66ss brake vs clutch - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 04-20-2019, 09:27 PM Thread Starter
Hillbilly Homer's Avatar
Question 66ss brake vs clutch
i finely got around to replacing the brake on my 1966 sears suburban 10.
Now if i adjust where the brake works the drive belt will not fully disengage and will grind when going into gear. Used new 1/4" thick baler belt for the brake lining.
Anyone have any ideas of what i did wrong...
A man that has never been lost
is a man that never knew where he was going.
Hillbilly Homer is offline
post #2 of 5 Old 04-20-2019, 09:32 PM
Re: 66ss brake vs clutch
I think the original lining was about 1/8 of an inch. I do not think you can get enough adjustment for 1/4 inch lining. Either find the correct lining or sand your thinner. Roger
rhenning is offline
post #3 of 5 Old 04-20-2019, 10:45 PM
I used an old serpentine belt for brake lining on my SS-12 and its pretty thick (or was when first installed !),I was able to adjust the clutch & brake enough to get them both to behave properly..
This is a manual copy of the Suburbans,scrolling down you'll see the procedure to adjust both right..until I found this online I was ready to give up on getting my tractor to shift without grinding the teeth off the gears!..one adjustment affects the other,both have to right..http://vintagesearsgardentractors.co...tor_manual.pdf
Tractor-Holic is offline
post #4 of 5 Old 04-21-2019, 06:07 AM Thread Starter
Thank you for the reply.
The original lining is 3/16. LOL if i cant get it to adjust out ill start it in gear and ride the brake a bit to ware it down as i mow the weeds.
Thank you for the link.
i hate it when gears grind
post #5 of 5 Old 04-22-2019, 04:06 PM Thread Starter
Thank You for the help! it will now go and stop without the gear grinding.
P.S. After doing the adjustments if you find it will not move or kills the motor.
You may need to release the parking brake!
Craftsman GT18 w/ Peerless 143-820-016 Brake Lever Clutch Trouble dougand3 Craftsman/Sears Forum 14 07-19-2018 11:45 AM
GT5000/Excellerator Model:28947 -Brake system question botchy5967 Craftsman/Sears Forum 1 05-17-2018 09:17 AM
53 NAA clutch and starter stuck jsdesign Ford N's 9N/2N/8N 4 05-14-2018 07:46 PM
Lawn Tractor, 90's - 2000 Vintage, Blade Clutch Problems andyjw Backyard Round Table - L & G Tractor Related Topics 0 03-05-2013 06:54 AM
Honda HR215 Blade Brake Clutch Removal Cairnhwy Walk Behind Mowers 4 01-10-2013 08:31 AM
