honda ht-r3811 belt sizes - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 04-10-2019, 09:40 PM Thread Starter
Shanem93's Avatar
picked this machine up last season for 50 bucks. needed alot of work. re did most of the engine new front tires alot of unfreezing the deck and pto. this machine was used and abused and sat outside for most of its life.had to change all the deck plastic bushings as well. ive successfully brought it back and even gave it a new paint job. although i didnt go with the honda colors. i call it the HonDeere. just ordered a new engine belt tensioner pullet cause the bearing exploded. so i have to change all the belts. i see the honda listing but cant cross reference them to a different make. can anyone tell me the sizes so i can pick them up at my local tractor supply or auto parts store.
Shanem93 is offline
post #2 of 4 Old 04-19-2019, 03:37 PM
slednut's Avatar
Re: honda ht-r3811 belt sizes
I have a couple 3013s, I just purchased the engine belt and I think it was 53" x 5/8 ". The OEM stock number is 76182-751-023. I purchased it from Napa Auto Parts, it was a Gates belt. BTW I think you have a 3011, I could be wrong.
https://www.hondalawnparts.com/oempa...011h-hsa-parts
slednut is offline
post #3 of 4 Old 04-20-2019, 12:56 PM
These are the belts for my H3011H and the generic replacement belts I use.
Honda H3011H Belts
Drive belt
76182-751-023 (SB-51) 51 outside length
Blade belt
76181-763-A02 (SB-71.2) 71.25 outside length
Replacement belts:
Drive B49 (deeper than original, hard to squeeze through tight spots and get on engine pulley, but works) 5L520 is same but not quite as deep, easier to mount.
Blade B69 (Deeper than original but works)
John Deere Model 68
Honda H3011H
oldyellr is offline
post #4 of 4 Old 04-23-2019, 09:25 PM Thread Starter
Shanem93's Avatar
no its a 3811. it was marked as a 3811 before i painted it. the engine belt is def a 49". the blade drive belt honda called for was an sb-61. im using a 59" inside diameter belt which does seem to work although im not 100% sure if its right.
Shanem93 is offline
Jacobsen 1200 Super Chief Belt sizes Panzercollector19 Introductions 1 04-10-2019 08:36 AM
LT1000 Mower Belt Issues... flea4me Craftsman/Sears Forum 5 07-30-2018 10:22 AM
Blade Belt issues with 2013 Troy-Bilt (MTD) mower KArthur MTD 10 07-18-2018 10:15 PM
honda 3813 PTO belt - just thought i'd pass this on larryccf Honda 0 06-22-2018 04:29 PM
Deck belt keeps throwing on 2185 SGINSC Cub Cadet Forum 3 04-08-2018 12:12 PM
