new to me Lawn-Boy mowers... - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 31 Old 09-29-2019, 03:29 PM Thread Starter
spokes100's Avatar
Smile new to me Lawn-Boy mowers...
I picked up 2 Lawn-Boy mowers today. Both with steel decks from the Toro era I think.
One is a 1997 push model #10227 serial #7933253 (free). The other is a 1998 self-propelled model #10323 serial #8929831 ($25). The 10227 turns over with compression but hasn't been started in a year. The 10323 is in unknown condition. It was left outside, overgrown with weeds and "discovered" by the new home owners of an abandoned house I believe. Even when holding the blade handlebar lever it pulls over hard, feels like little compression and when I pulled the plug it was whiskered, probably was seized.
I understand the 10227 has the "V" engine and is more Lawn-Boy and more desirable than the 10323 which has the DuraForce EPA1 engine which is more Toro. Do you agree?
I'll clean up and do some preliminary maintenance to the fuel system and just generally go over the 10227 first as I'm thinking it's much closer to running than the 10323.
Any insight you guys can offer would be appreciated. One question I have right off is what sparkplugs do you like. The 10227 has an NGK BPMR4A in it. The 10323 has a Champion CJ14.
ID:	2398079   Click image for larger version
ID:	2398081   Click image for larger version
ID:	2398083   Click image for larger version
ID:	2398087   Click image for larger version
spokes100 is offline
post #2 of 31 Old 09-29-2019, 06:43 PM
Re: new to me Lawn-Boy mowers...
The 1998 10323 I own has a Lawn Boy made Duraforce engine. I also have a 1995 Toro 2 stroke push mover that definitely uses a Lawn Boy built V engine. I do not think Toro has ever built their own engines from the beginning up to the current time. Over the years Toro has used Clinton, Lauson, Briggs, Tecumseh, Power Products, Lawn Boy, Suzuki, Kawasaki, Honda and is now using Chinese Honda clone engines. I may have missed some. For spark plug I use hat the owners manual says both the brand and number. Roger
rhenning is offline
post #3 of 31 Old 09-29-2019, 07:08 PM
LawnBoy90's Avatar
The 10227 should have a Champion RJ12C or NGK BR6S. The current plug in it can be used on the 10323 if it's in good shape. Gapped at .035". For the 10227 you'll want to remove the mounting screws and add some loctite to them. V series mowers tend to get loose so it's a good measure. Check the carb for warpage at the flange as well. The 10227 has the nice thrust bearing in the bottom of the crankcase so it's smoother running than previous Vs.
Mowers:
1970 - 5239 (D-408)
1973 - 3058 (D-433) (Rebuilt)
1974 - 8251 (D-480)
1975 - 5273 (D-601) (Rebuilt)
1982 - 7071 (F-101) (Custom)
LawnBoy90 is online now
post #4 of 31 Old 09-29-2019, 07:10 PM
LBAD Victim
LawnToro's Avatar
Either plug is acceptable.
I would take a DuraForce engine over a V any day. Better built engine in my opinion.
Old LawnBoys rock. Need I say more?
Stihl
2000 Stihl FS85
1995 FC44
2015 FS56rc-e
TORO
2019 25.4cc powerhead
2016 721R-C
2018 Super Recycler 20381
2008 Super Recycler 20093
Other
2005 Husqvarna 123L
2008 Poulan Pro PP335
2018 Masterforce 20V trimmer
2017 Black and Decker Battery hedge trimmer
2014 Scotts Sync 20V trimmer/blower combo
MTD
2017 Troy Bilt TB230 ($30 at Lowes!)
1995 Craftsman Hedge trimmer
Lawn Boy
1980 8070
2001 10247
LawnToro is offline
post #5 of 31 Old 09-29-2019, 09:10 PM
2 strokes forever!
Evans Ward's Avatar
DF for me too. I’ve owned Vs before and they sound like they are ready to let loose at any time. A rejetted DF will almost mow anything down.
Evans Ward
Macon, GA
'94 LB 10515
'98 LB 10525
'01 Toro Commercial Proline 22043
'88 Snapper Wisconsin Robin 2 cycle WT-1 125v
Plus 4 vintage 2 stroke streetbikes
Evans Ward is offline
post #6 of 31 Old 09-29-2019, 09:25 PM
I have not used/owned a V motor but my DuraForce is a beast. Don't knock it 'til you've tried it, as the saying goes.
TheSteelGator is offline
post #7 of 31 Old 09-29-2019, 10:39 PM
95lawnboy's Avatar
Nice finds for sure. I have owned many of both of those mowers, and everybody on here knows I favor the V engines, but I ran a couple 10323s for a few years and they were far more reliable than any of my Vs and slightly more powerful. By no stretch of the imagination is the V engine more desirable than the DF, from my experiences here on the forum and selling on Craigslist I would say just the opposite. I always run champion CJ8s in my duraforces, I like the Bosch plugs in my Vs, the recommended CJ12s are a little longer and get in my way when switching from bagging and mulching etc. That said, the 10314 I ran for the last year had an old rusty RJ19LM in it when I got it, and it runs perfectly and is burning the perfect color. I wouldn’t worry too much about plugs.
