What goes around, comes around! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 21 Old 08-05-2019, 06:52 PM Thread Starter
Yard Nazi's Avatar
Talking What goes around, comes around!
Hi all! Well today I picked up another 19" Lawnboy, model 5269G, from 1978. Here is the story. A few years ago one of our members, Peoria Murph, was downsizing and offered several mowers that he wanted to pass along. Made the trip down and brought the mowers back, one of which was the 5269G. This was given to Riley (LawnToro) along with another mower and the 5269G eventually went to Riley's grandpa. Fast forward to today and Riley decided his grandpa was going to part with the 5269G and I offered to take it back off his hands so now it is back home with me. This is a D-409 engine and the carb was already replaced with the metal Lawnboy carb and proper reed plate. The mower came back to me with the rope stuck on the starter so after a bit of cleaning, starter repair, double checked the governor setting, etc., it starts and runs great. Thanks in order to Murph, Riley, and Grandpa. I will enjoy using this one as well. As per the rules here are the pictures. Bill
Name:	1978 Model 5269G #1.jpg
ID:	2389711   Click image for larger version
Name:	1978 Model 5269G #2.jpg
ID:	2389713   Click image for larger version
Name:	1978 Model 5269G #3.jpg
ID:	2389715   Click image for larger version
Name:	1978 Model 5269G #4.jpg
Name:	1978 Model 5269G #5.jpg
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1978 Lawnboy Model 5269G
1979 Lawnboy Model 7268******1980 Lawnboy Model 5247******1982 Lawnboy Model 5247
1982 Lawnboy Model 5247*******1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is offline
post #2 of 21 Old 08-05-2019, 11:55 PM
4K Poster!!!!
Lawnboy77's Avatar
Re: What goes around, comes around!
Wow! Looks perfect!
Lawnboy77 is online now
post #3 of 21 Old 08-06-2019, 10:36 PM Thread Starter
Yard Nazi's Avatar
Talking Re: What goes around, comes around!
Okay I do have a question about this mower. I believe I am missing a part. Part number is 608810. It is called a spring bar. I think it is to hold the 2 speed lever up in place. Must clip under the back bottom of the shroud. Anyone care to weigh in here before I order one? Just wanted to find out how it is attached and what holds it in. Maybe since it is called a spring bar, spring tension holds it in. I know on the newer D600 series they used a rubber grommet. Thanks, Bill
post #4 of 21 Old 08-07-2019, 03:45 AM
AnthemBassMan's Avatar
Nice, clean Lawn Boy!
L8R,
Matt
1973 Lawn Boy 7262
1975 Lawn Boy 5024 Bricktop
Echo CS-370 Saw
Poulan P1500 Trimmer
AnthemBassMan is offline
post #5 of 21 Old 08-07-2019, 08:08 AM
old lawnboy's Avatar
The spring bar is a metal piece of spring material similar to what the recoil spring is made of except a little heavier and narrower and a little over 1 inch long that fits in the notch in the shroud to keep the speed adjuster from dropping out. I think I still have some if you can't find one locally. PM me if needed.
old lawnboy is offline
post #6 of 21 Old 08-07-2019, 12:57 PM
LBAD Victim
LawnToro's Avatar
You are missing that part. I remember you and I discussing that when we fixed it the first time a couple years ago. It is a spring bar that is missing.
I am glad to have been able to pass that mower along to someone who can use it. It served me and my grandpa very well over the last 2 years. The steep hill that my grandpa has is super hard on the 4 cycles unless they are pressure lubed. Plus, the lack of weight was really nice.
Old LawnBoys rock. Need I say more?
Stihl
2000 Stihl FS85
1995 FC44
2015 FS56rc-e
TORO
2019 25.4cc powerhead
2016 721R-C
2018 Super Recycler 20381
2008 Super Recycler 20093
Other
2005 Husqvarna 123L
2008 Poulan Pro PP335
2018 Masterforce 20V trimmer
2017 Black and Decker Battery hedge trimmer
2014 Scotts Sync 20V trimmer/blower combo
MTD
2017 Troy Bilt TB230 ($30 at Lowes!)
1995 Craftsman Hedge trimmer
Lawn Boy
1980 8070
2001 10247
LawnToro is online now
post #7 of 21 Old 08-07-2019, 04:39 PM
ReedZ's Avatar
Clean looking mower. Likely get many more years out of it.
Iíve used a piece off of a damaged recoil spring I have kicking around and just cut it to length to fit. Iíve done this twice now with good results.
