Center mower blade keeps coming loose! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 05-13-2019, 12:28 PM Thread Starter
Hey guys. Deutz allis 1920 with 60" deck. The center blade keeps coming loose (during heavy use, leaves, rocks etc, not during normal mowing) but the others don't seem to have this issue. Clearly it was an issue with the previous owner too, judging by the condition of the centering washer. (I had to replace it). Is this an issue with these? I did everything I could think of. Made sure the blade is balanced. Bolt was tight. Even added a lock washer. Saturday it happened again. I have now put it on with blue loctite and I guess we will see what happens. Any clues?
BoltsNhose is offline
post #2 of 8 Old 05-13-2019, 03:16 PM
Re: Center mower blade keeps coming loose!
threads are perhaps worn or have oil/grease on them?
dave_r is online now
post #3 of 8 Old 05-13-2019, 07:51 PM
Try using some medium strength thread locker on the bolts.
Dee_Veloper is online now
post #4 of 8 Old 05-13-2019, 09:58 PM
arathol's Avatar
Any pictures would help. Did you replace that washer with the correct part?
arathol is online now
post #5 of 8 Old 05-14-2019, 06:43 AM
Steve Urquell's Avatar
Threads are worn and not holding torque well. If the locktite doesn't get it you can make the nut into a castle nut and drill the spindle for a cotter pin or weld the blade on the spindle.
I welded one on my old wheelhorse that kept falling off with the intent to take the pulley nut off and drop the shaft/blade out together for sharpening. The shaft alone was $50. Shortly after that I got it hung up on a root and broke the spindle housing--had to buy one anyways. I got the shaft.
Steve Urquell is offline
post #6 of 8 Old 05-14-2019, 03:17 PM
arathol's Avatar
Not how it works with many Simplicity decks. The blade is located on the arbor shaft by a splined washer.
The arbor sticks out just a bit from that washer.
The blade is secured by a spring washer. Its cupped a bit in the center and applies a clamping force around the edge, not the center.
So, if that outer spring washer is not the correct part or is flattened out, you can tighten the bolt all you want but it won't keep the blade from spinning on the arbor.
Welding the blade on this deck would make it near impossible to the sharpen the blade, let alone replace it...
post #7 of 8 Old 05-14-2019, 03:44 PM
Got it. Thanks.
On my WH all you had to do was remove the pulley nut on top of the deck and drop the whole shaft and welded on blade out of the bottom for sharpening. It was on a mower I hated and intended to get rid of and didn't want to put money into.
When I broke the spindle housing I bought just the shaft, housing, and a nut and it cost me ~$150 to repair 1 spindle and that was re-using the bearings and spacer. No assembled spindle is available--parts only.
post #8 of 8 Old 05-14-2019, 03:52 PM
This looks more like a setup like my Gravely ZT XL 42, where the bolt holding the blade on screws into the spindle's shaft, rather than going all the way through it.
You (the O.P.) might try just getting a new bolt, or switch bolts with one of the other spindles and see if it moves with the bolt.
Blade changing safety? rahfish John Deere Forum 18 05-11-2019 07:17 AM
60" MMM help Steamguy Kubota 6 10-03-2018 12:11 PM
X590 Front or Rear Blade jma24 John Deere Forum 17 07-19-2018 08:44 PM
Blade Belt issues with 2013 Troy-Bilt (MTD) mower KArthur MTD 10 07-18-2018 10:15 PM
318 pto center bolt loose nyfrozenbrain John Deere Forum 1 02-25-2018 05:53 PM
