Old Girl - 1974 / 1975 Roper - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 842 Old 11-01-2014, 07:36 PM Thread Starter
larrybl's Avatar
Here we go with another restore! I am taking Waltz tips to heart with this one. Thanks Waltz! https://www.mytractorforum.com/showth...3&goto=newpost
Many good tips, and a great restore and excellent garage to boot.
Some of you may have seen my original post where I found the Roper and brought her home https://www.mytractorforum.com/showthread.php?t=697569, I have since named Her, and started checking Her out.
Deck removed and soaked in PB, Stored for now. It is pretty rusted and the belt cover will need a lot of TLC. The outer mandrills are froze, I pumped them full of grease. I'll come back to this later. Checked the oil, full and clean, Air filter is present but will need replaced, Battery won't take a charge. Looking through the brochures and I will stick with the original colors, not sure about the hub caps. Neighbor said he can help with the decals
ID:	1027729   Click image for larger version
ID:	1027737   Click image for larger version
Name:	Color Scheme.JPG
ID:	1027745   Click image for larger version
Name:	Deck PB Blasted.JPG
ID:	1027769   Click image for larger version
ID:	1027777   Click image for larger version
ID:	1027785   Click image for larger version
1990 18.5 Craftsman (RED)
1988 18.HP 44 Craftsman II (BOH)
1978 Roper 20T (Old Girl)
1988 JD 165 Hydro (Little John) Sold 2019
2012 Craftsman Pro
https://www.mytractorforum.com/showt...hlight=hulk+ii
https://www.mytractorforum.com/14-craftsman-sears-forum/699657-old-girl-1974-1975-roper.html
https://www.mytractorforum.com/12-jo...ttle-john.html
https://www.mytractorforum.com/14-cr...r-hulk-ii.html
larrybl is offline
post #2 of 842 Old 11-01-2014, 07:39 PM Thread Starter
larrybl's Avatar
Re: Old Girl - 1974 / 1975 Roper
I guess I need to bring some of the first pictures here. Roper 20T with a Snow Blower, Tire Chains, and all original manuals.
ID:	1027809   Click image for larger version
Name:	Old Girl is Home.jpg
ID:	1027817   Click image for larger version
2012 Craftsman Pro
https://www.mytractorforum.com/showthread.php?t=699657
larrybl is offline
post #3 of 842 Old 11-01-2014, 08:29 PM
10,000 +posts!
Ericjr16's Avatar
Man that is a nice old machine Larry!
Challenge Met
John Deere 180 yard tug
John Deere LX172 with bagger
1997 John Deere 345 with snowthrower
1971 Bolens 1256 snow caster
1967 Sears Suburban SS10
Many more!! changing by the day!!
John 3:16 Psalm 28:7
"Complain and remain, praise and be raised!
Ericjr16 is offline
post #4 of 842 Old 11-01-2014, 08:56 PM
No Quarter's Avatar
Nice find. Looking forward to see your progress.
1946 Gibson Model A w/WI 5.9hp
1984 John Deere 318 w/Onan 18hp
1989 John Deere 420 w/Onan 20hp (2)
1990 Craftsman GT6000 w/Briggs 18hp (2)
No Quarter is offline
post #5 of 842 Old 11-01-2014, 09:54 PM
Hahn Star
MikMan48's Avatar
Oh boy am i excited to see this. Up to the bleechers i go
Challenge Met
Have you met "The Fahn" yet?
https://www.mytractorforum.com/189-o...meet-fahn.html
MikMan48 is offline
post #6 of 842 Old 11-01-2014, 10:31 PM Thread Starter
larrybl's Avatar
I am out of PB, and need to pick some up tomorrow. Hood and Grill are removed and separated. All the fasteners are bagged and labeled. Just sitting now studying the construction of the old Girl. They didn't skimp on the metal on this one. Transmission does shift, but sounds a little dry. I may try and source some mufflers and engine gasket kit, carb kit, and fuel pump kit.
