LBAD strikes! 8F20K - Page 4 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #46 of 60 Old 06-19-2019, 09:19 PM
Re: LBAD strikes! 8F20K
You really got that engine cleaned and shined up. Incredible job RfWi. The paint job is nice IMHO.
You have a great little vintage Lawn-Boy.
Tractor Beam is offline
post #47 of 60 Old 06-19-2019, 09:39 PM
hotajax's Avatar
Where do you guys come up with these old vintage Lawn Boys? The pics all conjur up memories of the old guys in my neighborhood cutting their lawns with them. And in those days, without the high quality synthetic oil, they sure did smoke a lot. Now, I'm an old guy, too.
And even worse, I don't care.
hotajax is offline
post #48 of 60 Old 06-19-2019, 10:19 PM
Yard Nazi's Avatar
Talking Re: LBAD strikes! 8F20K
Those images still exist today!! Just look in my neighborhood as my wife and I mow several lawns with the old "Boys". Bill
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1978 Lawnboy Model 5269G
1979 Lawnboy Model 7268******1980 Lawnboy Model 5247******1982 Lawnboy Model 5247
1982 Lawnboy Model 5247*******1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is offline
post #49 of 60 Old 06-21-2019, 07:05 PM Thread Starter
RfWi's Avatar
It was a good day for painting,so primed and painted deck.I just love the detail cast in these decks.No wonder these Lawn-Boys really weren't cheap.Over $800 in today's money!
RfWi is offline
post #50 of 60 Old 06-21-2019, 10:02 PM
4K Poster!!!!
Lawnboy77's Avatar
Looks perfect! Just like factory paint!
Lawnboy77 is online now
post #51 of 60 Old 06-21-2019, 10:23 PM Thread Starter
RfWi's Avatar
Thanks!Well maybe not perfect...but I'm really happy how it turned out.The color is just right.
RfWi is offline
post #52 of 60 Old 06-21-2019, 11:08 PM
The amount of knowledge of about old Lawnboys here is astounding. The idea of mowing with 62 yr old mower pleases me. I pick up little factoids every time I drop by. One really useful tip was that the mixture screw for a F series is only a 1/4-1/2 turn out. Every other carb I ever messed with was a turn and a half out. I happened across that tip before I ever cleaned my first Walbro.
andyma is offline
post #53 of 60 Old 06-22-2019, 02:47 PM
ReedZ's Avatar
Agreed
That is a VERY good paint match. Looks great!
1952 LB 8T10, 1954 LB 8T14, 1955 LB 8F20K, 1956 LB 7000, 1957 LB 3100, 1957 LB 8S11LB, 1957 LB 5100, 1957 Marauder 89MH, 1958 LB 5150, 1959 LB 5250 Quietflite, 1959 LB 3050, 1962 LB 5230, 1962 LB 7251, 1962 LB 5260, 1963 LB 7213, 1967 LB 3054, 1967 LB 5265, 1977 LB 7227, 1977 LB 6277 Commercial, 1981 LB 5024, 1998 LB 10548
ReedZ is offline
post #54 of 60 Old 06-22-2019, 05:15 PM Thread Starter
RfWi's Avatar
Originally Posted by ReedZ View Post
Agreed
Yep,I think the paint guy did a terrific job mixing the paint.He didn't have much to go on.The only non-faded sample was under the model plate.Hard to tell from the pic,but there is just a touch of metallic,just enough.
RfWi is offline
post #55 of 60 Old 06-26-2019, 05:50 PM Thread Starter
RfWi's Avatar
Well,getting close to the end of this project.I can't wait to see how it runs.
Question: Why did these models have three types of blade washers?
ID:	2383683   Click image for larger version
RfWi is offline
post #56 of 60 Old 06-26-2019, 11:33 PM
good evening
to share what the washers are for this is how they mounted the blade
to mount the blade place the washers with flat spot on the crank first
then blade and other washers lock washer then blade nut i know this
because i have same mower it came from my grandfather who was a
lawn-boy dealer the mower was up in storage loft when i found it grandfather
said i could have along with another iron horse mower that first mower he sold is a 1953
model iron horse mower please let me know if you need more help your lawn-boy friend Scott
lbuser64 is online now
post #57 of 60 Old 06-26-2019, 11:39 PM
old lawnboy's Avatar
It was just LawnBoy's idea of what was needed to make the blade turn with the crankshaft without slipping and to let is slip if you kit something solid. Correct sequence is large steel washer with D shaped hole, next rubber washer, next fibre washer, next stiffener, next blade, next large steel with D hole, Safety washer then nut. From picture you have extra fibre washer. If you had a 21 inch mower you would use a fibre washer between the stiffener and the blade, but you have a model 8F20K (18) inch mower that does not use the washer between blade and stiffener. After tightening the nut, bend one of the safety washer tabs to lock the nut to the shaft. That deck paint looks the best I have ever seen. A hard paint to match.
old lawnboy is offline
post #58 of 60 Old 06-27-2019, 07:26 PM Thread Starter
RfWi's Avatar
I kind of thought that was the reasoning for those washers,to allow some slippage.There was a nylock nut on there.Since there is a safety washer on there,should that be a standard nut?Is the tightening torque less than a blade nut without those washers to allow the slippage?
I will certainly pass on all the compliments on the paint mix to the paint guy!
He did a bang up job!!
RfWi is offline
post #59 of 60 Old 06-28-2019, 01:14 AM
I could not find torque setting for blade nut for D shaft models, but later models that use nylock nut shows z525 to 650 inch torque or 45 to 55 foot pounds. Either nylock or regular nut should be fine. If wanting to go for exact as original, use regular nut.
post #60 of 60 Old 06-29-2019, 08:30 PM Thread Starter
RfWi's Avatar
Got this assembled and running! After remembering to open the needle valve,,it started on the first pull.Runs great,I even cut a little bit of grass.
Besides the fact the shroud doesn't match the decal as close as I'd like,I'm really pleased how this turned out.
ID:	2383979   Click image for larger version
ID:	2383981   Click image for larger version
ID:	2383983   Click image for larger version
RfWi is offline
