Seperate Choke Control - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 03-06-2019, 08:25 AM Thread Starter
lmichael's Avatar
So just wondering out loud here...............I am not crazy about the throttle and choke being on one control. I have an aversion to having to have throttle wide open to activate choke which causes engine to start at WOT. So curious if anyone else has installed a second control for choke only? Maybe show some photos?
lmichael is offline
post #2 of 5 Old 03-06-2019, 05:58 PM
Kioti SCUT
3 Legged Dog's Avatar
Re: Seperate Choke Control
No, but I'm thinking about doing the same thing.
I have a Husqvarna YTH2348 yard tractor/mower. I have to open the hood, and pull up on the choke rod to fully close the choke before it will start - even with the throttle in the "choke" position.
I've adjusted the choke/throttle cable several times, but it just doesn't last. I thought about running a separate cable just to the choke rod, so that it will operate independent from the throttle. Please let me know how you make out. Thanks, Cal
2017 Kioti CS2210 SCUT w/FEL (the 3 Legged Dog)
2019 PJ model UK142 T/A 14' utility trailer
MTD Yard Machines E644E snowblower
Rigid RD8000 8k/10k generator
3 Legged Dog is offline
post #3 of 5 Old 03-27-2019, 08:52 AM Thread Starter
lmichael's Avatar
Well I got a separate choke knob installed and was actually able to install it in such a way that the choke will work either independently of the throttle or as designed when used at full throttle as a fail safe. But I can now start the little guy up without having to rev the crap outta the engine at just over idle. I will put photos up. I have no idea of the part number of the cable and control I used as they were some pieces I had picked up like 30 years ago from the old Northern Hydraulics up in the north burbs of Minneapolis. Still had the price tag on them. I paid whopping $.29 each LOL.
lmichael is offline
post #4 of 5 Old 03-27-2019, 12:20 PM Thread Starter
lmichael's Avatar
Here are photos as promised. The little switch was added bt previous owner to run a pull behind sprayer. Otherwise other than what I added it's a stock little machine
ID:	2368475   Click image for larger version
ID:	2368477   Click image for larger version
ID:	2368479   Click image for larger version
lmichael is offline
post #5 of 5 Old 03-28-2019, 06:39 AM
Pepsiboy's Avatar
I am having the same problem with my Husky 2448 as both of the above posters. Thinking about doing the separate choke cable also. If weather cooperates with me today, I'll give it a try and post results here. Thanks to both of you for the great tips.
Dave
Pepsiboy is offline
Intek V-twin manual choke conversion? TechnicalLee John Deere Forum 2 10-01-2018 04:21 PM
Lack of Forward Speed ssmewing Case_Ingersoll_Colt Forum 3 08-28-2018 11:21 AM
Choke Cable for a JD420 with a 23hp Vanguard BillCavanaugh John Deere Forum 1 01-01-2013 06:39 PM
how long should I need the choke? onan 16 flavo cadillac Gravely 8 12-09-2012 12:36 PM
