Kawasaki 27hp RPMs Full Power - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 05-20-2019, 12:46 AM Thread Starter
firefighter5143's Avatar
What should the RPMs be set at when mowing? Mine only goes a little over 3000 RPMs. Seems a little slow for full power. 1
SIMPLICITY
firefighter5143 is offline
post #2 of 5 Old 05-20-2019, 02:39 AM
Re: Kawasaki 27hp RPMs Full Power
You might check the owners/users manual to see if they included the rpm the tractor was designed to run at. I'm pretty sure they would have calculated it out, so at designed rpm, the blade trips would run at their desired speed. The engine itself is most likely designed to run at 3500-3600 rpm, and may have been reduced by the OEM (the maker of your mower) to work with their design.
dave_r is offline
post #3 of 5 Old 05-20-2019, 10:06 AM
According to my manual (Model # 2690345) all of the available engines (Kohler gas, Kawaskai liquid cooled gas, and Briggs/Daihatsu Diesel) all made 27 HP at 3600 rpm. Hope this helps.
Simplicity Legacy XL 4WD Diesel
61" Fabricated Deck
Clean Sweep Triple Grass Catcher
Turbo Collection System
48" Kwik-Way Loader
60" Hydraulic Dozer
2011 GMC Sierra Denali AWD
Custom 4" Intake, BlackBear Tune, Kooks 1-3/4" Longtubes w/Catted Y-Pipe
http://s76.photobucket.com/albums/j18/Cakes12/
Cakes is offline
post #4 of 5 Old 05-29-2019, 09:58 PM Thread Starter
So what I found was I adjusted the throttle cable so the engine would reach its maximum but the throttle lever would slowly back itself back down in the 3200 rpm range. So my next step was to tighten the nut and bolt that go through the throttle lever underneith the dash. This solved my issue and now the tractor runs at 3600 rpm.
SIMPLICITY
post #5 of 5 Old 06-13-2019, 02:24 PM
Prestigious1's Avatar
You think it cuts good now?? Wait until you put some high performance cams, high compression piston and a couple Mikuni 40mm flat slide carbs on it...she'll sling the grass real well at 5200rpm!!
For a while...
2003 Simplicity Prestige 23/54 w/Chrome Baby Moons & Bumper, Arm Rests & Custom Hitch
2009 Simplicity Pacer 17.5/34 Walk Behind w/Bagger & Mulch Kit
2010 Simplicity i1224E Snowblower
2004 Ariens LM21SW Walk Behind
Prestigious1 is offline
HP needed for Bercomac 48" Power Broom dave_r Lawn and Garden Tractor Accessories 0 12-15-2018 04:49 AM
317 Power Steering Conversion using 400 parts xtinctss John Deere Forum 17 08-21-2013 03:51 PM
RECALL - Kawasaki engines & Honda generators BRAKER Safety Forum 0 11-16-2012 09:26 PM
Bringing Dell Desktop back from Sandy power outage Jere39 Computer and Electronics 17 11-11-2012 08:57 PM
2305 12V power port & light switch installation Loogie John Deere SCUT 46 07-21-2010 01:09 PM
