Mice vs. RV - Page 13 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
The Great Outdoors Hunting/fishing, Firearms, Shooting sports, Water sports, and Hiking and Biking... If you can do it outside.... Talk about it here!!!
post #181 of 192 Old 07-14-2019, 10:27 PM
Re: Mice vs. RV
Hi Mike, didn't realize you were online too.
Yeah if you have chipmunks you better get rid of them.
I have noticed that they will actually carry the baits away.
Fine with me I just keep feeding them till they are gone.
And you can put those bait chunks in your RV or where ever needed.
I keep some in my attic just in case.
And in the garage which is detached as well.
Be sure to wash hands afterwards.
Do tell of results if you try this.
Also the container says its not for anything but mice, voles and rats
and use is prohibited for any other such uses. I say BS.
It works and that's whats important!
Wlmitty is offline
post #182 of 192 Old 07-14-2019, 11:39 PM Thread Starter
Re: Mice vs. RV
I've been trying to avoid napalm (overdoing the poison and wiping out unintended animals). Another friend mentioned the big blocks when I told him that the mice I've seen eat D-Con like Chicklets and just keep coming (was actually much worse in the basement at my old house).
I'm also trying not to attract them closer (or worse, into) the RV.
I really can't believe that there isn't an exterminator that will service RVs around here. They'd make a fortune.
Mike
TRACTORS:
OTHER (NOTABLE) EQUIPMENT:
Echo PB751T backpack blower
Husqvarna 350 chainsaw
RETIRED TRACTORS:
mikeinri is offline
post #183 of 192 Old 07-15-2019, 12:38 AM
Re: Mice vs. RV
Don't know if we hit on this before but the d-con and stuff you buy for house use is weak n barely kill them.
You have to go to big box store or farm store and buy 4lb or larger to get the old ingredients.
2 different main good formulations of that too. The cheapest and most common is the same stuff that was in d-con for decades.
TobyU is offline
post #184 of 192 Old 07-15-2019, 10:17 AM
Re: Mice vs. RV
Also put some bait inside a 5 gal bucket with a small hole in the lid and a ramp walkway going up to the top of the bucket,
This will live trap the little critters and no dead stink when they die under something out of site. (which they will do when using poison) Takes a long time for dead mice stink to go away. When dead mouse stink first starts it smells like PROPANE.
To help reduce dead mice stink in a auto use fresh coffee grounds. You can review such on-line. Could not believe how well it works.
Forest Gump is offline
post #185 of 192 Old 07-15-2019, 11:09 AM
Re: Mice vs. RV
I've read people burn coffee to kill the stench of a dead body in a home that wasn't found right away...
I have had mice in many of the vehicles I bought in the past,they all sat for some time un-used,the grossest job in the world or one of the top ten at least,is tearing the vehicle apart to find all the nests,turds,and pee,and any live inhabitants and get rid of it all...
I have yet to find anything that completely eradicates that smell,some things mask it awhile but it usually comes back when the weather turns warmer..
My insulated truck body shed reeks of mice now,went in it a few days ago to get something and OMG...I bet every small engine I have stored in there has a nest in the blower housing now..stinks like death in there...
The aluminum diamond plate floor in it has developed holes around the steel screws holding it down to the steel rails,large enough for mice to crawl up thru,and my feral barn cats cant get in the truck body shed,only the lean to I built off of it next to it..they sleep in there,and I find a mouse corpse minus the brain once in a while in there--so far the tractors and engines in that area are mouse free thanks to the cats..even though the cats are getting quite old and probably cant catch them like they once could..
Tractor-Holic is offline
post #186 of 192 Old 07-26-2019, 03:44 AM
Re: Mice vs. RV
I am getting over run with chipmunks again this year. I've put out the 5 gal. bucket about 3/4 full of water and cover the surface with sunflower seeds. put a board up to the top and a few seeds on it and when they get to the top they think they've hit the mother load. They jump in and tread water for awhile till they tire out and drown. So far in the past two weeks I've killed 16 chipmunks and 28 mice that way' In the evening I put a little peanut butter on a piece of cardboard and lay it on top of the sunflower seeds and that attracts the mice at night. The most I've caught in one night is 5. At least two every night. In the morning before I empty the bucket I put more sunflower seeds on top and catch a chipmunk or two then that evening I empty the bucket and start all over. I have got a few chipmunks with my pellet gun. So far no mice in the RV but this past winter for the first time I got mice in my attached garage and in the house. I figure I'll keep trapping mice all summer, maybe keep them from reproducing so much. I set traps in my outbuildings and the garage.
