C21CPN Lawnboy - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 05-15-2019, 08:09 AM Thread Starter
C21CPN Lawnboy
I have a C21CPN commercial, remote filter, no BBC or other gizmos.
The engine has a lot of end play. I like the stagger deck and large fuel tank, its been a good mower. My son is taking on mowing some family yards and I want to re-power the mower so we don't have to be concerned it will fail during the growing season.
Is there a drop in replacement engine?
echo7 is offline
post #2 of 11 Old 05-15-2019, 09:36 AM
Re: C21CPN Lawnboy
Based on this thread:
https://www.mytractorforum.com/155-w...ommercial.html
It's got an F engine, which can be found on many Lawn-Boy models. Obviously, the shroud, fuel tank and brush guard will be different on a commercial model versus the homeowner models. But I'd think you could switch those over.
I'm sure one of the more regular posters here will be along shortly to tell you more...
TheSteelGator is online now
post #3 of 11 Old 05-15-2019, 10:53 AM
Re: C21CPN Lawnboy
Any "F" engine should bolt to the muffler plate. It would be best to pick an engine from a similar year model.
Phototone is online now
post #4 of 11 Old 05-15-2019, 10:57 AM Thread Starter
Re: C21CPN Lawnboy
I think an F engine is going to be hard to locate. I was thinking about a new engine. Honda, Kawasaki, B and S, etc
echo7 is offline
post #5 of 11 Old 05-15-2019, 04:55 PM
4K Poster!!!!
Lawnboy77's Avatar
Re: C21CPN Lawnboy
Well personally I think it will be much easier to do like what was already suggested, and that is to just find a good replacement F series shortblock rather than converting to a new 4 cycle engine. Your C21CPN was only made for two years (1989 and 90), the closest Lawnboy model to that in a 4 cycle (B&S) is a 680531 so you would need to bump those two parts catalogues and come up with the parts that you would need to covert it over to the 4 stroke new engine setup. Just a quick scan and Partstree is showing that the engine plate (pn#614429) that your new replacement 4 stroke would mount on is NLA, so that would have to be sourced used from ebay, or a similar source. The Briggs engine part number for that model is (pn# 126702-3192-01) is also showing no longer available, so a replacement with the same mounting pattern would be needed. Just a big head ache in my opinion for very little return, as a matter of fact, I think you will end up with a machine that is not as functional, or as desirable as the old original setup of the F engine. Now I don't know, but there is a chance that someone makes an aftermarket adapter plate for these old Lawnboys so that these new 4 stroke replacement engines can be mounted, but I have yet to hear about it. Once again, it would be my humble opinion that you would be spending money and time actually downgrading your highly desirable F engine equipped mower if you were to follow through and get rid of that F engine capability. There are still plenty of good new and used F series engines out there to be had. Heck, you may get many more years from that original engine if the only issue is crank end play. I forget the measurement off hand, but the manual gives quite a bit of lead way on crank end play, don't quote me, but .015 in. comes to my mind, so you could locate a good shortblock and stuff away until needed. It's an easy change over to when the time comes. You have a highly desirable mower as is. I see a constant ad being run down here in CL in west Texas of folks wanting to buy old 2 stroke Lawnboys, especially the commercial versions.
Lawnboy77 is online now
post #6 of 11 Old 05-15-2019, 05:27 PM
Re: C21CPN Lawnboy
Depends on the year of your LB but most can be repowered either by a direct bolt or with a home made adapter plate. In the pictures is my LB commercial with a Briggs via an adapter place. A LB 10201 With a Harbor Freight engine. A JS60 John Deere with a a HF Predator and I have probably 5 or 6 other mowers that have been repowered. The HF engines I have been real happy with and those will be around for years to come. Roger
ID:	2376693   Click image for larger version
ID:	2376695   Click image for larger version
ID:	2376697   Click image for larger version
rhenning is offline
post #7 of 11 Old 05-15-2019, 09:50 PM
LawnBoy90's Avatar
Re: C21CPN Lawnboy
If you go with a new engine I would recommend the B&S Quantum engine as that's what was stock on 4 cycle models from that era. The mounting plate is available on eBay and from experience the Quantum engines are plenty powerful. Not to mention Briggs parts are a little easier to come by.
Link for the mounting plate: https://www.google.com/url?sa=t&sour...D0ZaXcSDA5pETw
Sent from my XT1710-02 using Tapatalk
Mowers:
1970 - 5239 (D-408)
1973 - 3058 (D-433) (Rebuilt)
1974 - 8251 (D-480)
1975 - 5273 (D-601) (Rebuilt)
1982 - 7071 (F-101) (Custom)
LawnBoy90 is offline
post #8 of 11 Old 05-16-2019, 07:30 AM
RfWi's Avatar
Re: C21CPN Lawnboy
Why mess around with adapter plates and a four stroke adding a bunch of weight,just replace with an F.Parts aren't that hard to find,besides the OP is looking for a drop in replacement.
RfWi is offline
post #9 of 11 Old 05-16-2019, 08:10 AM Thread Starter
Re: C21CPN Lawnboy
Thanks for the replies.
I would prefer to find a NOS F engine for replacement but I know that will be difficult. That is why I wanted to look into options for a modern(currently in production or recently out of)engine.
I will look around on Craigslist as well as talk to the former Lawnboy dealership. Maybe I will get lucky and find something. Otherwise I will explore the adapter options.
echo7 is offline
post #10 of 11 Old Today, 01:31 AM
Re: C21CPN Lawnboy
Another vote for another F engine. This isn't LB territory like the mid-west I bought an L21ZPN and a 4 square JC Penny for 30$ Both in very rough shape. I got L21ZPN running just by taking the carb apart , soaking the parts and re-assembling. I removed the coil, wire brushed and sanded everything. It is an '89 and my old 7073 is an '88 The mowers are virtually identical with Walbro metal carbs. The engine has a lot of end play. I'm no LB expert. Generally speaking. End play in most engines isn't a big deal. Axial play is the bad one.
andyma is offline
post #11 of 11 Old Today, 10:45 AM
4K Poster!!!!
Yard Nazi's Avatar
Talking Re: C21CPN Lawnboy
I have been trying to remember something about a thrust washer that was added to the F series to help eliminate the end play crankcase wear on the F series. Also from what I have read, the bearings on the F series are a bit on the loose side as far as lateral movement. I would look for a back up mower to use if the Lawnboy fails down the road. Keep an eye out for a short block on eBay. They do come up. That way you have all the bases covered. Besides, no one that mows should only have one mower. :-) Bill
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1980 Lawnboy Model 5247
1980 Lawnboy Model 7268******1982 Lawnboy Model 5247******1982 Lawnboy Model 5247
1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is online now
lawnboy 8220 allisonwaters Walk Behind Mowers 13 10-13-2018 12:57 AM
Whats the Difference Between the M and DURAFORCE Lawnboy Engine? lawnboy7260G Walk Behind Mowers 26 07-03-2018 08:01 PM
New to me Lawnboy but what model? JohnWindl Walk Behind Mowers 9 06-11-2018 09:41 PM
Lawnboy C21CPN Mulch? JohnWindl Walk Behind Mowers 6 11-11-2017 01:41 PM
Lawnboy Mower Monitor ET-301 Yard Nazi Walk Behind Mowers 1 01-20-2013 09:27 PM
