Wobbly wheel - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 22 Old 09-19-2019, 01:56 PM Thread Starter
Unhappy Wobbly wheel
Hi Y'all,
I have a Sear Craftsman Garden Tractor purchased new in 2001. 20 horse Kohler.
My question is: right front wheel is beginning to wobble. What might that be? Bearings? Or what?
Please help.
Jerry
Gabrovic is offline
post #2 of 22 Old 09-19-2019, 02:31 PM
mightyraze's Avatar
Re: Wobbly wheel
Without more information we would be just guessing.
Good things to look at would be bearings, maybe bent wheel, or could be a worn spindle. Don't be afraid to investigate it closer, jack it up and pull the tire/wheel off and check it out.
-Jerry
2006 18hp LT1000 - 917.276390
1998 17.5 Murray Wide Body - 42505x92a
1994 15HP Twin LT4000 - 536.257670
1992 Troy Bilt - 6.5HP Repower Buggie
1990 Craftsman II - 917.2559101
1977 18hp Twin Hydro - 917.25980
1975 13hp repower- ST16 - 917.25874
Cabin Fever Contest Winner, 1st Place!
mightyraze is offline
post #3 of 22 Old 09-19-2019, 03:06 PM Thread Starter
Re: Wobbly wheel
Thank you. I will do just that.
Jerry
Gabrovic is offline
post #4 of 22 Old 09-19-2019, 03:14 PM
Blank Space
Re: Wobbly wheel
Need pictures. Many of that type of machines don't have bearings at all, just a bushing or maybe just the wheel slid onto the axle shaft.
LS MT125
post #5 of 22 Old 09-20-2019, 08:43 AM
Cranky Motorsports
GT_80's Avatar
Re: Wobbly wheel
First guess would be any of the above. I think the newer Craftsmans used plastic bushings in the wheels. Sometimes a tire that went flat and was re-inflated may not be 100% seated on the rim as well, making it look like its wobbling, when in fact it is just the tire. All things considered, even if it was so bad that the wheel was bent and wobbling a couple inches, it wouldn't matter. You're never going fast enough to have it matter. But it would bug me if it was bad
Hugh-SS/16 fan #0001
1967 Sub 12 Diesel
1967 Super 12 Special
1967 Super 12
1966/68 Sub "Miss Emma Lee" Diesel
1968 Super 12 Hydrotrac
1970 Sub 12
1970 Sub 12
1971 SS14 Hydro Diesel
1973 SS16 Diesel
1973 SS16 (red)
1973 SS16
1974 SS16
1976 SS18
1976 Roper RT16T with Loader
1978 Roper RT16 (pinky)
1978 GT18
1991 Craftsman with loader
My YouTube
GT_80 is offline
post #6 of 22 Old 09-20-2019, 09:23 AM
Professional Homeowner
steddy's Avatar
Re: Wobbly wheel
90% sure your plastic wheel bushing is shot. My neighbor has to replace his every few years. There was a thread awhile back (within last few months) with instructions on how to replace them with ball bearings. Neighborís machine was an LT1000, I think. Bushings would get so bad the wheels would tip in/out like 5 degrees or more. It looked ridiculous.
steddy is offline
post #7 of 22 Old 09-20-2019, 10:44 AM
Re: Wobbly wheel
If it is a simple axle where the hub rides on the axle with no bearings and no bushing, it might be worn out and in need of a repair sleeve, but this is pure speculation. Some pictures or a detailed description would likely get you more useful info.
Bobcat M610
Bolens 750
M&W LC 1890K Zero turn 54"
dtsh is offline
post #8 of 22 Old 09-20-2019, 02:22 PM
Slightly Autistic
Bill Kapaun's Avatar
Re: Wobbly wheel
https://www.mytractorforum.com/14-cr...e-posting.html
Look up flange bearing.
Without posting the model# to determine which of the over 1200 different craftsman models, I'm not going to venture to guess which one.
Most Craftsman LT's will use the same bearing. (plastic bushing)
But we don't even know if you have an LT.
Illegally Blind
Bill Kapaun is offline
post #9 of 22 Old 09-20-2019, 03:37 PM
Re: Wobbly wheel
https://www.amazon.com/XiKe-Bearing-...s%2C259&sr=8-3
i have these in all my tractors,lt 1000,ys4500,and7400 pro
lorraine984 is offline
post #10 of 22 Old 09-20-2019, 07:56 PM
Re: Wobbly wheel
Why on God's earth do these firms use plastic bushing? Even my JD 48 inch blade kit came with some plastic bushings for one of the shafts where it enters the frame. Although I am sure the engineers have tested these, I detest them.
But plastic bushings on an axle? What do you get, 2 maybe 3 years?
X 500 48" Deck 48" blade
Cyclone Rake
Stihl BR 600
Sears Suburban Super 12 1968
Alien5044 is offline
post #11 of 22 Old 09-20-2019, 08:30 PM
Re: Wobbly wheel
They build them to wear out.
Forest Gump is offline
post #12 of 22 Old 09-20-2019, 08:32 PM
10 fingers 10 toes
Kubota Ronin's Avatar
Re: Wobbly wheel
I'll go out on a limb here... manufacturers have to spend so much time and money engineering and implementing "safety" features that they can no longer afford wheel bearings.
Scott
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
post #13 of 22 Old 09-20-2019, 10:36 PM
Re: Wobbly wheel
Maybe because cheaper plastic will wear for sure and not other more costly metal. Rather change a plastic bushing than a spindle or wheel hub.
38racing is online now
post #14 of 22 Old 09-21-2019, 11:50 AM
Re: Wobbly wheel
Most of the time plastic wheel bushing cause the spindles to wear down,people don't grease them,probably the manufacturer doesn't suggest too either..
It is a case of putting a cheap part that will ruin an expensive part when it wears out rapidly,to increase sales & profits more than anything..
I am no fan of nylon or plastic bushing for wheels ,or steering components especially..bad enough the open gears skip,strip and get their teeth busted off as soon as the plastic bushings wear out in one or two mowing seasons..
I have tried replacing them with brass bushing on the steering gears,they will last longer,but still end up letting the gears get too sloppy ...why they cant use a real "steering box" like a car that is a sealed unit baffles me..making stuff so cheesy does nothing for customer satisfaction..
Tractor-Holic is offline
post #15 of 22 Old 09-21-2019, 01:39 PM
Re: Wobbly wheel
I've seen where some guys install flange bearing in place of the plastic front wheel bushing with good results. Amazon and flea bay has 4 flange bearings once you determine the size for usually around $15.
AND yes, steering sectors, wheel bushings, front axle area on lawn tractors that use plastic bushing sucks big air. (and the price of plastic replacements also suck big air)
and some manu recommend not greasing the plastic bushings because dirt will get in and it's then it's sanding itself, but the same type of another machine may have grease serts in the rim for greasing the plastic bushings)
But again we are not suppose to operate these machine at hi-way speeds.
