Mobil 424 Hydraulic Fluid vs Hy-Gard - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 06-19-2019, 01:13 PM Thread Starter
AYP123's Avatar
Hello! I'm working on a Craftsman DLT 3000 w/ a Peerless H2000-006A Silent-Trac transaxle. I wanted to know what fluid I should use in the pump? From what I found, the tractor takes Mobil 424 Hydraulic Tractor Fluid. I was considering using John Deere Hy-Gard though, as I'm thinking it may be better for the tractor. I also wanted to know if I should use the low or high viscosity Hy-Gard if I do get it. Thanks, Ashton.
1994 Craftsman LT4000
2006 Craftsman Mid Engine Rider
2003 Yard-Man 13BT604G452
2004 Craftsman LT1000
2002 Craftsman DLT 2000
2004 Craftsman LT2000
1998 Craftsman EZ3
1992 John Deere LX176
2008 Poulan Pro XT
1993 Montgomery Wards Signature Series 2000 Garden Tractor
1993 Craftsman LT4000
2001 Craftsman 14.5HP Lawn Tractor
1995 Craftsman GT6000
1999 Yard Machine 14.5 HP LT
2001 Craftsman LT1000
2003 Craftsman LT1000
2003 John Deere L111
2000 Craftsman EZ3
...and counting!
AYP123 is offline
post #2 of 17 Old 06-19-2019, 01:25 PM
Caustic's Avatar
Re: Mobil 424 Hydraulic Fluid vs Hy-Gard
Pull the manual and see what it specifies. The specification will tell you the viscosity and lubrication additives needed for that that transaxle.
Unintended Craftsman Collector it seems!
*** Ride On ***
Craftsman 644.605120 .... Some crazy Canadian 12 HP machine rescued from a flood once-upon-a-time in the Yukon!
** Chain Saw **
C944.419460 Special Edition (Husquvarna Anti-Vibration Handle?) - Non-working
358.360680 - Given to a friend that needed a saw
*** Walk Behind Tractor ***
Simplicity W 7.25 HP 1961
Simplicity VC 7 HP 1959
Simplicity V 5 HP 1953/54
*** Compact Tractor ***
Mitsubishi MT1601D 1982/1983
Caustic is offline
post #3 of 17 Old 06-19-2019, 01:28 PM Thread Starter
AYP123's Avatar
There are a whole bunch of documents online but I can't seem to find the specifications for it. It seems that the only thing I could find was that they wanted Mobil 424.
1998 Craftsman EZ3
2008 Poulan Pro XT
2000 Craftsman EZ3
...and counting!
AYP123 is offline
post #4 of 17 Old 06-19-2019, 01:36 PM
Caustic's Avatar
This says its 80W90. 2000-2000-006A.pdf
*** Ride On ***
** Chain Saw **
Caustic is offline
post #5 of 17 Old 06-19-2019, 01:37 PM
Caustic's Avatar
This says its 80W90. Attachment 2382643
Not sure if that pdf uploaded or not, the link to it is:
https://mymowerparts.com/pdf/Tecumse...-2000-006A.pdf
*** Ride On ***
** Chain Saw **
Caustic is offline
post #6 of 17 Old 06-19-2019, 01:39 PM Thread Starter
AYP123's Avatar
Yes, 80W-90 for the final drive, not for the hydraulic pump. I know what to put in the final drive. I think Iíll just go with standard viscosity Hy-Gard for the pump. I pulled the product information sheets and Hy-Gard was a bit better.
1998 Craftsman EZ3
2008 Poulan Pro XT
2000 Craftsman EZ3
...and counting!
AYP123 is offline
post #7 of 17 Old 06-19-2019, 03:06 PM
Caustic's Avatar
Ah, must be this one mentioned in a Sears forum then:
"Manage My LifeSeptember 30th, 2013
The pump takes Tecumseh hydrostatic fluid part number 730228A,. It must be that type of oil as others will mess the pump up.
