Lawn Boy 2010 Gardener - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 27 Old 04-22-2019, 01:14 PM
LawnBoy90's Avatar
Re: Lawn Boy 2010 Gardener
Originally Posted by jsoluna View Post
Thanks! What a beautiful color.
How do you all get the gas caps to stop leaking?
My D engine mower has the same style gas cap and I have to run with 1/2 tank or less or when it splashes it saturates the fiber discs under the cap and then comes right out the top hole. The tiller is the same. With a full tank it sloshes fuel out the cap.
I usually make sure they're as tight as they can go and if there is still some leakage I add a thin amount of permatex gasket maker on the threads helps out a lot.
Mowers:
1970 - 5239 (D-408)
1973 - 3058 (D-433) (Rebuilt)
1974 - 8251 (D-480)
1975 - 5273 (D-601) (Rebuilt)
1982 - 7071 (F-101) (Custom)
LawnBoy90 is online now
post #17 of 27 Old 04-22-2019, 01:51 PM
4K Poster!!!!
Lawnboy77's Avatar
From my experience you will never get those old Lawnboy metal caps to not vent some fuel/oil. I carry a shop rag in my back pocket just for that reason. It normally is just enough to cause oil to accumulate around, and on top of the cap, but shouldn’t run fuel down on to the deck. At least that’s my standards in regards to that issue. They later corrected that issue with the plastic caps introduced around 1977.
Lawnboy77 is online now
post #18 of 27 Old 04-22-2019, 07:52 PM Thread Starter
jsoluna's Avatar
I suppose I haven't investigated closely enough. I assumed it was coming out of the vent hole, may be the threads if the cork seal isn't doing its job. So a light film of oil/gas resistant RTV in the valleys of the threads?
Justin
'99 Cub Cadet 3205
'01 Lawn Boy 6.5
'96 Lawn Boy 4.5
'72 Lawn Boy 3.5
'12 Husqvarna 440
'09 Stihl FS55
jsoluna is offline
post #19 of 27 Old 04-22-2019, 07:54 PM Thread Starter
jsoluna's Avatar
Looks like I'll be rope starting it until I find a recoil assembly. The drive plate and pin drive assembly just crapped out on me this morning. Looks like bricktops use the same recoil start with different shroud.
Justin
'99 Cub Cadet 3205
'01 Lawn Boy 6.5
'96 Lawn Boy 4.5
'72 Lawn Boy 3.5
'12 Husqvarna 440
'09 Stihl FS55
jsoluna is offline
post #20 of 27 Old 04-22-2019, 08:39 PM
4K Poster!!!!
Lawnboy77's Avatar
The threads of the filler neck are really not intended to be the sealing surface. The sealing surface is the very top rim of the filler neck. It compresses against the gasket inside the cap along the outer perimeter. If the sealing lip is not dented and the gasket inside the cap is in good shape you should be okay.
post #21 of 27 Old 04-22-2019, 08:59 PM Thread Starter
jsoluna's Avatar
That's how I thought it worked too. I'll get a little more detailed look.
Really do enjoy working on this older OMC / Lawn Boy stuff. There's some sound engineering going on. The exhaust tone from the cast dual outlet housing is priceless!
Justin
'99 Cub Cadet 3205
'01 Lawn Boy 6.5
'96 Lawn Boy 4.5
'72 Lawn Boy 3.5
'12 Husqvarna 440
'09 Stihl FS55
jsoluna is offline
Old 04-25-2019, 07:25 PM
jsoluna
This message has been deleted by jsoluna.
post #22 of 27 Old 04-26-2019, 09:18 PM Thread Starter
jsoluna's Avatar
Video of the 2010! It's not pretty but it runs 🙂
https://youtu.be/KFZzCcg6fUY
Justin
'99 Cub Cadet 3205
'01 Lawn Boy 6.5
'96 Lawn Boy 4.5
'72 Lawn Boy 3.5
'12 Husqvarna 440
'09 Stihl FS55
jsoluna is offline
post #23 of 27 Old 04-26-2019, 11:12 PM
4K Poster!!!!
Yard Nazi's Avatar
Talking Re: Lawn Boy 2010 Gardener
That sounds great! Shouldn't take too much to get that recoil working again. Have you found where to get the air filter for that? Bill
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1980 Lawnboy Model 5247
1980 Lawnboy Model 7268******1982 Lawnboy Model 5247******1982 Lawnboy Model 5247
1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is offline
post #24 of 27 Old 04-27-2019, 06:23 AM Thread Starter
jsoluna's Avatar
Thanks!
I have not researched the air cleaner yet, they stay remarkably clean since they are located so high off the ground.
Justin
'99 Cub Cadet 3205
'01 Lawn Boy 6.5
'96 Lawn Boy 4.5
'72 Lawn Boy 3.5
'12 Husqvarna 440
'09 Stihl FS55
jsoluna is offline
post #25 of 27 Old 04-27-2019, 12:01 PM
4K Poster!!!!
Yard Nazi's Avatar
Here is one of several links to the filters. Part number 603787. These are the same as used on the edgers. Pretty sure this is the same seller I purchased from and they accepted very reasonable offers. Bill
https://www.ebay.com/itm/afp-35-lawn...4AAMXQiFxSA~wX
post #26 of 27 Old 04-28-2019, 07:44 AM Thread Starter
jsoluna's Avatar
Went to assemble my new recoil parts and got it all together and within the first couple pulls, it jammed hard. Had starter pin on outside of pulley as noted in manual. It felt like the engine backfired or something and it actually had bent the pin.
Took it back apart and bent the pin back into shape, reinstalled the assembly and tried pull starting without spark so I could watch things move.
Is it really only designed to engage like 1/4" of that pin? The old pulley wear marks indicate that is where it was originally as well.
ID:	2374155   Click image for larger version
Justin
'99 Cub Cadet 3205
'01 Lawn Boy 6.5
'96 Lawn Boy 4.5
'72 Lawn Boy 3.5
'12 Husqvarna 440
'09 Stihl FS55
jsoluna is offline
post #27 of 27 Old 04-28-2019, 11:25 AM Thread Starter
jsoluna's Avatar
Update: I think it is partially related to how I was pull starting it. I wasnt pulling the full stroke on the cord and the engine was more likely to recoil on me. I swapped the pin out to the other side of the driven pulley that hadn't been damaged and gave two full pulls and it acted just fine. May just be me.
Justin
'99 Cub Cadet 3205
'01 Lawn Boy 6.5
'96 Lawn Boy 4.5
'72 Lawn Boy 3.5
'12 Husqvarna 440
'09 Stihl FS55
jsoluna is offline
smn53
"Discussion of the Lawn Boy Automower 1957-1963" Dan Wyatt Walk Behind Mowers 19 10-21-2018 12:20 AM
New to me Lawn Boy Instructor74 Walk Behind Mowers 13 08-02-2018 04:04 PM
"Discussion of the Lawn Boy Loafer" Dan Wyatt Walk Behind Mowers 2 07-18-2018 08:26 AM
John Deere Lawn Boy? PeoriaMurph Walk Behind Mowers 10 06-11-2018 08:31 PM
