Identifying a series 16 RER early or late production for belts/pulleys - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 05-20-2019, 01:42 PM Thread Starter
Short story, I have an 331416BVE RER that I bought used and have had for a couple years. I replaced the very tired B&S with a similar year Kohler CV16 from a Scotts/John Deere hydro tractor. Before and after the engine swap, I have gone through a couple belts. Mower cuts great with a brand new belt but eventually I can hear the blade slowing and the performance drop. I would like to replace the idler pulleys, belt and whatever else might be causing my issues. On all of the parts diagram they list an early and late model series 16. What is the best way to identify which machine I have?
ID:	2377415   Click image for larger version
ID:	2377417   Click image for larger version
rvernsey is offline
post #2 of 4 Old 05-21-2019, 02:53 AM
NOVAZ27's Avatar
Cool Re: Identifying a series 16 RER early or late production for belts/pulleys
Hello. I have a 331413KVE that requires the 2-2252 belt. After a few cutting seasons the belt will stretch and start to slip some. After I check the belt for burn spots or nicks & cracks and such and find it to be ok I go ahead and readjust the belt tightener spacers located on the rear frame under the seat. You will probably have to buy the Snapper spacers needed or make your own. Since you bought the unit used the extra spacer pack that came with the mower when new are probably long gone. This belt adjustment system is used exclusively on the Square Frame RER's as far as I know. One other note is about the belt alignment. Did you space the drive plate on the replacement Kohler correctly? My 14hp Kohler Command uses an adapter plate to mount the engine to the Snapper frame. This raises the engine around .125" higher than the bottom of the Snapper frame. Raising the drive plate up that .125" "may" put the drive pulley on the drive plate slightly out of alignment. This may cause premature wear on the belt. There is page in one of the manuals that show the proper adjustment. I know that Propwash has shown it on this forum before. I have that page on my computer "somewhere" but I am unable to find it at this time. Perhaps Propwash has it handy and can post it for you on this thread. I have 2 manuals for you. THE 16&19 you may already have. The series 13 has an extensive adjustment section.
HOPE THIS HELPS
NOVAZ27 is offline
post #3 of 4 Old 05-21-2019, 09:22 AM Thread Starter
Thank you for the reply. Currently the mower does not have any frame spacers, but I had one years ago that did and I am familiar with the setup. I don't know if it's rusty, but the last time that I tried to separate the frame halves on this mower they would not budge. This might be another problem in itself because I don't think I am getting good tilting of the halves when I mow. As for mounting of the Kohler CV16, I did not use a mounting plate. Is the mounting plate for changing bolt hole locations or another purpose? I do remember the plate on my last one, but the donor motor came off of another snapper so I had it handy at the time (10+ years ago).
rvernsey is offline
post #4 of 4 Old 05-21-2019, 10:54 AM
These series (16 & 18 ) cause lots of questions , They all seem to use the same belt (7043844 or equivalent 73.75 long) . Im including the
early series 16-33.
propwash is offline
How Many XT3 Owners Out There, Post A Pic Mudyapster Cub Cadet Forum 606 Today 01:23 PM
New Snapper RER Series 6 Owner in NC! Dill Introductions 1 01-29-2019 12:07 AM
4WD is my choice, but which one? bgarfield John Deere Forum 47 07-09-2018 01:03 PM
Should I buy a used GT2544? heygreene Cub Cadet Forum 66 04-08-2018 09:14 PM
Closest comparable JD to Cub? jpeterson1976 Cub Cadet Forum 6 01-04-2018 08:11 AM
