lawn boy - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 05-14-2019, 04:50 PM Thread Starter
BoWoggie's Avatar
lawn boy
I have a Lawn Boy Gold Series . Model #10515 S.N. 3913965 I would first like to know how old it is. I bought it new, but it's been a while. I don't remember when. It is self propelled, rear wheel drive. The problem is this. When you release the lever and try to pull it backwards, the transmission is still somewhat engaged. Not enough to pull it forward, but enough to make it very hard to pull backward. I have checked the belt when the lever is released, and it is loose. What am I overlooking? I can't say for sure if the belt has ever been replaced, but I have always had it professionally serviced. I am retired now, and thought I might try to tackle this problem myself. Maybe that was a mistake.
Sometimes It's better to keep your mouth shut, and have the world think you a fool, than to speak, and remove all doubt.
BoWoggie is online now
post #2 of 10 Old 05-14-2019, 05:43 PM
Re: lawn boy
1993. Roger
rhenning is offline
post #3 of 10 Old 05-14-2019, 05:46 PM
LBAD Victim
LawnToro's Avatar
Re: lawn boy
Try pushing it forward after you release the bail bar. Sometimes, the freewheel clutches take a minute to disengage.
Old LawnBoys rock. Need I say more?
Stihl
2000 Stihl FS85
1995 FC44
2015 FS56rc-e
TORO
2019 25.4cc powerhead
2016 721R-C
2018 Super Recycler 20381
2008 Super Recycler 20093
Other
2005 Husqvarna 123L
2008 Poulan Pro PP335
2018 Masterforce 20V trimmer
2017 Black and Decker Battery hedge trimmer
2014 Scotts Sync 20V trimmer/blower combo
MTD
2017 Troy Bilt TB230 ($30 at Lowes!)
1995 Craftsman Hedge trimmer
Lawn Boy
1980 8070
2001 10247
LawnToro is online now
post #4 of 10 Old 05-14-2019, 10:05 PM
Yard Nazi's Avatar
Talking Re: lawn boy
I am not the guy to offer suggestions on this style of self propelled but from what I have read you may just need to disassemble the drive assemblies and clean them and reinstall. I have read that they get sticky when dirty. Don't know for sure, just passing along what I have read. Bill
If you do this, take pictures as you go and only do one side at a time.
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1980 Lawnboy Model 5247
1980 Lawnboy Model 7268******1982 Lawnboy Model 5247******1982 Lawnboy Model 5247
1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is online now
post #5 of 10 Old 05-14-2019, 10:20 PM Thread Starter
BoWoggie's Avatar
Re: lawn boy
I went to my small engine / lawn mower guy, and he told me the same thing about disassembly and cleaning. I took off one of the rear wheels. Wow I don't know if you have seen any of these taken apart, but what an engineering mess. ( IMHO) It doesn't make a lot of sense. There is a VERY strange key (square key) in the assembly that rocks back and forth to drive the wheel. I can see where grease,dirt, and grime would prevent it from working over time. I cleaned it up and reassembled it. I will do the other side tomorrow. It will either work or it won't. The mower is 26 years old, so I guess I got my moneys worth out of it. I only use it for trimming, as I have a tractor for mowing. My wife sometimes decides to mow the whole yard with the Lawn boy. She has way more energy than I do.
post #6 of 10 Old 05-15-2019, 02:09 PM
Lawn-Boy Nut
dougmac's Avatar
Re: lawn boy
I agree that the rocking keys are kinda goofy, but they work. I've had mowers with this style engagement since 1999 and none of the parts ever wear out. You would think the plastic disc would, but they just don't. I pump grease in through the grease zerks once a year and disassemble and thoroughly clean every 5 years or so.
Lawnboy's previous style (earlier F Series) had spring loaded woodruff keys machined into the shaft ends. This seemed like a more HD way of doing it, however it requires more frequent cleaning & re-lubing (IMO).
Doug
'72 5270 D600, 19" Mag Push: was 21" 7261 (deck shot; 1st mower I used as a kid)
'77 7024 D433, 21" Alum Push: had since early 80ís, added com-whls
'83 7270 F100, 21" Alum Push BBC: removed BBC
'84 8125 "F", 20" Alum 4-Sq 5-Spd SP
'95 10301 "V", 21" Steel 1-Spd SP: added 10550 gears
'99 10323 "E-DF", 21" Steel 1-Spd SP: bought new, added 10550 gears
'99 10525 "E-DF", 21" Alum 3-Spd SP: added com-whls
'03 10424 "E-DF", 21" Alum Push: bought new, added com-whls
dougmac is online now
post #7 of 10 Old 05-15-2019, 03:01 PM Thread Starter
BoWoggie's Avatar
Re: lawn boy
Got the other wheel apart and cleaned up. Mower now works like brand new. If you ever do this pay VERY close attention to how things come apart. As suggested earlier, do one side at a time. Thanks for your help.
post #8 of 10 Old 05-18-2019, 07:35 PM
Yard Nazi's Avatar
That's great news. As you could tell after you got it apart it is kind of hard to remember how it all goes back together without pictures or the other side for reference. Glad it was something simple. Bill
post #9 of 10 Old 05-19-2019, 06:16 PM
2 strokes forever!
Evans Ward's Avatar
Re: lawn boy
10515 is a great LB mower. One of my favorites. Glad you got it sorted out.
Evans Ward
Macon, GA
'94 LB 10515
'98 LB 10525
'01 Toro Commercial Proline 22043
'88 Snapper Wisconsin Robin 2 cycle WT-1 125v
Plus 4 vintage 2 stroke streetbikes
Evans Ward is offline
post #10 of 10 Old 05-20-2019, 11:20 AM
Jackass's Avatar
Re: lawn boy
I just did this maintenance on my 10515 last year. I took pictures as I removed each layer of the "mess" so I could get it all back together. A shot of grease twice a season usually helps out....otherwise I just shift back to neutral before rolling backwards long distances.
Jackass is offline
80ís Lawn Boy mowers Kendrick Walk Behind Mowers 4 05-20-2019 10:28 AM
"Discussion of the Lawn Boy Automower 1957-1963" Dan Wyatt Walk Behind Mowers 19 10-21-2018 12:20 AM
New to me Lawn Boy Instructor74 Walk Behind Mowers 13 08-02-2018 04:04 PM
"Discussion of the Lawn Boy Loafer" Dan Wyatt Walk Behind Mowers 2 07-18-2018 08:26 AM
John Deere Lawn Boy? PeoriaMurph Walk Behind Mowers 10 06-11-2018 08:31 PM