1952 LB 8T10, 1954 LB 8T14, 1955 LB 8F20K, 1956 LB 7000, 1957 LB 3100, 1957 LB 8S11LB, 1957 LB 5100, 1957 Marauder 89MH, 1958 LB 5150, 1959 LB 5250 Quietflite, 1959 LB 3050, 1962 LB 5230, 1962 LB 7251, 1962 LB 5260, 1963 LB 7213, 1967 LB 3054, 1967 LB 5265, 1977 LB 7227, 1977 LB 6277 Commercial, 1981 LB 5024, 1998 LB 10548
ReedZ is offline
post #8 of 21 Old 08-07-2019, 10:59 PM Thread Starter
Yard Nazi's Avatar
Thanks for the info on the spring bar guys. I found a local dealer that had 2 so I bought them both. Less than $4.00 for both. Clipped right in and holds the speed lever nicely. I got to use the mower on one of the neighbors yards today. Man does it run smooth. Started on one pull but it did want to die out without priming, probably because I was messing with the carb the first day and got it too lean. Turned the needle out about 3/4 and it ran perfectly. Polished up the handle today and put on a new handle cover. Sharpened, balanced, and oriented the blade. I think I will enjoy having this one in the rotation. I will keep an eye out for a replacement shroud as it does have a lot of gouges on the sides however the deck is in amazing condition and it is my favorite style. Would like to order some new decals but until I get a smoother shroud those will have to wait. Bill
post #9 of 21 Old 08-08-2019, 07:29 AM
New shroud?? That one looks almost perfect to me! Perfectionist! :-D
Seriously though, would some very fine grit sandpaper clean that up a bit?
-- Matt
Toys:
Lawn-Boy 10525 3-speed w/ comm wheels
Toro AWD Recycler 22"
Stihl 40C w/ Oregon SpeedLoad head
Echo SRM-230
Echo PB-250LN
Excell pressure washer w/ Honda GC160
More as acquired...
TheSteelGator is offline
post #10 of 21 Old 08-08-2019, 08:49 AM Thread Starter
Yard Nazi's Avatar
Thanks for the compliments but the pictures do not do the scratches in the shroud justice. Someone over the years must have been shoving it under some bushes or something. I have never sanded out a plastic shroud but I will assume that it would not be possible to sand and polish it enough to get it back to the factory gloss and I would rather keep the scratches than paint the shroud. Not a big deal so I will just continue using it for now. Bill
post #11 of 21 Old 08-08-2019, 11:54 AM
LBAD Victim
LawnToro's Avatar
About those scratches...
That shroud was not the original shroud on that mower. When you and I worked on it originally, we also worked on an 8253. We had swapped the 8253 shroud on there since the original 5269G shroud had an issue with a leak. The 8253 was really beat up, so the shroud did have a fair amount of scratches.
Stihl
2000 Stihl FS85
1995 FC44
2015 FS56rc-e
TORO
2016 721R-C
Other
2005 Husqvarna 123L
MTD
Lawn Boy
1980 8070
2001 10247
post #12 of 21 Old 08-08-2019, 02:45 PM Thread Starter
Yard Nazi's Avatar
Ah yes! Now it is all coming back to me.
Sent from my SM-J320R4 using MyTractorForum Free App mobile app
post #13 of 21 Old 08-10-2019, 11:26 PM Thread Starter
Yard Nazi's Avatar
Got to mow another yard tonight with the 5269G. My wife was using the 5273, D-600 series. Amazing sound with both mowers started and running at 3200 RPM. Very harmonic. The 5269G ran flawlessly and I am enjoying using it. Earlier in the day I replaced both handle brackets with nice used ones as the left bracket was from a self propelled 8253. Also the air filter cover was badly discolored and even though I had a new one in stock I decided to see what I could do with it. Used a razor knife blade and dragged it repeatedly over the discolored areas until everything was smooth and nicely green again. I may try this method on the side of the shroud. I have found a few on eBay but most are more than I want to spend and not any better than what I have. Bill
post #14 of 21 Old 08-11-2019, 10:56 AM
Green is where it's at.
Tinker'N's Avatar
Very nice!
I have a question.. since I'm not yet completely familiar with the older models.. Are all of the ones with a top that looks like that (same shape and control orientation) a 'D-series' motor?
- LAWN-BOY -
'02 10550 Duraforce EZ stride
'98 10323 D-Monster RWD
'96 10401 19-in. F-Series 5.0 (WTB 10400)
'84 5253 19-in. F-series (soon 4-sale)
- CRAFTSMAN -
'15 Platinum Tall-Wheel Push 7.25 B&S OHV
?Yr Platinum Tall-Wheel Push (motor swapped beater)
- SNAPPER -
'13 RWD 175cc 7.75 B&S OHV (shanghai'd!)
- TORO -
'93-ish PowerThrow 622
'97 PowerThrow 824 XL
- STIHL -
BG 55 Blower
BG 86 C-E Blower
FS 70 R String Trimmer
Tinker'N is offline
post #15 of 21 Old 08-11-2019, 05:09 PM
4K Poster!!!!
Lawnboy77's Avatar
Originally Posted by Tinker'N View Post
Very nice!
Yes, all those with that style shroud are D series engines, and more specifically D-400s.
