Lighting coil for a Quantum ? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 08-31-2016, 02:17 PM Thread Starter
Certified Shadetree Mech.
jcsmith's Avatar
I have a push mower with a B&S Quantum , recoil start only. I know there is an alternator for electric start models, but what I need is one for lights only.
I want to put a light on so as it gets dark I can still mow . Anyone know how I could accomplish this. Appreciate any info.
Chris
1968 Cub Cadet 104, '96 service replacement K301, 42" deck
2007 John Deere LA 130,21hp v-twin intek , 48" deck , 1997 Scotts 42502X8,( by Murray ) 2nd repower, '96 18hp B&S Twin ll,42" deck
As you slide down the Banister of Life, may the splinters point in the right direction !
jcsmith is offline
post #2 of 11 Old 08-31-2016, 03:41 PM
Re: Lighting coil for a Quantum ?
I believe the electric starts do not have a charging coil but you just charge the battery as needed. I have a 675 Quantum in a JD 70. It was a pressure washer engine and I found all the parts to make it electric start but never found a charging coil for it. About once a month I put the battery on a trickle charger over night. Roger
rhenning is offline
post #3 of 11 Old 08-31-2016, 04:05 PM
Yard Nazi's Avatar
Talking Re: Lighting coil for a Quantum ?
Unless you are mowing for hours on end I would think a headlight for a bicycle would work nicely. I have seen many on the road that are super bright. Do some research as far as brightness and longevity. Most are designed to mount on the handlebars so they should work nicely on a mower handle. Bill
1968 Lawnboy Model 3054******1973 Lawnboy Model 8231******1974 Lawnboy Model 5023
1975 Lawnboy Model 5024******1975 Lawnboy Model 5273******1976 Lawnboy Model 5274
1976 Lawnboy Model 8234EX****1977 Lawnboy Model 5024******1978 Lawnboy Model 5269G
1979 Lawnboy Model 7268******1980 Lawnboy Model 5247******1982 Lawnboy Model 5247
1982 Lawnboy Model 5247*******1972 Lawnboy Model 1015******1972 Lawnboy Model 1015
1987 Lawnboy Model 1400CL****1995 Lawnboy Model 61638
Where there's a will, there's Mr. Bill!***They don't call me MacGyver for nothing!***I have LBAD and DCAD!
Yard Nazi is online now
post #4 of 11 Old 08-31-2016, 10:49 PM Thread Starter
jcsmith's Avatar
Roger, I found charging coil part # 691991 that fits 9,11, and 12 cu/in engines. That is probably what you need . I need to know if it puts out a/c or d/c. Prices I've seen are between 25 and 70 dollars.
Bill, that's a great idea using a bicycle light. I'd rather find the right charging coil so I don't have to mess with batteries.
Thanks fellas for the responses.
Chris
jcsmith is offline
post #5 of 11 Old 09-01-2016, 12:16 AM
old lawnboy's Avatar
Not only will you need the charging coil, but you will need a new flywheel. Models with charging system have flywheel with magnets on inner side of flywheel. Unless you can find a junk engine, it will be very expensive to add. There are a lot of the new LED lights of different type out there that may work.
Bill
old lawnboy is offline
post #6 of 11 Old 09-01-2016, 03:20 PM Thread Starter
jcsmith's Avatar
Bill, This charging coil,# 691991, studs #691094 , screws # 691648 mount on the outside of flywheel , right above dipstick. The flywheel on it has a row of magnets opposite the ignition armature magnets. I don't know for sure but these magnets must be for the charging coil.
In the IPL's I've seen I don't see a regulator/rectifier or diode on the coil plug, so I'm thinking it is a d/c output , which would work for me. I have recoil start only. I appreciate the response.
Chris
jcsmith is offline
post #7 of 11 Old 09-01-2016, 03:36 PM
Wolfy's Avatar
Sorry still probably not what you are looking for but with LED lighting today you can go days and even weeks or months on batteries.
I have a headlight that goes literally on my head for night time work and I have had it for over a year no battery replacements. So you maybe surprised on how long those batteries will last.
Lawnboys! Yeah I have some...
Dad's LB 10550, 10525, 10323, 7023
Wolfy is offline
post #8 of 11 Old 09-01-2016, 03:41 PM
Wolfy's Avatar
For example. https://www.amazon.com/dp/B00IZSM5DY...ycleadvisor-20
Lights that last 50-150 hours for $12 bucks...
Maybe time to think outside the box just a bit. Not saying that way can't be done, but just to consider other more modern options...
10 Best Bicycle Lights 2016 | Bicycle Advisor
Wolfy is offline
post #9 of 11 Old 09-01-2016, 10:13 PM Thread Starter
jcsmith's Avatar
Wolfy, you and Yard Nazi are definitely on to something. I'm starting to lean toward the battery powered LED lights. Thanks for the links.
Chris
Also I'm into 2 stroke saws and bikes and the more I read about Lawn Boys, the more I want one, or two, or.................... !
jcsmith is offline
post #10 of 11 Old 09-02-2016, 10:21 AM
Wolfy's Avatar
Yeah it's crazy how cheap these bright led lights have become.
I'm an engineer And I get stuck in details all the time. I always have to remind myself to ask just because I can do something doesn't mean I should.
I do get several mowers in a year. If I come across one of these "alternator" systems I can pull one off and send it to ya for the cost of shipping.
Yeah you need a Lawnboy for starters!
100x the mower than anything else. But I'm bias:wink:
Good luck with your project. Keep us posted.
And why again are you mowing so late? I too have done that as well. I have my headlight on my head and 2 battery powered leds and I could see pretty good
Wolfy is offline
post #11 of 11 Old 09-02-2016, 12:32 PM Thread Starter
jcsmith's Avatar
I have 2 acres that I mow with the rider, or the wife does. But the dog pen is about 1/4 acre that I push mow. After work some nights I have to cut the pen and if it starts getting dark I want to see the dog turds if I missed picking any up. I have 3 dogs and pick up the " land mines " every day. The wife rarely picks any up so it is my job. I got tired of working on the rider with you know what mashed into the tire treads.
So push mowing is easier , plus a little exercise. Just the other night I ran a fresh one over . Now you know the rest of the story.
Chris
I appreciate the offer as well.I'm definitely interested.
jcsmith is offline
