Cletrac HG Stuff - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Vintage Tractors Any Vintage machines not listed....
post #16 of 63 Old 09-21-2006, 08:15 PM Thread Starter
Once was a Super Member
Wingnut's Avatar
Send a message via Yahoo to Wingnut
Re: Cletrac HG Stuff
This is the first time this has happened. I had to use duct to to get a good seal to check the compression. The spark plugs holes were 7/8"
These are brand new plugs 1-4 left to right.
The compression read 120 psi on all cylinder except number 2 it read 90 psi.
I poured some oil into number 2 and it still read 90 psi.
That narrows it down to:
Bad Valve -- Very possible
Head Gasket -- Very possible
Cracked head -- Very possible
Crack sleeve -- maybe but not likely
Crack Ring -- No psi remain the same after oil was added. (psi would have gone up)
Hole in the piston -- not likely but possible reading on compression at 90 psi is very and it was consistant.
Bent connect rod -- not likely engine runs smooth no knocks
ID:	14372   Click image for larger version
Celebrating 41 years of a Drug-Free Elvis! Adventures with Harry Ferguson!
How far you go in life depends on your being tender with the young, compassionate with the aged, sympathetic with the striving, and tolerant of the weak and the strong, because someday in life you will have been all of these.
Lose money while restoring a Farmall F-12 let me show you how!
CLICK HERE
Wingnut is offline
post #17 of 63 Old 09-21-2006, 08:21 PM Thread Starter
Wingnut's Avatar
Bear what is you opinion?
The number 2 spark plug has carbon junk on it
CLICK HERE
Wingnut is offline
post #18 of 63 Old 09-21-2006, 08:29 PM
10,000 +posts!
glenn27's Avatar
Exhaust valve, and /or head gasket on that cylinder?
Jimmy Buffett
glenn27 is offline
post #19 of 63 Old 09-21-2006, 08:44 PM Thread Starter
Wingnut's Avatar
I am going to pull the head tomorrow, but there is a history of cracked head on this engine!
CLICK HERE
Wingnut is offline
post #20 of 63 Old 09-21-2006, 08:47 PM
10,000 +posts!
glenn27's Avatar
Is there a ready-made source for replacements?
Jimmy Buffett
glenn27 is offline
post #21 of 63 Old 09-21-2006, 08:50 PM Thread Starter
Wingnut's Avatar
New and used part are available at http://www.olivercletrac.com/
CLICK HERE
Wingnut is offline
post #22 of 63 Old 09-22-2006, 04:21 AM
bear's Avatar
Send a message via AIM to bear Send a message via MSN to bear
does it burn any oil, antifreeze or have you run it long enough to tell looks like #3 has some deposits on it to possible head gasket between the 2 do you have a rad pressure tester if so hook it up and take it for a drive hook a load to it or use brakes to work engine and see how fast press raises in the rad
bear is offline
post #23 of 63 Old 09-22-2006, 05:27 AM
ex spelling bee champ
Ingersoll444's Avatar
Ing nice and strong? Maybe its the picture, but they all look pretty oily to me. Kinda like what my N used to produce.
Paul
SUPER Of The Month 10/2011
Ingersoll444 is online now
post #24 of 63 Old 09-22-2006, 05:51 AM
Collector of many tractors
Kbeitz's Avatar
This tractor is an OC3 ... What did the OC stand for???
Oliver Cletrac ???
Kbeitz is online now
post #25 of 63 Old 09-22-2006, 07:49 AM Thread Starter
Wingnut's Avatar
Its a non-pressure radiator system the wounderful Thermo-sophon system, but it has field installation kit water pump. The radiator is still a no pressure.
I do have a radiator pressure tester that I can used to verify the system is water tight. I can use that to check and see if any air being in pump cooling system with spark plug out just kicking the engine.
CLICK HERE
Wingnut is offline
post #26 of 63 Old 09-22-2006, 09:29 AM Thread Starter
Wingnut's Avatar
It’s a non-pressure radiator system the wonderful Thermo-siphon system, but it has field installation kit water pump. The radiator is still a no pressure.
I do have a radiator pressure tester that I can used to verify the system is water tight. I can use that to check and see if any air being pump into cooling system with spark plug out just kicking the engine.
CLICK HERE
Wingnut is offline
post #27 of 63 Old 09-22-2006, 09:44 AM
bear's Avatar
you'll need the spark plug in to see if it pumping air into the cooling system i just reread your post and #2 and #3 have different compression so its not likely the gasket is blown between them
bear is offline
post #28 of 63 Old 09-22-2006, 09:59 AM Thread Starter
Wingnut's Avatar
I can use stethoscope listen to air being pushed in, but its windy here today, so probably anything through it. Number 3 has good compression still. All will try all kind methods
CLICK HERE
Wingnut is offline
post #29 of 63 Old 09-22-2006, 10:01 AM Thread Starter
Wingnut's Avatar
Oliver Cletrac ???
Oliver Cletrac at first then couple of years later morphed into Oliver Crawlers
CLICK HERE
Wingnut is offline
post #30 of 63 Old 09-22-2006, 11:48 AM
I'd rather be threshing!
mbkerk's Avatar
Send a message via AIM to mbkerk Send a message via Yahoo to mbkerk
I thought of you Wingnut, a couple of weeks ago at the James Valley show in Andover, SD...
This one's for you!
Cletrac's owned by the Anderson family in Andover.
Mark
Fargo, ND
Where are you from? VOTE HERE! To represent your state!
2004 Craftsman GT 5000 • 1962 Cub Cadet • 1944 John Deere B • 1954 John Deere R Diesel
1945 VAI Case • 1998 Dodge Ram 2500 4X4 / Cummins 24V
mbkerk is offline
What is this stuff? Dachshund Farm Crops 30 04-19-2006 11:45 AM
New CC stuff CHEAP! mark777 Lawn and Garden Tractor Accessories 2 01-30-2006 11:48 AM
old stuff and new stuff etap John Deere Forum 1 01-20-2006 11:56 AM
You don't need a really big shop to get stuff done professor WorkShops, Garage and Shed Discussions 15 07-31-2005 01:25 PM