Getting the 10227 ready to go, like somebody above mentioned, make sure the carburetor isn’t warped with a straightedge. Make sure the governor is still intact where the throttle cable pushes and pulls on top of the carb, I've had to super glue the metal guide to keep it from popping out. Make sure the engine and baseplate are tight, use loctite as necessary. Same with the bolts for the recoil shroud and it’s mounting plate. Pull the muffler, check the ports, make sure the baffle is good and tighten it good. I’ve had many muffler bolts vibrate out into the blade (not a good time). If you have that trouble, a good idea is to take a couple little strips of metal, drill holes for the muffler bolts, and fold the ends over the flats on the bolt heads as lock tabs. If you have the blade off, make sure you time it to rise and fall opposite the piston (set the piston at TDC and put the blade perpendicular to the cylinder). It makes a big difference with vibration. If you notice excessive side play in the crank, the crank bearings often go bad in those motors as well, not a huge deal but something to note. There’s nothing you can do about end play, every V has the “thunk” when you squeeze the bail, but for that reason I always let mine out slowly. Hopefully some of this information is useful, I have a shed full of Vs so I have a lot so say about them...lol...good luck getting yours going
1993 10301
1994 10312
1995 10311
1997 10314 (x2)
1996 10651
2017 HRR216
2006 Echo GT200R
2005 Echo GT251
2016 Echo SRM225
2019 Echo SRM266
95lawnboy is offline
post #8 of 31 Old 09-30-2019, 09:09 AM Thread Starter
spokes100's Avatar
Thank you for all the replies and info, I'll update this thread as I go along, I'm not in any hurry so it may take me time but we'll get these two going like new.
post #9 of 31 Old 09-30-2019, 11:04 PM
Yard Nazi's Avatar
Talking Re: new to me Lawn-Boy mowers...
I am not familiar with the V series. Are they more similar to the F series or the Duraforce? If more similar to the F series the Lawnboy manual recommends orienting the blade on an F series parallel to the piston, not perpendicular. The D series are oriented perpendicular. Please confirm for future reference. Thanks! Bill
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1978 Lawnboy Model 5269G
1979 Lawnboy Model 7268******1980 Lawnboy Model 5247******1982 Lawnboy Model 5247
1982 Lawnboy Model 5247*******1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is online now
post #10 of 31 Old 10-01-2019, 09:50 AM
The Vs are a bit of a hot rod F series. I believe some of the Duraforce developement was done by Tecumseh in the 1990s. Never seen anything about blade position. Roger
rhenning is offline
post #11 of 31 Old 10-01-2019, 10:14 AM Thread Starter
spokes100's Avatar
I have a owners manual (downloaded). It doesn't say anything about blade orientation as 95lawnboy mentioned but it is something easy enough to try so I think I will. I've started the clean up, will post pictures, before and after later today.
post #12 of 31 Old 10-01-2019, 04:16 PM Thread Starter
spokes100's Avatar
Started cleaning things up yesterday. Previous owner said it smoked a lot. Clogged air cleaner and two out of three exhaust ports were plugged. Blade actually doesn't seem worn, don't know how long he had it or how much he used it. Everything came apart easily. Exhaust bolts were all loose, one almost ready to hit blade. Don't think he ever cleaned exhaust or sharpened blade.
ID:	2398359   Click image for larger version
ID:	2398361   Click image for larger version
ID:	2398363   Click image for larger version
ID:	2398367   Click image for larger version
ID:	2398369   Click image for larger version
ID:	2398371   Click image for larger version
post #13 of 31 Old 10-01-2019, 06:29 PM
95lawnboy's Avatar
I have the service manual somewhere and I believe it was mentioned in there. Not 100% sure but it sure works for me. You are correct about the F series being timed in line with the piston. The V engine is just an F crank, piston and rod in a differently shaped block, but a bit of a different animal.
1993 10301
1994 10312
1995 10311
1997 10314 (x2)
1996 10651
2017 HRR216
2006 Echo GT200R
2005 Echo GT251
2016 Echo SRM225
2019 Echo SRM266
post #14 of 31 Old 10-01-2019, 08:08 PM
Yard Nazi's Avatar
Section 9, page 13, in the online service manual. Also it is in the Lawnboy Service Manual in print. Bill
https://lookup3.toro.com/ttcGateway/...ls/lball40.pdf
post #15 of 31 Old 10-01-2019, 10:37 PM
95lawnboy's Avatar
The link you posted is just for the D and F engines tho,
I just checked the V service manual and from what I see it just says install the blade and torque it. Not sure where I heard that, but it sure works. Again I totally agree the F should be timed in line with the piston. I’m definitely not a “by the book” mechanic just saying what has worked well for me.
1993 10301
1994 10312
1995 10311
1997 10314 (x2)
1996 10651
2017 HRR216
2006 Echo GT200R
2005 Echo GT251
2016 Echo SRM225
2019 Echo SRM266
huffords
