My "New" Lawnboy yardsale find - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 05-19-2019, 08:49 PM Thread Starter
I responded to a local Facebook post offering this lawnmower for $25. I have 4 steel-deck Duraforce models, but I have never owned a aluminum deck Duraforce model. It took some minor repair to get it working, and I'm not sure I like the method of engaging the self-propel. I'm used to raising a bail for self-propel, or on my older ones tilting the handlebar forward. On this you actually have to be moving yourself for the mower to move. This is model 10552. I don't know the years, but I would guess early 2000's. Of course the electric-start battery is bad, and it didn't come with a charger. Not sure but I think one can get an inexpensive after-market battery for these?
ID:	2377335   Click image for larger version
ID:	2377337   Click image for larger version
Phototone is offline
post #2 of 9 Old 05-19-2019, 09:46 PM
4K Poster!!!!
Lawnboy77's Avatar
Re: My "New" Lawnboy yardsale find
Nice deal!
Lawnboy77 is online now
post #3 of 9 Old 05-19-2019, 10:16 PM
old lawnboy's Avatar
Nice find. I actually like the easy stride system better than the three speed self propelled. It always seems that I want to go different speed then what the gears of the three speed give me. It is to slow or two fast going up or down hills. As for year the serial number has year, the first two numbers indicate the year. 22--- would be 2002, 24---- 2004 and so on. Carburetors tend to surge on the DuraForce engines if not keep in good condition, but have all the power you can use, good rear wheel drive and seem to be fairly easy on gas usage. Adjust handle height for comfortable position and I think you will get to love the Easy Stride system. Also if you are going to keep it, install a 90 degree fuel shut off in the fuel line just below the fuel tank outlet. They should have made fuel shut off in tank at factory, but for some reason they didn't. Not sure why but the Dura Force carburetors seem to leak more often then earlier models even though they use the same needle and seat and similar float. Again, nice find.
old lawnboy is offline
post #4 of 9 Old 05-19-2019, 11:12 PM Thread Starter
well, I've got 5 Duraforce powered lawnmowers now and I don't have any fuel leaks, nor do I have significant surging. This is my first aluminum deck Duraforce. People make the mistake of getting carb cleaner on the float, which dissolves the coating, and the float fails.
post #5 of 9 Old 05-20-2019, 02:49 AM
ReedZ's Avatar
What a steal! Electric start option too!Congrats. Very nice mower. I had the exact same one.
I never could get used to the easy stride. It drove me crazy. Iíve had 3 or 4 and always end up flipping them while keeping the 3 speed ones as I find them so much better to operate. I know thereís lots of guys out there that like the easy stride though so itís all about personal preference.
1952 LB 8T10, 1954 LB 8T14, 1955 LB 8F20K, 1956 LB 7000, 1957 LB 3100, 1957 LB 8S11LB, 1957 LB 5100, 1957 Marauder 89MH, 1958 LB 5150, 1959 LB 5250 Quietflite, 1959 LB 3050, 1962 LB 5230, 1962 LB 7251, 1962 LB 5260, 1963 LB 7213, 1967 LB 3054, 1967 LB 5265, 1977 LB 7227, 1977 LB 6277 Commercial, 1981 LB 5024, 1998 LB 10548
ReedZ is offline
post #6 of 9 Old 05-20-2019, 07:37 AM
Dang, that's a deal for $25! My neighbor has this exact same model minus the electric start and seems to like it very much. I've no idea re: the battery but I'd be tempted to try and wire up a cheaper aftermarket one. I'm thinking that an OEM LB battery (if you can even find one) would be $$$.
TheSteelGator is offline
post #7 of 9 Old 05-20-2019, 09:20 AM
lawnboyben's Avatar
They are. Last I checked they're around $70.
Lawn-Boys
1991 C21ZPN
1994 10520
1995 10545
1999 22261
Blowers
Echo PB-400E
Husqvarna 125B
Trimmers
Husqvarna 128LD
Echo SRM-2400
Echo SRM-210
lawnboyben is offline
post #8 of 9 Old 05-20-2019, 10:55 AM
Yard Nazi's Avatar
Talking Re: My "New" Lawnboy yardsale find
If you have a Batteries Plus near you, check with them on a battery. I picked up a nice Duracell AGM battery for my Liberty mower and it was cheap and has performed well. The Liberty is not self charging but the battery seems to last a very long time between charges. If you need a charger for the mower send my a PM as I have a NOS Lawnboy charger and if you send me a email address I can send you a picture to see if it is something you are interested in. Bill
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1980 Lawnboy Model 5247
1980 Lawnboy Model 7268******1982 Lawnboy Model 5247******1982 Lawnboy Model 5247
1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is offline
post #9 of 9 Old 05-25-2019, 04:41 PM Thread Starter
Well I decided what have I got to lose, and I charged up the battery on my car battery charger at the lowest amperage of 2 amps. It took a charge, and by golly it will start the mower. I am amazed at my $25 purchase.
Help to find what model this simplicity is moose49304 Simplicity/Allis Chalmers Forum 4 01-29-2013 11:18 PM
Mulch Plate Cover for 54" deck - cant find? mroman59 Craftsman/Sears Forum 12 12-17-2012 12:17 PM
considering purchasing a used lawnboy bkearney Walk Behind Mowers 12 12-10-2012 07:48 AM
Help Identify Lawnboy Bag Rod-Handle Mount Yard Nazi Walk Behind Mowers 3 11-01-2012 07:33 PM
