My New To Me Sears Craftsman FF Loader - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 25 Old 06-12-2019, 08:08 PM Thread Starter
Sears Craftsman FF24
rwolf15241's Avatar
My New To Me Sears Craftsman FF Loader, Looking for Dual Wheel Adapters
Name:	Sears FF Tractor.jpeg
Sears SS16- Really Clean Parts
Sears SS18- Parts
Sears GT 19.9 - Parts
Sears GT 19.9 - Runs Great, For Sale Or Parts
Sears FF20- Parts Tractor
Sears FF20- Snow Blower
Sears FF24- need hood
Sears FF24-Rebuilding & looking for Parts
Sears SS 16- Plows, Middle Buster, parts for Sale
Wanted Sears FF20, FF24 Parts or Whole & attachments
**NEED FACTORY FRONT END LOADER FOR MY SEARS FF24**
rwolf15241 is offline
post #2 of 25 Old 06-13-2019, 12:56 AM
20,000 Posts & Climbing
Re: My New To Me Sears Craftsman FF Loader
Why?
What size are the rear tires?
TUDOR is offline
post #3 of 25 Old 06-13-2019, 05:27 AM Thread Starter
rwolf15241's Avatar
26x12x12
Sent from my SM-N950U using MyTractorForum Free App mobile app
Sears SS18- Parts
post #4 of 25 Old 06-13-2019, 06:35 AM
FF and a loader??? Wow, where in the world did you ever find those two things???
Mike
TRACTORS:
OTHER (NOTABLE) EQUIPMENT:
Echo PB751T backpack blower
Husqvarna 350 chainsaw
RETIRED TRACTORS:
mikeinri is offline
post #5 of 25 Old 06-13-2019, 06:53 AM Thread Starter
rwolf15241's Avatar
I have 4 Sears ff tractord
Sears SS18- Parts
post #6 of 25 Old 06-13-2019, 06:56 AM
Wow, only in PA!!!
Mike
TRACTORS:
RETIRED TRACTORS:
mikeinri is offline
post #7 of 25 Old 06-13-2019, 07:01 AM Thread Starter
rwolf15241's Avatar
I have A-line on another 24
Sears SS18- Parts
post #8 of 25 Old 06-13-2019, 07:59 PM
Originally Posted by rwolf15241 View Post
26x12x12
Those tires will carry 140 lb of Rim Guard each.
While duals contribute to stability, they create a couple of other problems. They limit maneuverability . A 4' wide tractor becomes 6' wide and a GT can't handle a 6' bucket on the loader to clear a path wide enough for the tractor to pass.
While they improve flotation when dealing with soft ground conditions, it has to be remembered that the small front tires of a loader equipped tractor actually carry a heavier load than the rear tires. The maximum load on the rear tires is half the weight of the bare tractor, plus the weight of the operator and any ballast applied, including an implement on the 3PH. The rated max implement weight for your tractor is 400 lb. The max static load rating for the rear axle is 1500 lb, including what is on the 3PH. Wheel weights and liquid ballast are not carried by the axle, but there is a max weight rating for the rear tires as well, and that can only be achieved with duals and considerable ballast.
Bottom line, duals are an aesthetic application. There are few loader tractors in the real world that are equipped with duals. The agricultural community will put a loader on a field tractor with duals when required, because it is a major undertaking to remove duals that weigh upwards of a ton each.
For reference, the GT pictured below is carrying 400 lb of applied ballast weight, and can lift and carry 600 lb in the 210 lb 54" bucket in this configuration, and still has the same traction capabilities as the same tractor without the loader and applied ballast. The implement normally carried as additional ballast was omitted due to restricted maneuvering space in the 3' deep excavation of my driveway. With 40 years of GT loader experience under my belt, I've never come across a situation where duals would be an asset.
Originally Posted by mikeinri View Post
Wow, only in PA!!!
Mike
I saw one for sale in WI a few years back. The arms are a bit further apart than needed for most GTs because of the wide hood.
The FF series are really Boss looking tractors when all decked out.
TUDOR is offline
post #9 of 25 Old 06-15-2019, 09:36 AM Thread Starter
rwolf15241's Avatar
I still want dual wheels, lol
Sears SS18- Parts
post #10 of 25 Old 06-17-2019, 03:32 PM Thread Starter
rwolf15241's Avatar
They sold the dual wheel kit for a reason
Sears SS18- Parts
post #11 of 25 Old 06-17-2019, 06:37 PM
Yup. For the same reason that any company sells a product . . . to generate a profit.
I had the very same thoughts as you when I first started playing with loader GTs over 40 years ago. Almost 4000 hours of using said tractors has 'adjusted' my thinking.
Duals work great in the field for flotation on the soft soil when gardening. Not so good for loader applications where traction and maneuverability are more important.
TUDOR is offline
post #12 of 25 Old 06-17-2019, 08:41 PM
B440's Avatar
Duallies!
https://www.xtrememotorworks.com/Par...Cub-Cadet.html
B440 is offline
post #13 of 25 Old 06-18-2019, 03:21 PM Thread Starter
rwolf15241's Avatar
They don't make 6 bolt spacers
Sears SS18- Parts
post #14 of 25 Old 06-18-2019, 05:09 PM
B440's Avatar
Well that's an oddball rim for a tractor
Does it use 1" axles and hubs? How about swapping hubs to the more-common 5-lug?
B440 is offline
post #15 of 25 Old 06-18-2019, 05:39 PM Thread Starter
rwolf15241's Avatar
New, rims, hubs, more money, I will.just make them
Sears SS18- Parts
