Starter not getting power - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Vintage Tractors Any Vintage machines not listed....
post #1 of 13 Old 07-14-2019, 07:36 PM Thread Starter
bigz1983's Avatar
I have a 1956 IH 300 utility
and a couple weeks ago it started just randomly quiting.
I wiggled the ignition switch and it would start.
So I replaced the ignition switch.
Well it still won't start.
I got a multi-meter and I have 12.9 volts at the big starter wire but no power to the little selonid wire when turning the key.
There is a little relay or something by the battery what is that?
I don't know where to go from here.
I need some direction here.
ID:	2386595   Click image for larger version
"If at first you don't succeed buy a farmall"
bigz1983 is offline
post #2 of 13 Old 07-14-2019, 09:39 PM
Re: Starter not getting power
That little thingy is a circuit breaker, it may be open.
RoyM is offline
post #3 of 13 Old 07-14-2019, 09:49 PM
kklowell's Avatar
The other things to check might be a fuse, corrosion of a connection or a safety switch.
kklowell is online now
post #4 of 13 Old 07-15-2019, 10:08 AM Thread Starter
bigz1983's Avatar
Ok I'm going to remove it and check it out. Thanks.
bigz1983 is offline
post #5 of 13 Old 07-15-2019, 10:09 AM Thread Starter
bigz1983's Avatar
Ok I will check that out. Thanks.
Someone told me clean all the grounds.
bigz1983 is offline
post #6 of 13 Old 07-15-2019, 08:38 PM Thread Starter
bigz1983's Avatar
I decided to take all the conduit off all the wiring on the left side of the tractor.
Dang it's a mess.
Whoever wired this sucks.
No crimp connectors nothing...
I got a IT manual for my OH 300 utility but strangely it doesn't have a wiring diagram.
Dang it now I gotta figure out this mess with no wiring diagram.
bigz1983 is offline
post #7 of 13 Old 07-15-2019, 08:44 PM
MARK (LI)'s Avatar
Check for continuity through that circuit breaker....if no continuity, replace it...then disconnect, clean and reconnect very wire terminal that you can find...rewiring it may be a good idea...without a diagram simply just change one wire at a time...use different colored wires to differentiate and use full lengths without connecting pieces in the middle...you can actually just try to install a 12v 40 amp relay switch that will help unless some connection is just not making contact at all
MARK (LI) is online now
post #8 of 13 Old 07-15-2019, 09:13 PM
I'd look online for a wiring diagram..
Replacing one wire at a time might work,but if the previous "electrician" put a wire where it doesn't belong,you'll be copying his mistake..
Tractor-Holic is offline
post #9 of 13 Old 07-17-2019, 10:16 PM Thread Starter
bigz1983's Avatar
I got the IH 300 utility fixed today.
She's running.
The cobble job "electrician" had spliced wires together by stripping back the coating and it corroded and broke.
I rerouted the wires direct to the battery instead of the starter post.
Looks alot cleaner now.
ID:	2387035   Click image for larger version
bigz1983 is offline
post #10 of 13 Old 07-18-2019, 07:10 AM
Retired & lovin it!
Newsman's Avatar
Glad you got it up and running.
MikeC
Newsman is online now
post #11 of 13 Old 07-18-2019, 07:22 AM
Kubota Ronin's Avatar
As long as you're already greasy, go ahead and service those ground connections.
They're every bit as important as the 'hots', and keeping them in just as good a condition will serve the machine and you well in years to come.
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
post #12 of 13 Old 07-18-2019, 09:55 AM
Joe
micah68kj's Avatar
Location: Pa. Transplant from the the great state of Wv.
+1 on the clean grounds. Very important.
Joe
micah68kj is offline
post #13 of 13 Old 07-18-2019, 07:45 PM Thread Starter
bigz1983's Avatar
Thanks for the advice guys.
I cleaned up the grounds with a dollar store wire brush set. Worked good.
bigz1983 is offline
