This may help, pictures on wiring on a 1970 SS12 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 10-31-2010, 09:09 PM Thread Starter
Tractor addict
BillTheTractorMan's Avatar
Send a message via MSN to BillTheTractorMan Send a message via Skype™ to BillTheTractorMan
I was out working on my SS12 today, had some troubles with the wiring diagram but got it all figured out. Now this could help you if your wires are correctly colored, or if you spend some time looking at this and your tractor.
First is of the S/G properly wired up.
Here's the voltage regulator. I color coded my circles to the wire color.
A) green wire wire, green circle runs on the dash side up to the right terminal on the S/G
B) Red wire, red circle runs from the voltage reg. to the ammeter
C) Orange wire, orange circle runs from voltage reg. to light switch
D) Brown wire, brown circle run from opposite side, or underside of voltage reg. to the left terminal on the S/G
The larger cable from the ignition switch connected to mine on the left side terminal, I have also heard of peoples connecting on the right side terminal. How ever the Red positive wire from the ignition always connects to the same terminal as the brown wire.
This is looking in from the flywheel side of the engine, or clutch pedal side of the tractor. This wiring explanation will also only work if every thing is still correctly place, please refer to my pictures.
I hope this helps, I only covered the voltage reg. and S/G because it's all that I worked on and have pictures of, the rest is straight forward on the wiring diagram. If I remember correctly the wiring diagram is available in the craftsman/sears stickies sub-forum.
Sears GT group (suburbans/customs/etc)
http://www.facebook.com/groups/101589189889692/
Growing website for user based uploads about Sears tractors. (file sharing, forums for posting and reading guides, etc)
http://www.mysearstractor.com/
BillTheTractorMan is offline
post #2 of 8 Old 10-31-2010, 10:36 PM
oatville's Avatar
Re: This may help, pictures on wiring on a 1970 SS12
Thanks for the pictures. Unless I was doing a true restoration, I would probably take the first oppurtunity to replace the original engine with a modern one and get the benifits of a modern alternator-starter-solid state Magneto electrical system.
ID:	127221 Name:  2MakeJpeg.jpg
ID:	127219 Click image for larger version
http://www.smallenginewarehouse.com/...y=Engine&HP=12
My GT5000 Dirt Toy
oatville is offline
post #3 of 8 Old 11-01-2010, 12:07 PM
Cranky Motorsports
GT_80's Avatar
There is still something to be said for having an original year motor in it, (even if it is out of another tractor).
Nostalgia, and the fun of getting an old motor running again
Hugh-SS/16 fan #0001
1967 Sub 12 Diesel
1967 Super 12 Special
1967 Super 12
1966/68 Sub "Miss Emma Lee" Diesel
1968 Super 12 Hydrotrac
1970 Sub 12
1970 Sub 12
1971 SS14 Hydro Diesel
1973 SS16 Diesel
1973 SS16 (red)
1973 SS16
1974 SS16
1976 SS18
1976 Roper RT16T with Loader
1978 Roper RT16 (pinky)
1978 GT18
1991 Craftsman with loader
My YouTube
GT_80 is offline
post #4 of 8 Old 03-19-2015, 04:27 PM
Hunterdustin7's Avatar
question what could make the engine not turn off when key is in off position and lights not turn on. like the engine starts but only if key is held at a certain position once running it can be turned off but by chocking it out you can turn the key any which away and i put a new ignition switch but the problem of killing the engine still exsists
Hunterdustin7 is offline
post #5 of 8 Old 03-19-2015, 04:42 PM
mightyraze's Avatar
Grounding issue? Start you a new thread and people will help out.
Things to mention, Year and Model of your tractor!
-Jerry
2006 18hp LT1000 - 917.276390
1998 17.5 Murray Wide Body - 42505x92a
1994 15HP Twin LT4000 - 536.257670
1992 Troy Bilt - 6.5HP Repower Buggie
1990 Craftsman II - 917.2559101
1977 18hp Twin Hydro - 917.25980
1975 13hp repower- ST16 - 917.25874
Cabin Fever Contest Winner, 1st Place!
mightyraze is offline
post #6 of 8 Old 03-19-2015, 05:02 PM
Is your tractor EXACTLY the same one as in the original post?
There's over 200 Craftsman electrical schematics and they AREN'T all the same.
Bill Kapaun is offline
post #7 of 8 Old 03-19-2015, 05:36 PM
its the same as the picture and how do i start a new thread
post #8 of 8 Old 03-19-2015, 05:56 PM
Click the New Thread Button on the left below the list of threads
