Opinion On Buying Older Used Legacy w/ FEL - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 23 Old 04-02-2019, 10:34 AM Thread Starter
I am looking at finding a SCUT or CUT with FEL for a fair amount of landscaping work around my house. It's not a large property at roughly 1/2 acre, but I plan on adding cement driveway extensions (removing 8" soil, hauling in gravel), regrading 300-400 feet of one side of the property, etc. More then enough work for a SCUT imho. I am looking at a late 90's early 2k's Legacy with 20hp Kawasaki w/ FEL, rear PTO, and 3pt. It has around 1000 hrs. Current owner hasn't had it long and has upgraded to something larger, so it's history is unknown. He said the rear PTO clutch is broken, other then that he said it works fine. He also has a parts tractor that I could have for a little more. He is asking $4750. I included pics of the broken PTO clutch. What do you think caused that and would it be much to fix. What else should I look for when inspecting and testing? It's a few hours away, so I want to be well prepared when I go look at it.
Wondering what opinions are on how much life I should expect to get out of it, and based on it's price relative to age and hours. My other option is renting equipment on and off over the next few years to accomplish my tasks.
ID:	2369487   Click image for larger version
jonshonda is offline
post #2 of 23 Old 04-03-2019, 01:33 AM
20,000 Posts & Climbing
Re: Opinion On Buying Older Used Legacy w/ FEL
I can't help with the clutch, but I personally put over 2000 hours on my 1977 MF1655/FEL doing everything that you mentioned and a whole lot more.
The Legacy has the same hydro and final drive as the Massey and a longer wheelbase which helps with ballasting, but it is a bit narrower making for less stability on slopes. As a bonus, it also has power steering which will be an asset. Armstrong steering gets old in a hurry with a full payload in the bucket.
While the price mentioned seems a bit high to me, the value is certainly there, especially if a parts tractor comes with it.
Note that a Legacy is a heavy 2wd GT, not a 4wd SCUT, but it is comparable when properly ballasted and equipped with 2-link chains. My MF1655 will outlift my MF GC2310 SCUT and push a bigger bucket through deeper snow. The SCUT has an advantage for doing dirt work with its 4wd and narrower bucket.
The advantage of having your own loader is that you have the opportunity to take on tasks at your discretion as time and weather permits. Renting depends on having enough time available to do the entire job during the rental period, if the weather also cooperates and the machine is actually available. At about $250 per day, 20 days over several years will cost $5000. Its a real bear to line up a full days work for a rental when you have several projects that need doing now. Something is going to be missed that you will remember two days later.
In my case, I have a third of an acre residential property of which I have tilled, excavated, backfilled, or otherwise disturbed over 75% of the surface over the years. In addition, snow removal on occasion absolutely requires a loader. A snow blower will get nowhere moving the 1200 sq-ft of snow that avalanches off of the house roof onto the driveway when the weather turns mild like it did 3 weeks ago. The pile was 3.5' deep for 40' and the full width of the driveway. Without my loader, I'd have to hire a wheel loader and a truck to haul it away instead of just moving it to the pile it in the back yard.
Having your own loader is golden. Mine owes me nothing after using it for 22 years, even after buying a brand new engine for it after 12 years. It has saved me over $10K just in snow removal, never mind redoing the 165' driveway or excavating for the garage and pool.
TUDOR is offline
post #3 of 23 Old 04-03-2019, 07:55 AM Thread Starter
Thanks for the insight TUDOR. I messaged a member who is local and he also commented to the fact that GT prices are sky high in our area (there is a XL w/ FEL local with 600hrs and they are asking $13,500 ). Looking more into it, this Legacy didn't have a deck on it when the current owner bought it, which makes me think it spent all its time with a loader on the front. Guessing that's not as posh a life as being a dedicated mower it's entire life. Regardless, the parts tractor has no motor, but has a 60" deck.