ID:	1027961   Click image for larger version
ID:	1027969   Click image for larger version
ID:	1027977   Click image for larger version
2012 Craftsman Pro
larrybl is offline
post #7 of 842 Old 11-02-2014, 10:04 AM Thread Starter
larrybl's Avatar
I was thinking about this last night, plus my Wife warned me that Christmas was coming up, so tractor money may have to wait till after the holidays. I think I'll attempt to get the engine running while at this stage of tear down. I'll leave the dash intact and try and free up the throttle and choke cables. The battery positive cable will need a new end installed, and I'll use BMP's 450cca battery as the original battery is dated 07 and won't take a charge, I can set up my clean test gas tank and hook it to the fuel pump. There is some serious rust through in the battery tray, I'll have to make a replacement for it at some point. I have been taking pictures of all the cable routings and wire connections. I do want to finish removing the drive belt (it is the largest belt I have seen to date) and a few more shields around the engine before I attempt to crank it. I only want to see it run long enough to listen, look, feel, and see for any issues before I remove the engine. Depending on how my other chores go today I might be able to make this happen this evening.
ID:	1028209   Click image for larger version
Name:	Choke cable.JPG
ID:	1028217   Click image for larger version
ID:	1028225   Click image for larger version
Name:	Dash wires.JPG
ID:	1028241   Click image for larger version
ID:	1028249   Click image for larger version
2012 Craftsman Pro
larrybl is offline
post #8 of 842 Old 11-02-2014, 12:09 PM
Dayton_King's Avatar
I do the same thing, no matter what it is I make sure I can at least run it and even better drive is around, before I start restoration
1967 Allis Chalmers B10 hydro lift
1967 Allis Chalmers B10 manual lift
Gravely 8122 project to 8242 honda conversion
Gravely 8183-T project to 8203-D diesel conversion
Dayton_King is offline
post #9 of 842 Old 11-02-2014, 05:00 PM
Rumbleseat's Avatar
I've signed up to watch this one!
1981 Craftsman GTV/16 ("The Burro")
1963 Bolens 800, Type 187-01
Always looking for old antique traffic signals too!
Rumbleseat is offline
post #10 of 842 Old 11-02-2014, 05:02 PM Thread Starter
larrybl's Avatar
Prep for a first start
I finished my chores early thanks to the extra hour today. I started with removing the frozen throttle cable, I guess it was getting bad based on the damage to the dash. I think I can repair this. Next I pulled the plugs, both look good and are the same type. I then fixed the + battery terminal. I drained and removed the Gas tank, the gas smelled like varnish. I installed my clean test tank and filled it with fresh gas which has been treated. I removed the drive belt and found the clutch pedal was detached from the clutch bracket. (Glad I removed the belt). Pulled the battery from the BMP and installed, hooked up the battery charger on trickle. Got the other Fire Extinguisher from the old shop, Checked the safeties and verified the key switch worked by bumping the starter (It turned over 1/4 to 1/2 turn) I'm exited now! Freed up the throttle cable and re-attached. All I am waiting on now is the video camera to charge so I can film this.
ID:	1028537   Click image for larger version
ID:	1028545   Click image for larger version
ID:	1028553   Click image for larger version
ID:	1028569   Click image for larger version
ID:	1028577   Click image for larger version
ID:	1028585   Click image for larger version
ID:	1028609   Click image for larger version
ID:	1028617   Click image for larger version
ID:	1028625   Click image for larger version
2012 Craftsman Pro
larrybl is offline
post #11 of 842 Old 11-02-2014, 05:09 PM
10,000 +posts!
Ericjr16's Avatar
Bet she fired up!!
Challenge Met
Ericjr16 is offline
post #12 of 842 Old 11-02-2014, 07:24 PM Thread Starter
larrybl's Avatar
; I didn't have the throttle cable set properly other wise it would have started easier. Mission accomplished! It seems to run good (I'll post a second video where the throttle cable is adjusted) Lot of work ahead but I know the engine will be worth it.
2012 Craftsman Pro
larrybl is offline
post #13 of 842 Old 11-02-2014, 07:36 PM
10,000 +posts!
Ericjr16's Avatar
YEAH!!!!!!!!!!! Sounds real good Larry!!!!!!!!!!!!!!!!!
Challenge Met
Ericjr16 is offline
post #14 of 842 Old 11-02-2014, 07:47 PM Thread Starter
larrybl's Avatar
I adjusted the throttle cable, starts real easy now. I didn't prime it at all.
2012 Craftsman Pro
larrybl is offline
post #15 of 842 Old 11-02-2014, 07:52 PM
10,000 +posts!
Ericjr16's Avatar
Man it sounds real good! You did real good buying a strong engine!!
Challenge Met
Ericjr16 is offline
