Simplicity Landlord 20 DLX Broken Wheel Spindle - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 05-20-2019, 07:21 PM Thread Starter
Without bad luck I'd have no luck at all.
I bought what I believed to be a well-maintained 2000 Landlord 20 DLX with around 680 hours on it. After a whopping 15 minutes mowing, the front left wheel spindle snapped and turned the tractor into a trike. I've never seen this happen before and was fairly dumbfounded.
I have a new spindle ordered with delivery expected later this week.
Am I correct in assuming this is a straightforward repair as described in the service manual?
Anyone else have this experience or have thoughts on the cause? The previous owner claims good routine greasing maintenance.
The picture of the break point below makes me think the part was never fully welded as there is half of the cross section rusted. Are these spindles really two pieces welded? I'd assumed they were one solid piece from wheel to splines.
thaumaturge is offline
post #2 of 11 Old 05-20-2019, 07:47 PM
MARK (LI)'s Avatar
Re: Simplicity Landlord 20 DLX Broken Wheel Spindle
Can't weld it back?...was there a front end loader on it at one time?...that will do that kind of damage
MARK (LI) is offline
post #3 of 11 Old 05-20-2019, 09:41 PM Thread Starter
No front loader. The weld would be interior to the stop bracket, so no really.
post #4 of 11 Old 05-20-2019, 11:30 PM
mmman's Avatar
The DLX is a great little tractor but I have seen a number of those spindles break in that very same place.
mmman is offline
post #5 of 11 Old 05-21-2019, 11:06 AM Thread Starter
That's what I have come to understand, but disappointing nonetheless.
The prevailing theory for the cause seems to be embrittlement of the spindle during manufacture. You'd think a manufacturer would know how to weld a little bracket on a critical part like a spindle without compromising the metal integrity so perhaps the cause is elsewhere but there's no doubt the point of failure was weakened from more than just use.
Either way, I am out the time and coin replacing the part and watching the grass grow knee high in the meantime.
post #6 of 11 Old 05-22-2019, 11:19 AM
Yup.
Though I found mine in a more catastrophic way, with much more load on it. Thankfully I had the bucket close to the ground when it broke. Mine broke in the EXACT same spot as yours. 1" diameter trailer spindles was my cure.
No way to re-weld it and have it hold. I tigged mine just so I could try to get it back into the shed to fix it for good and it wouldn't even make it 4 feet.
ID:	2377715   Click image for larger version
Chuck Woolery is offline
post #7 of 11 Old 05-22-2019, 07:57 PM Thread Starter
Got it fixed today with new spindle.
Of course some brain surgeon at Simplicity decided to powdercoat the part so that the old bearing wouldn't slide on. Spending time taking off the coating was an unplanned annoyance given I had no wire wheel, sandpaper or other abrasive on hand at the new yard with the tractor. After several hundred turns with a vice grip slowly scraping away without marring the shaft too much I managed to get it all back together.
Old 05-22-2019, 08:17 PM
MARK (LI)
This message has been deleted by MARK (LI).
post #8 of 11 Old 05-22-2019, 08:20 PM
MARK (LI)'s Avatar
That was an expensive tractor....you would think that the manufacturer would have a supply ready to ship out with little fanfare to avoid bad publicity...and I am a big Simplicity fan
post #9 of 11 Old 05-22-2019, 08:25 PM Thread Starter
Agreed.
Thankfully I bought the tractor used for $1200 with 680 hours so my tolerance for failure is a bit higher. It's in good shape otherwise having had new PTO clutch and deck bearings installed recently.
I got a comparative bargain on the spindle part ($150) via an open box item from a dealer listed on -bay. Retail was closer to $200 onilne and who knows locally. Still highway robbery but could be worse, could be green.
post #10 of 11 Old 05-25-2019, 06:21 PM
ACmowerguy's Avatar
Unfortunately many of these tractors are nearing the end of their life cycle as they are nearing 20 years of age. Having had many Simplicity large frame (Sovereign) series tractors I found the DLX to be a disappointment. Many more parts worn at earlier hours and costly to replace. Numerous parts are already NLA though most of those are merely cosmetic. I had a '98 Landlord and it seemed better even though its really built about the same as the DLX models (though a 345 was several thousand more when new) I have seen better longevity and quality in the JD 345 series than these late model Landlords. They just don't wear out parts at the same rate and the power steering system is much better. I had two 345s and sold them because I prefer the Simplicity deck system. Much simpler and less scalping.
SIMPLICITY- 700, 3410S, 3410H, 17GTH-L, 727, 738, 7116H, 75th anny Sovereign, '99 Landlord DLX
Allis-(2) B-10's, B12, (2) B110's, B-207, (2) B210's, B212, HB212, Homesteader 8, 416H, 710, 912H, 914S , 916H, 917H
Deutz-Allis 917H with PS
Massey-MF8 Executive, MF12, MF16,
Sears- 1971 HT14 hydro
JD - 110, 214
ACmowerguy is offline
post #11 of 11 Old 05-25-2019, 07:29 PM
my 76 990 snapped a spindle like that have a loader on it and got jammed into a dumpster gate when dumping some thing when trying to lift bucket snped the axle look like had an old break in it had tractor since new just put loader on in 2012 fixed it up with new section should have taken a pic after fixed mine there was a couple more that had broke posted
You could have hit some thing at some time causing the fractur
Bernard Camarro
Fairfield Conn
Bernard Camarro is offline
67 Simplicity landlord clean up. rdmanone Simplicity/Allis Chalmers Forum 25 03-01-2019 09:44 AM
Landlord DLX loader build Chuck Woolery Simplicity/Allis Chalmers Forum 38 08-23-2018 09:04 AM
Simplicity landlord DLX Mrlunchbox Simplicity/Allis Chalmers Forum 3 07-13-2018 11:49 PM
Landlord DLX or Prestige Dragon Master Simplicity/Allis Chalmers Forum 5 01-24-2013 11:41 AM
