2010 cracked rear axle remedy? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 21 Old 05-15-2019, 05:57 AM Thread Starter
Dave Shaver's Avatar
Hi all,
Well, was servicing my 2010 the other day and when I greased the rear axle grease was coming out where it ain't suppose to....
I don't know what it takes to replace but I'm really not going to pull the tranny apart to do it. SOOO, I ordered two locking collars from McMaster-Carr, (if they don't have it you probably don't need it, great company!) and you can see in my pics the crack and the collars in place.
Guess my question is do you think it will hold or am I just whistling Dixie til it breaks? The hardest job it does is pull a VERY heavy roller, probably over 800 lbs estimated. MY JD's with the hydros DO NOT like to pull it, need a geared tractor to do the job. I have a line on a geared 7112 with hi lo and thought it may be an upgrade if you guys think think the collar thing ain't gonna work.
Opinions appreciated and thanks!
Name:	Cracked Axle 1.jpg
ID:	2376655   Click image for larger version
Name:	Cracked Axle 2.jpg
ID:	2376657   Click image for larger version
Name:	Cracked axle 3.jpg
ID:	2376659   Click image for larger version
Name:	Locking collars.jpg
"You can judge a man's character by the way he treats someone who can do nothing for him". Malcolm S. Forbes
Current fleet
2004 GX345 w/ diff lock, 48C mulch compatible deck, 42" thrower, 48" blade
1998 345 w/30" tiller, 48" mulch compatible deck, Johnny Bucket JR.
1967 Simplicity 2010 w/blade, very heavy roller, thatcher, aerator
1978(ish) Simplicity 7016 w/ 20hp Kohler Command w/ 50amp alt, lights, wiper, heater in steel cab, 36" thrower mod. to 42", 42" deck
Dave Shaver is offline
post #2 of 21 Old 05-15-2019, 07:44 AM
Re: 2010 cracked rear axle remedy?
It certainly is worth a try. Id say it all depends how deep that crack goes whether it would last or not.
Junky is offline
post #3 of 21 Old 05-15-2019, 08:36 AM Thread Starter
The crack has mitigated about 40% from the outside in towards the trans diagonally.
Thanks for the reply Junky.
Current fleet
post #4 of 21 Old 05-15-2019, 09:46 AM
That would severely weaken the axle. Maybe a tight fitting thick walled pipe with set screws fitted over all of the exposed surface would brace it a little better? Other than that its replacing the axle. Good luck on that.
Junky is offline
post #5 of 21 Old 05-15-2019, 10:49 AM
Maybe a shaft coupler like this one will let it last a bit longer..?..
https://www.surpluscenter.com/Brands...r-1-1563-E.axd
Tractor-Holic is offline
post #6 of 21 Old 05-15-2019, 05:53 PM
As others have said, it depends on how bad the crack is. For what it's worth, I have a similar problem on my tractor which also has a cracked axle tube. I bought a similar collar from McMaster Carr and it has held for the last 9 years.
Dee_Veloper is offline
post #7 of 21 Old 05-15-2019, 06:15 PM Thread Starter
Junky and Tractor -holic,
I think the idea of a tube over it would still allow movement. And, that shaft coupler might work but the axle mics at 1 11/16" and they don't show one with that exact ID.
Current fleet
post #8 of 21 Old 05-15-2019, 06:24 PM Thread Starter
Dee Veloper,
That's what I was hoping to hear. Someone else that did the same thing and it has lasted 9 yrs! Great!
Thanks to all you guys for your thoughts. This forum has a lot of people with great ideas and I greatly appreciate it! Maybe we'll get some more opinions......
Current fleet
post #9 of 21 Old 05-15-2019, 06:29 PM
Parts collector
mopar65pa's Avatar
drill a hole "1/8" at each end of the crack as deep as the crack, grind a "V" in the crack not too deep. Then weld it and put your sleeve or whatever you choose over it.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #10 of 21 Old 05-15-2019, 06:38 PM Thread Starter
Hi Mopar,
Well, I thought about that and even just stop drill the crack without welding. My gut feeling was that with all the grease that's in that axle tube it would be a big problem trying to weld it. I do have a small wire welder which might do it but the idea of the crack getting contamination from the grease stopped me on that one.
Current fleet
post #11 of 21 Old 05-15-2019, 06:53 PM
Parts collector
mopar65pa's Avatar
Originally Posted by Dave Shaver View Post
Hi Mopar,
Wipe it down with alcohol or Acetone, do not use brake clean! (brake clean when heated and burnt will kill you) Let it run in the cracks. Grind it wipe it again with alcohol and weld on the highest setting you have.
I'm not sure what you have for a welder but if it's anything like my little Campbell Hausfield it may do the trick. I personally have a miller 210 mig that will weld anything.
Here's the thing, it is tempered steel. You need to "spot weld it" HOT for 2 seconds and burn that weld in, then let it cool for 5 mins. If you over heat it it will lose the "temperment" then it will bend and warp under pressure.
just trying to help man!
1970 140 H1
1977 300 H2
198? 332 50" deck
post #12 of 21 Old 05-15-2019, 07:35 PM
On mine, I removed the grease zerk and replaced it with a set screw so I could get the collar directly over the crack.
post #13 of 21 Old 05-15-2019, 09:15 PM
arathol's Avatar
Welding is not really an option. There is a bronze bearing sleeve inside that might not take to kindly to that.
Keep in mind that not only does the tube have to move but the axle shaft has to turn freely inside it. You can clamp it up and it might work but if you are going to be puling an 800 lb roller its probably going to get worse regardless. The clamp will keep the crack closed but the torque from pulling a heavy load will still twist the axle and the crack will grow.
Best bet for easy repair is find another working gear box. A new or refurbished axle tube - if you can find one -will most likely cost almost as much as the entire used transmission and its a not a simple thing to replace it in any case. I have one in the garage waiting to be rebuilt right now...
arathol is offline
post #14 of 21 Old 05-16-2019, 07:36 AM Thread Starter
Mopar,
I'm not much of a welder anyway. I get penetration (I think) but make them pretty with a mini grinder..... But I do appreciate the info.
Yeah I agree Arathol,
I only pull that roller once a year in early spring on my 3/4 acre rolling lot. I guess we will have to see what happens. That 7112 I was thinking of looking at is going to have issues I wouldn't know where I have had this 2010 since 1987. It's like an old buddy.
Dee Veloper,
I thought about that but my brain could't think of a way to plug the hole. Set screw would do it. Maybe I'll order another collar and do this.
Thanks to everybody!!!
Current fleet
post #15 of 21 Old 05-16-2019, 09:48 AM
I suggest taking it to a welder, for patch up welding. Should be only $50 or so. Even a bit of weld on surface without grinding would be stronger than collars. Do it quickly to keep heat down. I've stick welded cracked hydraulic cylinders with oil in them using 6010 for first pass. Looks like chicken poop, but it seals it, then grind and 7018, if you like (ports have to be open on cylinders). If one option is to get new rear end why not try welding first.
Hydronerd is offline
Pro wheel bearing and seal Com12 Gravely 19 12-21-2018 06:22 PM
318 rear axle leak Sbela55 John Deere Forum 3 03-31-2018 09:53 PM
Lawn Tractors, 90's - 2000 Vintage, Front Axle Change andyjw Backyard Round Table - L & G Tractor Related Topics 11 03-11-2013 11:30 AM
rear wheel steer axle for fron axle? nick 130 Home Made Tractors, Implements and Accessories 18 12-27-2012 02:26 PM
Agco needs a diaper .... PBR ME Simplicity/Allis Chalmers Forum 16 12-26-2012 03:40 AM
