2010 cracked rear axle remedy? - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 21 Old 05-16-2019, 06:29 PM Thread Starter
Dave Shaver's Avatar
Re: 2010 cracked rear axle remedy?
Thanks Hydronerd,
I have a guy who could weld it for me. I did find a 2010 that is not running and it sounds like the guy just want to get rid of it. Hummm, maybe I'll give him a call. I pulled the rear on my 345 in the past to exchange, this one shouldn't be any worst than that.......
"You can judge a man's character by the way he treats someone who can do nothing for him". Malcolm S. Forbes
Current fleet
2004 GX345 w/ diff lock, 48C mulch compatible deck, 42" thrower, 48" blade
1998 345 w/30" tiller, 48" mulch compatible deck, Johnny Bucket JR.
1967 Simplicity 2010 w/blade, very heavy roller, thatcher, aerator
1978(ish) Simplicity 7016 w/ 20hp Kohler Command w/ 50amp alt, lights, wiper, heater in steel cab, 36" thrower mod. to 42", 42" deck
Dave Shaver is offline
post #17 of 21 Old 05-18-2019, 06:30 AM Thread Starter
Hey guys,
This looks like the tube I need.
https://www.ebay.com/itm/Simplicity-...QAAOxy~iJQ-TEv
Is it as simple as pulling the right wheel and sliding on?
Thanks again
Current fleet
post #18 of 21 Old 05-18-2019, 07:52 AM
If you knew a machinist they could grind a bit undersized tube to an exact fit for you. The tighter the fit the better.
Junky is offline
post #19 of 21 Old 05-18-2019, 01:02 PM
arathol's Avatar
Originally Posted by Dave Shaver View Post
Hey guys,
Thanks again
That is an internal transmission part. Its the spacer that goes between the large drive gear and the bearing on the left side of the case. You can see it here on the left side of the gear on the old tube.
Sliding this over the crack will accomplish nothing except to hide the problem....
arathol is offline
post #20 of 21 Old 05-18-2019, 05:37 PM
To use that spacer you would need to cut it lengthwise and weld on some nuts to bolt it back together.
If you're looking for something longer, maybe this would work for you.
https://www.aa-mfg.com/product/4-bolt-clamp-2/
I believe the tube is 1 3/4 in diam so it should fit.
Dee_Veloper is offline
post #21 of 21 Old 05-18-2019, 06:50 PM Thread Starter
Thanks arathol, I wondered where that tube went.
Dee, thanks, I think the collars I have will do the same thing especially if I get one more and remove the zerk fitting. When I mic'ed mine it appeared to be 1 11/16. Thats what I ordered when I got the collars.
Current fleet
Pro wheel bearing and seal Com12 Gravely 19 12-21-2018 06:22 PM
318 rear axle leak Sbela55 John Deere Forum 3 03-31-2018 09:53 PM
Lawn Tractors, 90's - 2000 Vintage, Front Axle Change andyjw Backyard Round Table - L & G Tractor Related Topics 11 03-11-2013 11:30 AM
rear wheel steer axle for fron axle? nick 130 Home Made Tractors, Implements and Accessories 18 12-27-2012 02:26 PM
Agco needs a diaper .... PBR ME Simplicity/Allis Chalmers Forum 16 12-26-2012 03:40 AM
