What can I expect to pay for blasting / powder coating? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 11-19-2015, 10:51 PM Thread Starter
jdurnya's Avatar
Hey guys,
Have the usual tractor parts I need blasted / painted / powder coated.. Any rough ideas on costs? I.E. Fender pans, 54 plow, side panels, towers, etc.
Just want to go to blaster with some idea on how much it should cost..
Thanks,
Joe
Tractors:
And then there were only 3...
1995 John Deere 425 AWS
1991 John Deere 420
1990 John Deere 430
Implements:
JD 40" Tow Behind Core Aerator
JD 40" Front Mount DeThatcher
JD 47 Snowblower
JD 54" Quick Hitch 4 way plow x2
JD Model 80 Cart
JD Tow Behind Sprayer
Custom front weight bracket / hitch receiver
Custom 4x5 to 300 series frame adapter
Custom Winch
Former Machines:
1996 John Deere LX176 my first Deere
jdurnya is offline
post #2 of 12 Old 11-19-2015, 11:08 PM
Wrascal's Avatar
Re: What can I expect to pay for blasting / powder coating?
This is comparing apple jacks to peanut brittle but here goes ...
Last spring I had a fifth-wheel tailgate made for my truck. Locally it cost me $50 to have it powder-coated. My prior guess going in was up to $150 I'd approve, anything over that I'd visit a regular body shop for a paint job.
So what's it worth to you?
2014 x310
2007 x540
Wrascal is offline
post #3 of 12 Old 11-19-2015, 11:40 PM
crawler's Avatar
The current condition will really dictate the price. Sandblasting can run as much as the powdercoating.
I took a pretty nasty set of 15x10 wheels in, and it cost $110 for gloss white.
I took 4 new heavy bike wheels, 2, candy apple red metal flake, two silver metal flake, and a bike seat in hammered copper, cost me $70.
All the air vents in my house cost me $120 to do (size not available now, can't replace them).
I made a 2' square metal magnet board for my nephew, cost me $40 for hammered copper.
I would paint the plow if I were you. You're going to knock any finish off, and paint is an easy fix.
I'm powdercoating my whole tractor and loader, but the bucket and forks will be painted so I can touch them up.
'90 JD 318 - 50" deck, 54" blade, H3, 3pt
'68 Bolens 1250-02 48" deck, tiller
Bolens HT 20/23 54" deck, 54" blade
Bolens HT 23 - loader in work, 60" deck
crawler is offline
post #4 of 12 Old 11-20-2015, 01:24 AM
Senior MTF Pollster
Austen's Avatar
It can also depend upon how many different colors your doing. For example if everything is going to be one color (which it probably won't) price will go down. Other than prep work costs (like sandblasting), the other biggest influential cost factor is the number of colors.
Is everything taken apart I assume? If not, you'll want to take pieces apart to avoid dissassembly charges by the shop.
Ask the shops you're getting price quotes from if it's possible to combine your parts in with an existing order doing the same color. Often times shops- especially when you're powdercoating, will offer you a discount if add your parts in with someone eles's order assuming you're doing the same color.
Bolens HDT1000 #11- Coming eventually!
1977 Economy Tractor
Hydraulic lift conversion
24" model front king pins
48" Belly mower
32" tiller
3pt hitch
"So I say to you, ask, and it will be given to you; seek, and you will find; knock, and it will be opened to you." - Luke 11:9
Austen is offline
post #5 of 12 Old 11-20-2015, 01:47 AM
crawler's Avatar
Good call, except for custom colors, I just wait until they do a run of the color I want.
crawler is offline
post #6 of 12 Old 11-20-2015, 05:48 AM
I had a 44 inch Bercomac Snowblower that I was going to get powder coated, There were 6 or 7 parts and they were solid, but pretty rusty. I was quoted $500 to sandblast and powder coat everything.
John Deere 320
John Deere 345
Lots of attachments
Seane1987 is offline
post #7 of 12 Old 11-20-2015, 07:48 AM
No Quarter's Avatar
I just had a fender pan done. It cost $175 and I supplied the powder.
1946 Gibson Model A w/WI 5.9hp
1984 John Deere 318 w/Onan 18hp
1989 John Deere 420 w/Onan 20hp (2)
1990 Craftsman GT6000 w/Briggs 18hp (2)
No Quarter is online now
post #8 of 12 Old 11-20-2015, 08:35 AM
devans's Avatar
I built a custom headache rack for my truck and was quoted $200 per hour for sand blasting and $300 for the powder coat.
I painted it black for less than $50.
Don Evans
I thought I had G.A.S. under control, I was Gravely mistaken
1963 L8 - Under reconstruction M 96599, M# G-5451
1972 816
1973 408 rider
1973 C - Parts tractor S/N 88418
1973 C8 - Current workhorse
1983 5200 - Current workhorse
30" Quick hitch mower
30" 106 mower
MA-210
48" plow blade
Restored Estate Sulky
Restored Standard Sulky
Lawn Roller
Pull behind dump cart
Chain guard for the 30" mower
Rotary plow
Haban sickle mower
Kwik way loader
Wish list 3/4's of a mile long
devans is offline
post #9 of 12 Old 07-02-2018, 09:53 PM
Pay2play's Avatar
I was quoted $175 for the heat "run" and approximately $100 for materials. That should do the pan and side covers, hopefully grill too. I need to get them the parts to be sure of actual cost. Not sure about the sand blasting cost yet.
Pay2play is offline
post #10 of 12 Old 08-16-2019, 12:33 PM
HD
HDmstng's Avatar
I paid about 300 for stripping and powder coating of my troy bilt horse tiller. Everything was taken apart prior.
Sent from my SM-G950U using Tapatalk
1985 John Deere 318
1973 Troy Bilt Horse I Tiller
HDmstng is offline
post #11 of 12 Old 08-21-2019, 02:35 AM
I have plan to paint my tractor too. I have already bought powder coating and step ladders for it. Because My tractor is high and I need to use ladders for painting it. Plus ladders like here in review https://abovethefloor.net/ I can use in other house works.
grumpty is offline
post #12 of 12 Old 08-21-2019, 03:39 AM
You are going to powder-coat your entire tractor?
dave_r is online now
