Oil Pump gear, and PTO bearing - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 04-02-2019, 07:55 AM Thread Starter
lmichael's Avatar
So pretty much getting ready to pull the PTO clutch off my 4514 as I am pretty convinced the bearing is bad. What is the p/n and or source for that bearing? Is it an easy "press" out/in? Would like to avoid having to buy whole new clutch if only the bearing is bad/noisy
As for the oil pump gear, what is necessary to buy? Obviously the gear but any other parts? Gaskets, etc? Would like to have a full accounting of the parts necessary as I'd like to get this tractor done and out of the garage so I can finish my Simplicity Sovereign as well, once the Honda is done
lmichael is offline
post #2 of 3 Old 04-02-2019, 09:16 PM
Re: Oil Pump gear, and PTO bearing
if you do a search under my name, i posted a pictorial a long time ago, but it was still available not that long ago. IIRC, there's no gaskey but a silicone O ring that goes under the plate or cover.
if you go to Boats.net and look up the parts schematic, you'll find both detailed with part numbers & pricing
larryccf is offline
post #3 of 3 Old 04-03-2019, 08:54 AM Thread Starter
lmichael's Avatar
I went onto partstree and found not only a good break down but all the parts at less $$$ than anywhere else. So I ordered all the oil pump parts and I ordered the PTO clutch bearing as the pto works fine it's just got that whining noise common to a rough bearing
lmichael is offline
PTO Assembly john6185 Honda 25 07-25-2018 08:55 PM
JD GT262 electric PTO shuts engine off in 1st gear mattlyons John Deere Forum 5 07-20-2018 12:23 AM
PTO no trunion block on dog gear trgentry Gravely 6 06-28-2018 07:35 AM
20 G - Brought it home. Canary Al Gravely 411 06-17-2014 07:22 PM
Mid PTO - Found a gear tooth B7610HSD Tripledy Kubota 1 12-28-2012 11:27 PM
