Easy question about the hydro d-shaft on Sunstar - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 02-14-2019, 10:15 PM Thread Starter
tdipaul's Avatar
I have the "new to me" GTH20 apart for cleaning and maintenance, and upon greasing the driveshaft u-joint and spline I noticed that the shaft does not appear to be on the spline as far as it could be. Or maybe it is. Per the diagrams it appears there isn't a clip or pin holding it on.
Does this sound right to you?
also, where do you check/add fluid?
#7 is a grease fitting...
front of unit with driveshaft attached (input)
rear of the unit for reference
Simplicity GTH20
Craftsman FF20
Scag SW61
Wright Stander B
Toro 5/24 SB
Stihl BR700
Stihl FS94
tdipaul is offline
post #2 of 4 Old 02-15-2019, 02:21 AM
20,000 Posts & Climbing
Re: Easy question about the hydro d-shaft on Sunstar
The end with the U-joint is longer than the one in the last pic.
Check the depth from the spider side of the U-joint to the end of the shaft with a wire or shirt pocket machinist's scale.
TUDOR is online now
post #3 of 4 Old 02-15-2019, 04:09 PM
G-1
Senior Tinkerer
Tdipaul, I had that U-joint problem. On mine, the engine mounts became loose and the rubber wore out. I had noticed that there was more vibration coming from the shaft, but by the time I did anything about it, the splines on the driveshaft wore too much. Ended up having to replace the driveshaft. For some reason, even after putting new rubber on the engine mounts and replacing the shaft (with a used one), the U-joint still did not go onto the pump shaft far enough. I don't know why and speculated that maybe it never did go on as far as it should. Anyway, I moved the motor mount plate back enough to get the U-joint to slide on almost to the groove in the pump shaft. (Had to drill a couple new holes in the frame.) It made a tight fit between the engine and the cooler housing, but has worked OK since.
The fluid level is checked at the clear tube. One inch of fluid showing in the tube with engine off and parked level.
Gerald
G-1 is online now
post #4 of 4 Old 02-15-2019, 04:31 PM Thread Starter
tdipaul's Avatar
I checked inside the spider and there is some shaft felt inside so I guess it is ok
Gerald, thanks for this info. I was washing and reassembling the machine outside today (60 and sunny in NJ!) and saw the clear tube you mentioned running atop the hydro unit and the fluid was about where you said it should be.
Took her for a spin and shes all good to go for spring now. These sure are overbuilt tractors and are effortless to operate with the power steering. I wish I had a snow plow for it.
Simplicity GTH20
Craftsman FF20
Scag SW61
Wright Stander B
Toro 5/24 SB
Stihl BR700
Stihl FS94
tdipaul is offline
Question about PTO shaft to snowblower trevor.wright0 CUT Implements and Accessories 2 12-22-2017 09:03 AM
ATTN: John Deere 318 Owner's, a Few Tip's on how to Keep that 318 Alive & Well Hammerdown John Deere Forum 34 06-01-2016 11:21 AM
project tractor MF 14 gonna do a lotta mods Whirly Massey Ferguson 375 02-20-2014 01:33 AM
Bolens 1455 - Drive shaft issue backwoodsmechanic Bolens Forum 10 01-05-2013 07:13 PM
317 rear PTO shaft question jduffey5 John Deere Forum 2 11-28-2012 12:21 PM