I do agree that having a loader at my disposal would be ideal, it's just hard to sell that idea to the wife when I have spent a lot of time getting our current lawn tractor equipped to handle the leaf barrage our neighbor casts upon use throughout the year.
post #4 of 23 Old 04-03-2019, 10:20 AM
Learning the hard way
kb4212's Avatar
To be fair the XL for $13,500 has only 68 hrs diesel/loader/2-stage blower/deck/and cab/. Don't ask me how I know.
2004 Simplicity Legacy XL 4x4 27HP Diesel with 48" deck, 60" 4-way snow/dirt plow, 46" 2-stage snow blower, 3-point, rear PTO, and FEL
1950 Ford 8n Sherman Step-up (in the family since new) and Dearborn 19-5 rear blade
https://www.youtube.com/user/W1WEASEL
kb4212 is offline
post #5 of 23 Old 04-03-2019, 10:28 AM
c5rulz's Avatar
I'd pass, way too much money for something that is busted. It almost looks to me like the clutch was broken getting it off, and that is troubling.
JD X758 60" HC deck
Dolmar 7900
Jonsered 2159 ported
Echo CS303T
Echo PPT 266
Echo PPT-266 pole saw
Silvey 510
Oregon 511AX
Nielsen 100B for rakers
c5rulz is offline
post #6 of 23 Old 04-03-2019, 10:29 AM Thread Starter
Haha! I'm talking about a different one in NW WI. Too funny!
Yours does look very nice, but unfortunately out of my price range and my Ariens Platinum blower would be pretty cross with me if I showed up with that fancy machine!
post #7 of 23 Old 04-03-2019, 10:31 AM
kb4212's Avatar
Oh shoot. I'm sorry. I'll guess I'll have to change the price to $13,499.
kb4212 is offline
post #8 of 23 Old 04-03-2019, 10:32 AM Thread Starter
Change the price to $7,499 and I'll pack up and be down there today!!
post #9 of 23 Old 04-03-2019, 10:33 AM
kb4212's Avatar
kb4212 is offline
post #10 of 23 Old 04-03-2019, 10:58 AM Thread Starter
I'll even throw in a case of blatz and a cheap cigar or two.
post #11 of 23 Old 04-03-2019, 11:23 AM
kb4212's Avatar
Oh man, too bad it wasn't Schlitz we might have had a deal. LOL
kb4212 is offline
post #12 of 23 Old 04-03-2019, 02:48 PM
KB, did you get your XL from Persha Equipment in Mayville.
Legacy XL 4x4: Hardside Cab, 47" Two Stage Snowblower, 60" Deck, Front End Loader. Prestige 27HP/54" Deck, Simplicity Chipper/Shredder. Fimco 25 gallon tow behind sprayer
Andy is offline
post #13 of 23 Old 04-03-2019, 03:47 PM
kb4212's Avatar
Andy, no I bought it used private party sale in Central Illinois.
kb4212 is offline
post #14 of 23 Old 04-03-2019, 05:32 PM
kb4212's Avatar
What about this one?
https://madison.craigslist.org/grd/d...856653819.html
kb4212 is offline
post #15 of 23 Old 04-03-2019, 06:36 PM
Okay, I knew he had one for sale a few months back new in the crate. How do you the like the diesel compared to the Kawasaki?
Andy is offline
FS: Simplicity Legacy Diesel FEL Loader 60" Deck (NY) kteach27 For Sale & Wanted to Buy (Your Location) 0 12-26-2018 08:58 AM
FS: Simplicity Legacy 24.5 Diesel FEL 60" Deck 550 Hours kteach27 Simplicity/Allis Chalmers Forum 1 12-23-2018 09:50 PM
Has anyone seen the new FEL for the Legacy XL Andy Simplicity/Allis Chalmers Forum 14 03-21-2018 03:57 PM
Info and opinion on older Case maverick302 Case 1 02-10-2018 08:07 AM
How capable is an old legacy fel really? 92GA Simplicity/Allis Chalmers Forum 38 01-11-2018 04:17 PM
