity Prestige 23/54 w/Chrome Baby Moons & Bumper, Arm Rests & Custom Hitch
2009 Simplicity Pacer 17.5/34 Walk Behind w/Bagger & Mulch Kit
2010 Simplicity i1224E Snowblower
2004 Ariens LM21SW Walk Behind
Prestigious1 is offline
post #17 of 20 Old 06-13-2019, 12:53 PM
If your stripes are not pronounced, the deck may not be adjusted properly. The full weight of the rear of the deck should be on the rollers...make sure that the lift chains are not holding the weight up off the rollers. There should be slack in these chains when fully lowered. I have seen these holding the deck with the rollers still a couple inches off the ground...it defeats the purpose of a full floating deck and diminishes the striping effect, yet was delivered to the customer this way. Also, the taller the grass typically means better more pronounced stripes, so if you're mowing at 4" you should have great stripes!
post #18 of 20 Old 06-14-2019, 12:33 AM
Willscary's Avatar
Very nice Prestigious1!
I own a 2017 Simplicity Prestige 27/52 EFI, JB Jr, Johnny Plow Jr.
From 2015 to 2017 I owned a used 2013 Simplicity Conquest 27/50.
From 1996 until 2015 I owned a White LT-16 Vanguard V-twin and 2 stage blower.
In 1991 I purchased a used 1984 Gilson 16 HP opposed twin. It was a horse!
Willscary is offline
post #19 of 20 Old 06-14-2019, 06:48 AM Thread Starter
tlzkaasen's Avatar
I'll check that tonight - Appreciate the info!
2017 Simplicity Broadmoor with 48" deck | 25 HP Briggs |. Nothing else . .. yet
Sold -->1995 455 | AWS | JD 54" Deck | Mulch kit | 47" Two stage blower JD Quick Hitch w/Hydraulics| 25x10.5x12 All Trails Rear tire | Ruegg 3pt cat 1| 6 JD suitcase weights | Ruegg drawbar| Block Heater
Sold-->1998 445 | JD 40 loader | JD 54 deck |
tlzkaasen is offline
post #20 of 20 Old 06-15-2019, 11:05 AM
Ilovetomow's Avatar
There are several factors that effect stripes besides the roller.
1. Height of cut. It needs to be high enough for it to lay flat.
2. Type of grass. Tall Fescue is best in my. opinion.
3. Lawn thickness. Obviously the thicker the better, and weeds don't stripe.
Sent from my SM-J320V using Tapatalk
1999 Craftsman 14.5HP, 42"...Sold
2009 Simplicity Regent 22/44...Sold
2006 Simplicity Prestige 23/50...Sold
2016 Simplicity Broadmoor 22/44
Ilovetomow is offline
