LBAD strikes! 8F20K - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 60 Old 11-02-2017, 05:30 PM Thread Starter
RfWi's Avatar
LBAD strikes! 8F20K
I thought I could resist,but it was futile!!1955 IronHorse.I've liked the design of these since I first saw them.Seems to be all original.Good thing is it has spark and compression.Bad thing is the chunk of deck broken off by discharge.I'll post more pics after I give it a bit of a bath.
ID:	2119793   Click image for larger version
ID:	2119801   Click image for larger version
ID:	2119809   Click image for larger version
ID:	2119825   Click image for larger version
ID:	2119833   Click image for larger version
ID:	2119841   Click image for larger version
RfWi is offline
post #2 of 60 Old 11-02-2017, 05:38 PM
Senior MTF Pollster
Austen's Avatar
Re: LBAD strikes! 8F20K
Nice find! It looks well-preserved.
Bolens HDT1000 #11- Coming eventually!
1977 Economy Tractor
Hydraulic lift conversion
24" model front king pins
48" Belly mower
32" tiller
3pt hitch
”What joy for those whose strength comes from the Lord." - Psalm 84:5
Austen is online now
post #3 of 60 Old 11-02-2017, 11:02 PM
old lawnboy's Avatar
Nice find, this was the first year for recoil starter and has Iron Horse on top. 1956 models have larger starter and no Iron Horse on top. Canadian models with larger starter continued to have the Iron Horse on top but not US. First models had engine model (C-10 and serial number on an aluminum plate fastened to cylinder fin and shroud was attached with 10/24 screws instead of 1/4 20 hex head bolts. Very first C-10 engines had gas tank and shroud soldered together. Deck should not be to hard to repair as it is aluminum not Magnesium. A chunk of aluminum from something else and you should be able to get it welder. Much easier than Magnesium. If you need any parts, let me know as I have a lot of early C engine parts. I am trying to find an early 8F20K that has the shroud with the 10/24 screws. Most of them were converted to 1/4 20, but surely there are a few out their.
old lawnboy is offline
post #4 of 60 Old 11-02-2017, 11:20 PM Thread Starter
RfWi's Avatar
Yep,for being 60plus years old,it is in pretty good shape.
Thanks for the info.I may need to take you up on the parts offer once I get into this a bit more.
RfWi is offline
post #5 of 60 Old 11-03-2017, 11:19 AM
ReedZ's Avatar
Nice score!
Even has the original wheels. That's a rarity.
That year model the shrouds had a tendency to crack/break around the mounting screws. One of the reasons they went to the 1/4-20 the following year.
I've got the same mower. Just need to get around restoring it. I've got 2 on the go right now with very slow progress.
Keep us in the loop on your clean up and getting it running
G
1952 LB 8T10, 1954 LB 8T14, 1955 LB 8F20K, 1956 LB 7000, 1957 LB 3100, 1957 LB 8S11LB, 1957 LB 5100, 1957 Marauder 89MH, 1958 LB 5150, 1959 LB 5250 Quietflite, 1959 LB 3050, 1962 LB 5230, 1962 LB 7251, 1962 LB 5260, 1963 LB 7213, 1967 LB 3054, 1967 LB 5265, 1977 LB 7227, 1977 LB 6277 Commercial, 1981 LB 5024, 1998 LB 10548
ReedZ is offline
post #6 of 60 Old 11-03-2017, 12:56 PM
unclelee's Avatar
Nice find....some guys have all the luck😂
1953 8FH11LB
1960 ET-1 edger
1963 8221
1964 3052 x2
1967 3002
1968 5236
1969 5238
1971 5020
8235AE
6255 commercial
8461 commercial x2
1982 5006
10323 Duraforce
10732 Lawngirl
10520 Gold Series
GOD GUTS GUNS & LAWNBOYS
unclelee is offline
post #7 of 60 Old 11-03-2017, 07:17 PM Thread Starter
RfWi's Avatar
Gave it a quick bath,deck looks better.I was wondering if those were the original plastic wheels , my 5233 which is 10 years newer has steel wheels.Is this carb linkage correct?Now that the shroud is cleaner I can see on/off- choke actuator directions.I can pull for choke but can't turn for on/off.
ID:	2120969   Click image for larger version
ID:	2120977   Click image for larger version
RfWi is offline
post #8 of 60 Old 11-03-2017, 09:14 PM
4K Poster!!!!
Lawnboy77's Avatar
Looking good! I don't know much about these old Iron Horse Lawnboys...I would of never guessed that any of those came with plastic hub wheels. They sure look original, but being plastic I have my doubts. Just a guess on the on/off switch, but probably just a little rusty within the mag plate. I think that with some disassembly and cleaning you will be good to go.
Lawnboy77 is offline
post #9 of 60 Old 11-03-2017, 10:57 PM
ReedZ's Avatar
Yes those plastic wheels are original to that model
As for the shroud I find it interesting that the on/off is embossed. It shouldn't be for that year/model
ReedZ is offline
post #10 of 60 Old 11-03-2017, 11:23 PM Thread Starter
RfWi's Avatar
Could be a shroud replacement?The paint on bottom edge of shroud does look more like gold than red.But could be just age.
Just noticed I am now a SENIOR MTF member.100th post woo hoo!
RfWi is offline
post #11 of 60 Old 11-03-2017, 11:24 PM
You have a good eye Reedz. I didn't notice the on/off on shroud. I have attached pictures of early C-10 cylinder with aluminum model and s/n tag. Lawn-Boy later suggested the tags be removed due to better air circulation without them.
ID:	2121169   Click image for larger version
post #12 of 60 Old 11-03-2017, 11:29 PM Thread Starter
RfWi's Avatar
Mine still has that tag on it.
RfWi is offline
post #13 of 60 Old 11-03-2017, 11:36 PM
Yes the shroud is a replacement. May be from another later engine or hew when installed. If From another engine it will have engine model and s/n stamped in flap over spark plug or flap to the rear or front of the deck. The original likely broke or split out attachment holes. This would likely have had the small screws holding it on. The mag plate may have been replaced also or the screw holes tapped out to 1/4 20. The original mad plates with small screws did not have as much aluminum to tap out. Getting interesting, look and see if the cylinder has screw hole for model plate. Another note, Lawn-Boy also made a plate the reinforce the shrouds that broke out at the attachment screws. Not sure if they made later shrouds out of heavier material, but only early ones seem to have had the cracking problem.
post #14 of 60 Old 11-03-2017, 11:57 PM Thread Starter
RfWi's Avatar
So much for being all original! At least it does have a good shroud.I'll have a look see at it tomorrow and see what I kind find.
RfWi is offline
post #15 of 60 Old 11-04-2017, 12:04 AM
I found row information on the reinforcement plate and changes in early C-10 engines. See the information at bottom of parts page for changes in C-10.
ID:	2121209   Click image for larger version
