Sunbeam Grillmaster - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 20 Old 09-03-2019, 08:16 PM Thread Starter
Sunbeam Grillmaster
I am replacing the burner in a gas grill that my mother gave me and noticed there was supposed to be a drip guard that covered the inlet tubes of the burner. The drip guard had completely rusted away which caused the inlet tubes to rust out right at the burner, it’s all one piece so even thought the burner looked good, it is no good because of the rusted out inlet tubes. I ordered a replacement burner but could not find the little drip guard so I made my own. I took an old cookie sheet type of baking pan that my wife was throwing away, measured the space I needed to fill over the inlet tubes, measured it all out on the pan and took some tin snips, (aviator snips), and made the drip guard. The pan was a heavier, thicker metal so I figure it should last a while. When I get the new burner, I will make adjustments to my homemade drip guard and then drill some holes for self tapping screws to secure it in place. So, if ya can’t find what ya need, sometimes you can just make what ya need.
HobieMarty is offline
post #2 of 20 Old 09-03-2019, 09:45 PM
JeffBen's Avatar
Re: Sunbeam Grillmaster
Had to retire my sunbeam grillmaster just last week do to same issues.
JeffBen is offline
post #3 of 20 Old 09-03-2019, 10:40 PM
Don
I had one of those 25 years ago and it seems to me there was a hole at the bottom of the grill in the middle where I had a coffee can hanging collecting the grease.
Don
post #4 of 20 Old 09-04-2019, 08:57 AM
Choke's stuck on!
robhay2's Avatar
I work in a lab with sheet metal fab equipment. I've seen a lot of "government job" drip guards walk outta here!
One note: since you used a coated non-stick pan make sure to have a nice hot fire without cooking food to burn off any coatings (nasty). 15 minutes should do it.
Nice job with the tin snips BTW!
robhay2 is offline
post #5 of 20 Old 09-04-2019, 04:26 PM Thread Starter
Thanks for the replies. It’s not a non-stick pan by the way, it was all metal with no non stick material on it anywhere. It had a little surface rust on it so my wife wanted to throw it away. I actually had it in the cabinet under the kitchen sink to be thrown out and forgot about it and had been sitting in there for a few months. When I thought of making my own guard, I remembered that the pan was still in the cabinet, thank goodness I had not thrown it out as it’s some pretty good metal and I think that it should last a while. This grill has two drip pans under the burner. Each pan has a hole in the center and hangers for a can to collect grease. Also, the burner in the picture is the old one, I put it back in there for fitting the homemade guard.
Thanks for the compliment about the tin snips, I took a sheet metal class many years ago to learn how to make duct work and I suppose I actually retained some “learnins”. Lol.
Oh yeah, my Mother told me the grill is about 20 years old also. I will post pics of the progress.
post #6 of 20 Old 09-04-2019, 07:43 PM Thread Starter
Getting ready to freshen up the paint a bit. Wet sanded the front to get some old tape residue off. I used some “Goof Off” first but it just wasn’t doing the job so I wet sanded it all off. Also going to scrape out the inside and clean it up a bit to get ready for the new burner. Making progress.
post #7 of 20 Old 09-05-2019, 01:28 PM
Choke's stuck on!
robhay2's Avatar
We had a grill similar to this (maybe the same model) when I was growing up. My dad did a similar restoration on it a few years ago and I was glad he did rather than buying a HD throwaway.
robhay2 is offline
post #8 of 20 Old 09-05-2019, 09:21 PM Thread Starter
Ain’t that the truth, take care of something at it will last you many years.
Here is the first coat of satin black, ran out of paint, got some more and will finish it up tomorrow. The temperature gauge was coming apart so I cleaned it up a little and glued it all back together with some “waterproof” Loctite gel glue. I will see how long it stays together and may have to replace it later. Tomorrow I will scrape out the inside and vacuum it all out again, hopefully will be grilling this weekend.
post #9 of 20 Old 09-06-2019, 04:55 PM Thread Starter
Got the new burner today and funny thing, it came with the drip guard/shield!!! It wasn’t in the listing when I ordered the burner, but oh well, bonus prize!!!
Sprayed a second coat of satin black and getting ready to put it all together.
post #10 of 20 Old 09-06-2019, 10:56 PM Thread Starter
It lives again!!!! Spent the day finishing up the grill and cooked some burgers!!! Maybe I will get a few more years out of this old grill. Keep em burnin!!!
Sent from my SM-N950U using Tapatalk
post #11 of 20 Old 09-06-2019, 11:13 PM
Don
It seems to me mine had an electric rotisserie. A little motor with an electrical plug. You plug it in and it would rotate. You notice the holes in the hood?
Don
post #12 of 20 Old 09-07-2019, 07:26 AM Thread Starter
Yep, I have a rotisserie also. Pretty cool!!!
post #13 of 20 Old 09-09-2019, 05:29 PM
Choke's stuck on!
robhay2's Avatar
Nice! What is the stick for?
robhay2 is offline
post #14 of 20 Old 09-10-2019, 01:17 AM
Probably for keeping people away until the food is finished being cooked...
dave_r is online now
post #15 of 20 Old 09-10-2019, 06:03 PM
10,000 +posts!
glenn27's Avatar
Nice job! Re-purpose and re-use...So many companies nowadays-do NOT make replacement parts for the very thing you just did.....
Bah-humbug to these people....
BTW--have you tried those copper grill mates for the grates? Saves a lot of clean up and flare ups...
glenn
Jimmy Buffett
glenn27 is offline
