Duraforce Problem #1 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 07-18-2019, 02:48 PM Thread Starter
MTF--A Step Above!
Brad's Avatar
I have 2 Duraforce Gold machines. Nearly identical except 1 is electric start. Went to start them up today and neither would start. Will start with mower #1.
Have had a problem with the coil (at least I think that is the issue). Won't fire off when first pulled out of the shed 75% of the time. I can let it set while I weed eat and mow with the rider, come back, pull the rope and it'll fire first pull most of the time. Weird, but I'll just live with it. Anyway, I noticed that the primer bulb was disintegrating. I also noticed gas was leaking out pretty bad (never noticed this before). Took tank off the shroud and found a leak in the tank. Anyone have enough confidence in any sealant to suggest putting some on there to stop the leak? Suggestion as to the type I would use? Funny, if you've never looked at a Duraforce tank, almost looks like 2 pcs of plastic snapped together.
Probably going to get another coil in the future, but until I am totally convinced that's the problem I will hold off.
Thanks!
Drop me a PM!
Brad
de KA9WRZ
Brad is online now
post #2 of 13 Old 07-18-2019, 05:26 PM
LBAD Victim
LawnToro's Avatar
Re: Duraforce Problem #1
I would replace the coil. That is definitely your problem.
As far as the gas tank goes, I have had good luck with Seal All. It comes in a small yellow tube. It is amazing stuff.
Old LawnBoys rock. Need I say more?
Stihl
2000 Stihl FS85
1995 FC44
2015 FS56rc-e
TORO
2019 25.4cc powerhead
2016 721R-C
2018 Super Recycler 20381
2008 Super Recycler 20093
Other
2005 Husqvarna 123L
2008 Poulan Pro PP335
2018 Masterforce 20V trimmer
2017 Black and Decker Battery hedge trimmer
2014 Scotts Sync 20V trimmer/blower combo
MTD
2017 Troy Bilt TB230 ($30 at Lowes!)
1995 Craftsman Hedge trimmer
Lawn Boy
1980 8070
2001 10247
LawnToro is offline
post #3 of 13 Old 07-18-2019, 06:10 PM
lawnboy dan's Avatar
seal all works but not permanent
lawnboy dan is offline
post #4 of 13 Old 07-18-2019, 10:15 PM
95lawnboy's Avatar
I agree with Dan, seal all will work for a while but eventually you should probably replace your tank. If there's any mower repair shops/ junkyards around maybe you can get a used tank cheap. I know the guy near me charges like $5 for used tanks. If your mower is a 2001 model, they were actually recalled for the gas tank leaking. Not like it really matters, I just thought that was kinda interesting
If you need a new primer bulb, I'd advise spending a little more and buying a genuine toro/lb one. I bought a pack of the stens ones last year and as soon as gas hit them they get hard as a rock and unusable.
Like lawn toro said, the coil is definitely your problem with hot restarts. You can get an aftermarket coil on the bay for $12 or so and I have great luck with the ones I've bought.
2000 10324
1999 10323
1998 10323
2003 10324
1995 10311
2001 10360
1997 10314 (x2)
1996 10651
2017 HRR216
2006 Echo GT200R
2016 Echo SRM225
2019 Echo SRM266
95lawnboy is offline
post #5 of 13 Old 07-19-2019, 12:55 AM
old lawnboy's Avatar
When you say you have no spark, are you using a spark tester of some kind or just laying a spark plug on the engine for ground. The best spark tester I have found is the one that looks like a spark plug and has a alligator clip spot welded to it. It will show a spark and also when it jumps you will hear it snap if you listen carefully. If the primer bulb is cracked, the DuraForce engines are almost impossible to start cold. Maybe sitting in the sun for a while helps to start it. Always tear it down to the flywheel is exposed so you can remove the kill wire from the ignition module for final test of spark to eliminate wiring and kill switch. Also test without spark plug in cylinder so you can spin it a little faster. LawnBoy/Toro modules seem to be a lot better then the China knockoff ones.
old lawnboy is offline
post #6 of 13 Old 07-20-2019, 02:08 PM
LBAD Victim
LawnToro's Avatar
I have never had an issue with a cracked primer bulb causing a hard start condition. I can typically start my Duraforce within 2 pulls with only the choke when it is cold.
Stihl
2000 Stihl FS85
1995 FC44
2015 FS56rc-e
TORO
2016 721R-C
Other
2005 Husqvarna 123L
MTD
Lawn Boy
1980 8070
2001 10247
LawnToro is offline
post #7 of 13 Old 07-20-2019, 03:39 PM
Senior MTF Poster
Flush the tank with water, find a pc. of similar plastic, use a soldering gun to "Plastic weld" the leak. Don't melt thru. Flush tank with a little fresh gas and reinstall.
Walt Conner
Walt 2002 is offline
post #8 of 13 Old 07-20-2019, 03:58 PM Thread Starter
MTF--A Step Above!
Brad's Avatar
Walt Conner
Excellent suggestion. Going to give this a try. I should be able to make that work. Thank-you!
(What do you think the results would be if I didn't flush the tank and used a propane soldering iron? Probably not too good.....)
Drop me a PM!
Brad
de KA9WRZ
Brad is online now
post #9 of 13 Old 07-20-2019, 08:18 PM
5K Poster!!!
Indy452's Avatar
When your duraforce won't start again, push it into a sunny spot and let it warm in the sun an hour or so, if it starts, its the chronically fail prone coil.. Thats what I have to do with mine... once its running its fine. Those coils on the duraforce were pitiful.
Indy452 is offline
post #10 of 13 Old 07-21-2019, 07:09 AM Thread Starter
MTF--A Step Above!
Brad's Avatar
I have done the old 200* for an hour in the oven trick before. I may try that with the coil from the Duraforce Problem #2 I mentioned. That's kind of why I wondered about all the humidity we've been having, if that was maybe a factor. Oh, well, something to keep me out of the pool hall!
Drop me a PM!
Brad
de KA9WRZ
Brad is online now
post #11 of 13 Old 07-21-2019, 12:05 PM
Senior MTF Poster
Probably would solve your leak problem - - permanently.
Walt Conner
post #12 of 13 Old 07-25-2019, 02:37 AM Thread Starter
MTF--A Step Above!
Brad's Avatar
Well, I sealed the cap off with a latex glove and blew into the gas outlet to see exactly where the leak was. Whole top of the seam appeared to be split about 3" long. I used the sealant, giving it 3 layers to get a good seal. Put everything back together today, threw some gas in, primer now seems to work. Fired right up. Problems with #1 temporarily solved!
May invest in another coil just to have on the shelf.
Thanks for suggestions!
Drop me a PM!
Brad
de KA9WRZ
Brad is online now
post #13 of 13 Old 07-25-2019, 11:30 AM
Yard Nazi's Avatar
Talking Re: Duraforce Problem #1
Looks like those tanks can be had new, shipped, for $35.00 on eBay. Might be worth checking a local dealer to get a price. My Toro dealer knows I try to shop local when I can and will try to match an online price if possible, or at least get close. Glad you got it fixed, for now. Bill
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1978 Lawnboy Model 5269G
1979 Lawnboy Model 7268******1980 Lawnboy Model 5247******1982 Lawnboy Model 5247
1982 Lawnboy Model 5247*******1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is offline