I recently built a screech owl house. Still need to get it up in a tree. Hopefully it will attract them. They are very good for rodent control. Had some a few years ago but haven't seen any for awhile.
A friend of mine that lives a few miles from me had a toyota 4x4 pickup that he kept in his pole barn. He didn't drive it alot because he has a company truck. Back early spring he started it and pulled it out and let it run to warm up while he went back in the house and when he looked out the window the truck was on fire. It had several mouse nests under the hood on the engine and they caught fire. Total loss and the insurance paid off pretty good.
Just call me Larry
2012 JD X729, 62C deck, 45 loader, 54" front blade, Quick Hitch, Cat 1 3PH, Heavy Hitch. Heavy Hitch Forks. Heavy Hitch Sub Soil Ripper. Heavy Hitch sleeve hitch. 8 JD suitcase weights. 2-50# cast rear wheel weights. 4 home made 63# wheel weights. Front fork frame for 45 loader.
197? Economy Power King Model 1614 with tandem transmissions, hydraulics and 3PH and 48" mower deck.
Thread for 110 RF build https://www.mytractorforum.com/12-john-deere-forum/287161-66-110-rf-rebuild.html
1966 JD 110 RF, 580 TracVac, Home built log splitter, Stihl MS260 Pro Chain Saw,
Stihl BG85 Leaf Blower, Echo GT2400 Weed Whacker, 20KW Generac standby generator.
KWDAILYD is online now
post #187 of 192 Old 07-26-2019, 10:23 AM
Re: Mice vs. RV
I saw a 2016 Dodge Charger that was towed to my friends shop--wouldn't start..
He opened the hood and removed the big plastic cover over the engine intake and saw cotton batting sticking out everywhere...after a quick inspection of the wires going from the firewall to the engine,he found several were chewed in half...
He told the owner "I'm not qualified to repair something this new and complicated"..
Told him take it to a dealer,and make sure ALL the mouse nests were removed before starting it up!..
A woman I know also had a 2 year old Buick with less than 10,000 miles on it suffer the same fate..costed her a fortune to get a new harness installed ..
If car makers didn't use SOY based wire insulation,this probably wouldn't happen much..
Toyota is one of the worst offenders for using that type of wire..
I live about 400 feet away from a Toyota dealership,and I have heard they had several brand new ones in recent years that sat in the back of the lot quite some time,that wouldn't start or run right when someone went to take a test drive!..same issue..lots of wooded areas right between the dealership and my street..
post #188 of 192 Old 08-03-2019, 10:06 AM Thread Starter
Re: Mice vs. RV
No mice, or new signs of them, since early May.
... Until today... Signs in the sink and on the counter. Glue traps re-deployed...
We did spend about two weeks in there, cleaned out all the food but didn't vacuum or really clean the surfaces yet. Now I know what else I'm doing tomorrow.
Mike
TRACTORS:
RETIRED TRACTORS:
mikeinri is offline
post #189 of 192 Old 08-03-2019, 10:23 AM
Re: Mice vs. RV
Unfortunately next month is when they usually start looking for new places to nest for the winter...
I have been lucky so far,no mice have been in my house since last fall,no signs of any at least..,but I have heard some noises in the wall in my bedroom that may or may not have been the house settling from cooling down after a hot summer day..
post #190 of 192 Old 08-03-2019, 10:26 PM
Country1966?'s Avatar
We get mouse invasions every year. Trying this now 7 or 8 shots every evening before bed into the inlet of my AC/furnace. We here them in our ducts usually.
Makes the house smell like mint and it gets real good reviews on Amazon so we'll see.
https://www.amazon.com/Mighty-Mint-P.../dp/B07HYP6D5C
Massey GC2400
Gravely ZT HD 60" 24hp Kaw.
Old Troy Build Horse Tiller
Husky Snow Blower 24" 6hp
Not Enough Barn
Country1966? is offline
post #191 of 192 Old 08-04-2019, 11:49 AM Thread Starter
Re: Mice vs. RV
I'm not going to be spraying anything every day.
Went to replace my headlights today, opened the hood, and found this...
Mike
TRACTORS:
RETIRED TRACTORS:
mikeinri is offline
post #192 of 192 Old 08-05-2019, 08:44 PM
You don't have to spray it everyday
get yourself a small container like an old Altoids container or breath mint container cut slots in it.
put in a small cotton cloth in and spray it real good. fasten it into your engine compartment with either tape or zip ties. Spray once every couple weeks
Massey GC2400
Not Enough Barn
