D Series Gear Drive Question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 09-10-2019, 04:15 PM Thread Starter
LawnBoy90's Avatar
Does anyone know which side the thrust washer goes in on the gear drive D engines? before the gear or after? I have a D-400 gear drive short block I'm going to use on my recently failed 7260B (rod cap was cracked luckily it didn't blow up) and I forget what order the gear and thrust washer go in and I don't want to nuke this one either. Thanks!
Mowers:
1970 - 5239 (D-408)
1973 - 3058 (D-433) (Rebuilt)
1974 - 8251 (D-480)
1975 - 5273 (D-601) (Rebuilt)
1982 - 7071 (F-101) (Custom)
LawnBoy90 is online now
post #2 of 9 Old 09-10-2019, 05:09 PM
4K Poster!!!!
Lawnboy77's Avatar
Re: D Series Gear Drive Question
I'm not sure that you can use a D-480 short block on a pusher 7260B without some mods. It might be better just to use the individual parts from the D-480 and install in the D engine of your 7260B. What did you plan on doing with the drive shaft hole in the crankcase? It would seem to me that you would have to just plug the hole somehow, since the driveshaft will have nothing to connect to on a pusher D-400. The jug, piston and rod should all be the same part number for both engines so what about just replacing those parts and leaving the crank and crankcase original?
Edit: The D-480 shaft drive engine also mounts rotated 45 degrees from the standard D series so not sure what problems that would present.
Lawnboy77 is online now
post #3 of 9 Old 09-10-2019, 05:42 PM Thread Starter
LawnBoy90's Avatar
I have a muffler plate for a D-600 and parts for the capstan setup to make this a functional D-480 powered 825- series mower. I originally used parts from a previous 8251 I parted out. However I figured I would resurrect the 8251 and use the crankcase on another dead mower of mine. It had the extended snout crankcase on it but I don't have a clean enough crank for the bottom seal to seal properly and with the parts I have it'll only cost me new bottom end gasket and PTO seal which isn't too much.
Mowers:
1970 - 5239 (D-408)
1974 - 8251 (D-480)
post #4 of 9 Old 09-10-2019, 05:50 PM
4K Poster!!!!
Lawnboy77's Avatar
Okay I understand now...you are converting the 7260B pusher into a shaft drive SP. Sounds like a good plan! As for the order of assembly, I would just go with what the parts catalogue says. I'm not sure if there is a manual that covers the shaft drive setup, but I'll be there is a service manual that would cover those. I don't think I have any reference that covers that, I'll look for anything and post pictures on this thread about the shaft drive setup. Old Lawnboy (Bill) probably has something on it.
post #5 of 9 Old 09-10-2019, 06:19 PM
old lawnboy's Avatar
ID:	2395709See attached page, bottom left side.
old lawnboy is offline
post #6 of 9 Old 09-10-2019, 06:36 PM Thread Starter
LawnBoy90's Avatar
My bad I should've explained that first! When I first got the engine I thought the washer was after the gear but it does look like the washer goes first then the gear. It seemed to function okay in both spots so that's why I was confused. I'll get some pictures soon taking a break for now.
Mowers:
1970 - 5239 (D-408)
1974 - 8251 (D-480)
post #7 of 9 Old 09-10-2019, 06:47 PM Thread Starter
LawnBoy90's Avatar
Originally Posted by old lawnboy View Post
Attachment 2395709See attached page, bottom left side.
Thanks for coming through old lawnboy! By stationary pin are they talking about the PTO shaft or something different? I didn't see anything sticking out in there but will check again. The washer for my mower appears to be p/n 608363 not the 608030 that is listed on that page. That parts viewer shows the washer coming before the gear and when I got the machine I think it was behind. So maybe the PO did some repair work on it who knows.
Mowers:
1970 - 5239 (D-408)
1974 - 8251 (D-480)
post #8 of 9 Old 09-11-2019, 10:08 AM
ID:	2395777 The picture with thrust washer and gear is correct. Gear should line up with the center of crankshaft. Part number 608363 is thrust washer for crankshaft that went into the crankcase prior to inserting the crankshaft. I can not find any information showing the 608363 thrust washer but I have 15 of the in stock and they are for crankshaft as the attached picture will show their size. The thrust washer is cast into later crankcases and the earlier version using the 608363 was not available after the cast in version was made.
post #9 of 9 Old 09-12-2019, 07:01 PM Thread Starter
LawnBoy90's Avatar
Attachment 2395777 The picture with thrust washer and gear is correct. Gear should line up with the center of crankshaft. Part number 608363 is thrust washer for crankshaft that went into the crankcase prior to inserting the crankshaft. I can not find any information showing the 608363 thrust washer but I have 15 of the in stock and they are for crankshaft as the attached picture will show their size. The thrust washer is cast into later crankcases and the earlier version using the 608363 was not available after the cast in version was made.
Oh okay! I thought that's what they were talking about. The driveshaft washer that came with this mower doesn't seem like the one I had in my parts because it's pretty thin. The one in the picture looks a little thicker. I found one that matches pretty well and have it installed. Couldn't get to pictures today but I followed the order shown in the parts drawing so I should be good now. We'll see soon. I'm waiting on the gaskets and seal and the heat to die down to get this project finished up. Thanks old lawnboy and LawnBoy77!
Sent from my XT1710-02 using Tapatalk
Mowers:
1970 - 5239 (D-408)
1974 - 8251 (D-480)
