Cracked engine sumps - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 08-17-2019, 01:32 AM Thread Starter
Gravely 2-wheeler
I have two mowers, MTD w/B&S550ex and Husqvarna w/B&S625e, where the engine sump that is bolted to the mower deck is cracked on the upper surface from the outside of the flange near a mounting bolt towards the middle of the sump. They only have 3 or 4 mounting bolts which do not appear to offer enough support when the mower sees heavy use. These mowers are used in foot tall thick weeds with occasional hidden branches or rocks. The tall weeds are unavoidable since I can't keep up with mowing at this location and several areas are only mowed once every year or two. (A landscaping service mows the good lawns and I get the rest.) The one advantage of these mowers is that they are baggers which means a clean "lawn" after one pass. My Gravelys can handle the tall grass with no problem but then I have to rake to clean up.
Rather than replacing the sumps I am planning to clean and JB Weld the cracks and bring the total number of mounting bolts to 12 evenly spaced around the flange.
Paul L
Gravelys: 1950 L, 1954 L, 1968 Comm 10A, 1969 C8, 1971 C8, 1984 5665
1967 430, 1969 432, 1980 8122
Craftsman 917.270670
PaulL is offline
post #2 of 13 Old 08-17-2019, 11:53 AM
LBAD Victim
LawnToro's Avatar
Re: Cracked engine sumps
That is a very common issue on those newer Briggs. If you are mowing tall weeds, I would look at a wheeled string trimmer.
Old LawnBoys rock. Need I say more?
Stihl
2000 Stihl FS85
1995 FC44
2015 FS56rc-e
TORO
2019 25.4cc powerhead
2016 721R-C
2018 Super Recycler 20381
2008 Super Recycler 20093
Other
2005 Husqvarna 123L
2008 Poulan Pro PP335
2018 Masterforce 20V trimmer
2017 Black and Decker Battery hedge trimmer
2014 Scotts Sync 20V trimmer/blower combo
MTD
2017 Troy Bilt TB230 ($30 at Lowes!)
1995 Craftsman Hedge trimmer
Lawn Boy
1980 8070
2001 10247
LawnToro is online now
post #3 of 13 Old 08-17-2019, 12:55 PM
Senior MTF Poster
JB Weld will not hold.
Walt Conner
Walt 2002 is online now
post #4 of 13 Old 08-17-2019, 01:21 PM
+1
I think that there are a number of JB Weld victories declared on this forum and others that don't last long. This has the makings of one. You may get some use out of it, but IMHO, it will be a ticking time bomb.
denverguy is offline
post #5 of 13 Old 08-17-2019, 06:34 PM
JB weld won't work long term or maybe not even at all.
I have only seen damage or cracking on these when there is a blade strike.
I am not liking the new briggs ohv and don't expect them (I'm sure B&S doesn't either) to be around like the old L heads.
Had 4 old ones this week go back to customers running perfectly. Two 1999's and two 1995's.
These new ones clog up the carb easier(epa shares a lot of blame for this) have surging issues that don't always go away, have weaker crankcases, and I think they all have a plastic cam gear on the camshaft!!!
They are the easiest and shortest pull required to start ones I have ever seen just edging out the old Tecumseh easy start...
Typical!!! Market for user friendliness and fake or on paper features and NOT durability or longevity.
TobyU is offline
post #6 of 13 Old 08-17-2019, 06:37 PM
I have to say....even though the old mowers might have gotten by for a good long time mowing overgrown fields of foot tall weeds and rocks and sticks.....no mower is made for this.
Many people do use mowers as brush hogs and it's not really something any mower should be asked or expected to do.
TobyU is offline
post #7 of 13 Old 08-17-2019, 08:44 PM
Joe Naab's Avatar
Send a message via AIM to Joe Naab Send a message via MSN to Joe Naab Send a message via Yahoo to Joe Naab
JB weld? No way, it will never hold. Poor design you just can't fix. Too bad they never made a cast iron vertical motor. But then I'd suppose the deck would start to crack. You can keep improving poor engineering but the weakest point will always win.
Ariens GT20 with lots of attachments to play with
New Holland L325 Skid Loader (money pit) with new Kohler K582 mini block, standard q. attach and likes to flip forward
Joe Naab is offline
post #8 of 13 Old 08-17-2019, 08:53 PM
Any pictures of this crack??
TobyU is offline
post #9 of 13 Old 08-17-2019, 09:24 PM
LBAD Victim
LawnToro's Avatar
I should also mention that Almost every puch mower uses 3 or 4 mounting bolts. Even the old 1960's lawn boys have only 4 mounting bolts, and I have never had an issue with them holding.
Stihl
2000 Stihl FS85
1995 FC44
2015 FS56rc-e
TORO
2016 721R-C
Other
2005 Husqvarna 123L
MTD
Lawn Boy
1980 8070
2001 10247
post #10 of 13 Old 08-17-2019, 10:14 PM
Drilling more holes will only weaken it, there is not enough material. The three bolt system has worked well for many years, they are lawn mowers not brush hogs.
RoyM is offline
post #11 of 13 Old 08-18-2019, 04:22 PM
lawnboyben's Avatar
Why don't you just cut it down first with your gravely and then suck up the clippings with a push mower? To me that seems like the easiest solution.
Lawn-Boys
1991 C21ZPN
1994 10520
1995 10545
1999 22261
Blowers
Echo PB-400E
Husqvarna 125B
Trimmers
Husqvarna 128LD
Echo SRM-2400
Echo SRM-210
lawnboyben is offline
post #12 of 13 Old 08-19-2019, 10:20 PM
old lawnboy's Avatar
These engines will last a long time if properly used. My experience with them is if used for normal everyday use they are good. Broken sump flanges usually come from bent blades and or bent crankshafts. The crankshaft length is long and it does not take much to bend it if the blade strikes something. This causes excess vibration that works one or more of the bolts loose and eventually breaks the sump flange. Even blades that are straight but out of balance can do this. These are walk behind lawn mowers, not Army tanks. If you are going to be hitting water meter covers, drain culverts and bricks and large stones you can expect these problems.
old lawnboy is offline
post #13 of 13 Old 08-29-2019, 06:16 PM
Hmmn mebbe 30$ for 2 basket case F series to keep the 10415 and 7073 going wasn't a dumb idea. after all. Plus I have a Toro 3 spd with a sick Tecumseh? and a great same engine and worn out 1 spd. on my back up LB I also have a Dura Force with the same 1 spd.. I have yet to break a LB or a Toro walk behind beyond repair. And in my early days learning, I was guilty of small engine abuse. Sheared a few keys chewed up blades ran w/o air cleaner. Bent cranks, etc. But for a thrown rod, I never cracked a case. That's just cheep. No wonder you don't need to change the oil. Thanks for heads up. I have some good quality old stuff. Built by Americans. My fellow baby boomers back in the 80's
andyma is offline