Tecumseh Transmission Oil Hydro Fluid 730228A
Description
Alco Synthetic Hydrostatic Transmission Fluid 1 Quart. 15-50 WT
Replaces
STENS 770-131
TECUMSEH 730228A
ROTARY 11589
*** Ride On ***
** Chain Saw **
Caustic is offline
post #8 of 17 Old 06-19-2019, 03:11 PM Thread Starter
AYP123's Avatar
Description
Replaces
STENS 770-131
TECUMSEH 730228A
ROTARY 11589
Thanks for the info. After searching around I think I'm going to go with neither of these options. I did a little digging around through the product information sheets of both the Mobil 424 and JD Hy-Gard, and I think that I don't want either one. Instead I'm going to go with AMSOIL Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-30, as it seems to be the much better option for the pump. For the final drive, I'm going to go with their Severe Gear Oil 80W-90. It may be more than what it needs, but I think it will be a great combination for what I do. I trust AMSOIL more than Mobil for sure.
1998 Craftsman EZ3
2008 Poulan Pro XT
2000 Craftsman EZ3
...and counting!
AYP123 is offline
post #9 of 17 Old 06-19-2019, 03:16 PM Thread Starter
AYP123's Avatar
Description
Replaces
STENS 770-131
TECUMSEH 730228A
ROTARY 11589
Has anyone been able to find what capacity the pump and final drive has?
1998 Craftsman EZ3
2008 Poulan Pro XT
2000 Craftsman EZ3
...and counting!
AYP123 is offline
post #10 of 17 Old 06-19-2019, 03:35 PM
Caustic's Avatar
Tecumseh is unclear, but list the 2000 as unservicable and similar to the 2300. If it is, the 2300 takes 64oz in the transaxle. This is in tecumseh's service manual.
No mention on the pump volume. I note they say 15W50 above, 30 might be a bit light when it gets warm?
*** Ride On ***
** Chain Saw **
Caustic is offline
post #11 of 17 Old 06-19-2019, 03:42 PM Thread Starter
AYP123's Avatar
I did notice that. According to Tecumseh, the transaxle operates at 170 degrees Fahrenheit, so when I look at the product information sheets, I’ve been looking at the kinematic viscosity tests performed at 100 degrees Celsius which is 212 Fahrenheit. They’re all relatively the same. AMSOIL is about 5 cSt behind Hy Gard, at 55 cSt. I’m thinking that as long as it has a good rating their, it will be ok. Should I not use the 5W-30 though? I was reading through some YouTube comments and the person said they used the AMSOIL along with the Severe Gear and it works just fine for them after 3 years.
1998 Craftsman EZ3
2008 Poulan Pro XT
2000 Craftsman EZ3
...and counting!
AYP123 is offline
post #12 of 17 Old 06-19-2019, 03:44 PM Thread Starter
AYP123's Avatar
Also, when you say 64 oz in the transaxle, do you mean the final drive? Or do you mean the hydraulic pump?
1998 Craftsman EZ3
2008 Poulan Pro XT
2000 Craftsman EZ3
...and counting!
AYP123 is offline
post #13 of 17 Old 06-19-2019, 08:51 PM
Caustic's Avatar
Tecumseh calls it a transaxle; to me, you normally find final drives in skidsteer, excavators, and tracked tractors.
I could not find a spec that had the volume listed for the pump. Would reccomend measuring it when you drain it.
*** Ride On ***
** Chain Saw **
Caustic is offline
post #14 of 17 Old 06-19-2019, 08:53 PM
Caustic's Avatar
Final drives typically look something like this
*** Ride On ***
** Chain Saw **
Caustic is offline
post #15 of 17 Old 06-20-2019, 04:24 PM
20,000 Posts & Climbing
A transaxle is a transmission and final drive (rear end reduction and differential) all in the same case
Many older hydros were mated to separate final drives in both LTs and GTs. While normally both are removed if service is required for either the transmission or the final drive, the larger hydro transmissions can often be pulled while leaving the final drive in the chassis. Since only the final drive is bolted to the chassis, the reverse isn't feasible.
TUDOR is online now
