Nothing happens when I turn ignition key LTX1000 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 22 Old 06-18-2019, 03:27 PM Thread Starter
Hi,
I just bought a used Craftsmen LTX1000 (Model # 917.272450) last summer. I replaced the battery, plugs, fuel filter and air filter. It was starting and running great until last weekend. Actually it started up easily a couple of different times that weekend - I had to mow the grass at the lake on 2 separate days because I got rained out before I could finish. Anyway, the second day like I said it started right up and I was almost done when I noticed that the deck on the left side, as I'm sitting on it, looked lower than the other side.
I turned the mower off and looked under the deck - this is the side that has the turn knob that adjusts the height of the deck. I lifted up on the deck and saw that it did raise a little bit more and it looked more level with the other side. There was a nut underneath, so I adjusted that so that now my deck was a bit higher on that side. I also reached in above the deck and scooped out several handfuls of lawn debris.
When I went to start the tractor again nothing happened when I turned the key. It didn't turn over and acted completely dead. Although I had a new battery, I undid the wires and took a wire brush and sandpaper to make sure there was a good connection - still absolutely nothing.
So, what could be the issue? I did accidentally knock a wire loose when I cleaned out debris? Or is there some sort of safety switch that I disengaged or that happened to just stop working? Any help is greatly appreciated.
Thanks. Ken
KenSchu is offline
post #2 of 22 Old 06-18-2019, 03:43 PM
Caustic's Avatar
Re: Nothing happens when I turn ignition key LTX1000
Step 1, short your solenoid control line and see if it clicks.
If it clicks you are good, if not: either you need a new one or your battery is too low.
That is the most common issue. Rule it out before waste time looking in other places.
Unintended Craftsman Collector it seems!
*** Ride On ***
Craftsman 644.605120 .... Some crazy Canadian 12 HP machine rescued from a flood once-upon-a-time in the Yukon!
** Chain Saw **
C944.419460 Special Edition (Husquvarna Anti-Vibration Handle?) - Non-working
358.360680 - Given to a friend that needed a saw
*** Walk Behind Tractor ***
Simplicity W 7.25 HP 1961
Simplicity VC 7 HP 1959
Simplicity V 5 HP 1953/54
*** Compact Tractor ***
Mitsubishi MT1601D 1982/1983
Caustic is offline
post #3 of 22 Old 06-18-2019, 03:44 PM
I know itís a dumb question but u never know... is the deck dis-engaged? If the batt is new, a safety switch is not set or the solenoid isnít working. If it was the solenoid I should hear a clicking when key is turned
e.fisher26 is offline
post #4 of 22 Old 06-18-2019, 03:53 PM Thread Starter
Can you please tell me step by step how to do this? I'm pretty handy but I am not familiar with this procedure. Thanks.
KenSchu is offline
post #5 of 22 Old 06-18-2019, 03:56 PM Thread Starter
Yes the deck was dis-engaged and in the raised position. I did wonder if that safety switch under the lever to engage/dis-engage the blades could be the issue. As stated above, I don't know how to check if the solenoid is working.
KenSchu is offline
post #6 of 22 Old 06-18-2019, 03:59 PM
If not clicking, then a safety switch, one for the seat, brake/clutch, neutral on the trans, and the deck. Does it have a manual handle or electric pto for the deck?
post #7 of 22 Old 06-18-2019, 04:07 PM
Caustic's Avatar
Take a length of wire (or if you have room you can use a jumper cable) and go from the positive on your battery to the small pole on your solenoid.
You are briefly connecting these, it is a 12V activation signal line. This will activate it even if the engine is off (and it should be for this test) or any safety switches are tripped.
*** Ride On ***
** Chain Saw **
Caustic is offline
post #8 of 22 Old 06-18-2019, 04:13 PM Thread Starter
Manual handle to engage the deck.
KenSchu is offline
post #9 of 22 Old 06-18-2019, 04:26 PM Thread Starter
One other thing that I remembered, it did seem like the brake/clutch pedal was not going nearly as far when I pushed on it with my foot.
KenSchu is offline
post #10 of 22 Old 06-18-2019, 04:28 PM Thread Starter
Would I be able to easily find these safety switches (I do know about the one for the seat)? How would I know if a particular safety switch was the issue?
KenSchu is offline
post #11 of 22 Old 06-18-2019, 04:35 PM
Caustic's Avatar
This might point to your issue as there is a clutch/brake switch to keep you from running over people if it is in gear.
However, you likely just pulled out a loose connection.
Go from simple to complicated.
*** Ride On ***
** Chain Saw **
Caustic is offline
post #12 of 22 Old 06-18-2019, 04:54 PM Thread Starter
I am thinking it is something simple, I'm just unfamiliar with troubleshooting & handyman work on small engines/tractors. And wiring is my worst subject. I suppose I just need to look and follow wires to see if anything got disconnected.
KenSchu is offline
post #13 of 22 Old 06-18-2019, 04:58 PM
Safety switches is a good guess....but first check the 20 amp fuse near the solinoid...if that is blown no power goes anywhere.....
Cranman is offline
post #14 of 22 Old 06-18-2019, 05:27 PM Thread Starter
I'm not exactly sure where the solenoid is located, nor that fuse. Could you provide me a little direction please.
KenSchu is offline
post #15 of 22 Old 06-18-2019, 05:43 PM
Caustic's Avatar
Follow your positive battery cable, the first thing you come to will be a three terminal device (two large lugs, one small), that is your solenoid.
The fuse will be on a smaller wire off the positive and has a clearish case that pops open. Inline fuse, going to the ignition.
*** Ride On ***
** Chain Saw **
Caustic is offline
