5023 Lawnboy Bricktop On Off Switch Intermittent - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 04-21-2019, 12:03 AM Thread Starter
Yard Nazi's Avatar
Talking 5023 Lawnboy Bricktop On Off Switch Intermittent
Hi all! Just looking for opinions here. My 5023 Bricktop has been getting hard to shut off. I have to wiggle the on off switch until I find the magic spot to ground the ignition. I had it apart today and cleaned and wire brushed everything and then sprayed the contacts with tuner cleaner. Still intermittent. Do I need to replace the screw that goes into the armature plate? Could it be worn down? How about the blade on the on off switch? All looks okay but it should shut off much easier than having to mess with it to find the sweet spot. Thoughts? Bill
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1980 Lawnboy Model 5247
1980 Lawnboy Model 7268******1982 Lawnboy Model 5247******1982 Lawnboy Model 5247
1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is offline
post #2 of 4 Old 04-21-2019, 10:38 AM
ReedZ's Avatar
Re: 5023 Lawnboy Bricktop On Off Switch Intermittent
I’ve had that problem in the past as well. Never had to replace screw or contact. Just a good cleaning with a medium grade steel wool. How’s the condition of the wire? Is it stiff/hard. I’ve had one of them go bad before. It was brittle and the copper inside actually wore and broke apart causing an intermittent issue as well. Likely from the vibration and just age. When I took the wire out the plastic insulation broke apart very easily just by bending it.
1952 LB 8T10, 1954 LB 8T14, 1955 LB 8F20K, 1956 LB 7000, 1957 LB 3100, 1957 LB 8S11LB, 1957 LB 5100, 1957 Marauder 89MH, 1958 LB 5150, 1959 LB 5250 Quietflite, 1959 LB 3050, 1962 LB 5230, 1962 LB 7251, 1962 LB 5260, 1963 LB 7213, 1967 LB 3054, 1967 LB 5265, 1977 LB 7227, 1977 LB 6277 Commercial, 1981 LB 5024, 1998 LB 10548
ReedZ is offline
post #3 of 4 Old 04-21-2019, 12:05 PM Thread Starter
Yard Nazi's Avatar
Well I took the shroud and flywheel off, removed the grounding screw and wire brushed it thoroughly. Also filed and wire brushed the contact on the on/off switch. Seems to be working well at the moment. Insulation on the wire looks good. We'll see how it works in the longer run. Bill
Sent from my SM-J320R4 using MyTractorForum Free App mobile app
post #4 of 4 Old 04-21-2019, 10:11 PM
Senior MTF Poster
Put small thin washer under screw head or replace screw.
Walt Conner
Walt 2002 is offline
Troy Bilt Horse Forward Interlock Safety Switch tarheel54 Tiller Talk 8 04-26-2019 09:17 PM
bricktop lawnboy nc forkz Ebay/Craig's List 0 08-19-2018 07:49 PM
Lawnboy 5023 Bricktop Leaking Fuel from Carb Filter Housing Yard Nazi Walk Behind Mowers 0 08-01-2018 03:03 PM
Universal Ignition Switch Start Amp ? TriumphMan Backyard Round Table - L & G Tractor Related Topics 6 07-27-2018 08:35 AM
Lawnboy D-600 Electric Starter Intermittent Yard Nazi Walk Behind Mowers 2 12-16-2017 12:50 AM
