Have the clutch off - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 04-07-2019, 09:03 AM Thread Starter
lmichael's Avatar
Have the clutch off
So I got the clutch off my 4514, actually other than the one bearing seems in good shape, however I thought there was only one bearing to it, I found another on the plate where the cable runs behind, (not sure what its called) see photos. Not sure how to remove it either as it seems that has to come off to get to oil pump gear. So looking for guidance
ID:	2370413   Click image for larger version
ID:	2370415   Click image for larger version
ID:	2370417   Click image for larger version
lmichael is online now
post #2 of 4 Old 04-07-2019, 09:52 AM
Re: Have the clutch off
I think the other plate you're seeing is the brake plate. Have you taken out the three nuts it looks like that's what holds it in place.
john c is offline
post #3 of 4 Old 04-07-2019, 10:10 AM Thread Starter
lmichael's Avatar
No I have not simply because I was not sure if a bunch of spring loaded parts would come flying off Also now I see the bearing in that "brake plate" is a 6005U but when I was looking at the parts list I thought that bearing was the one in the pulley. So I see there are 2 bearings but the one in the pulley is not broken down to a separate number. Does anyone know if both bearings are the same? If so............easy, if not what is the other bearing spec/number other than the 6005U?
post #4 of 4 Old 04-08-2019, 09:22 AM Thread Starter
lmichael's Avatar
OK so on the oil pump, there is a smaller section in the center with 3 bolts/screws kind of triangular shaped and a larger round section with maybe 6 bolts/screws. I am assuming the rounder section screws are what is removed to get to the oil pump gear?
Unable to adjust front PTO clutch on 322 Teen with 318 John Deere Forum 25 03-27-2019 06:58 AM
53 NAA clutch and starter stuck jsdesign Ford N's 9N/2N/8N 4 05-14-2018 07:46 PM
More Ford 3000 Dual Clutch adjusting questions dustiebutt Ford/New Holland Tractors 0 11-24-2017 12:28 PM
Lawn Tractor, 90's - 2000 Vintage, Blade Clutch Problems andyjw Backyard Round Table - L & G Tractor Related Topics 0 03-05-2013 06:54 AM
Rider PTO Clutch Disassembly yamato72 Gravely FAQ and Stickies Section 12 10-07-2012 09:06 AM
